Sagan Technology Metro • View topic - fixing an issue
fixing an issue
fixing an issue
Postby françois » Sun May 11, 2014 1:05 pm
Hello Jerm,
This answer from Attila ( rapid composer ) about a crash between RC ( as vsti ) and metro
Cheers
François
Re: another crash :)
This crash was not caused by RapidComposer. Metro unloaded RapidComposer from the memory, without cleaning up, while it was running. It is like when you are walking on the street, and someone removes the pavement under your feet...
Process: Metro [24139]
Path: /Applications/Metro Folder/Metro.app/Contents/MacOS/Metro
Identifier: biz.sagantech.Metro
Version: 7.2.4 (6.0)
Code Type: X86 (Native)
Parent Process: launchd [144]
Responsible: Metro [24139]
User ID: 501
Date/Time: 2014-05-10 15:36:27.743 +0200
OS Version: Mac OS X 10.9.2 (13C1021)
Report Version: 11
Anonymous UUID: B2880AFF-0D24-2F29-C3B9-44284CC9842D
Sleep/Wake UUID: 593780EF-17D7-46B9-9124-6AE1E7117682
Crashed Thread: 20 anim
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x000000000d14c7c1
VM Regions Near 0xd14c7c1:
MALLOC_TINY 000000000ce00000-000000000cf00000 [ 1024K] rw-/rwx SM=PRV
VM_ALLOCATE 000000000d502000-000000000d702000 [ 2048K] r--/r-- SM=SHM
Thread 0:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x9564bd12 __pread + 10
1 com.apple.CoreServices.CarbonCore 0x960e5209 BasicRead(FileRecord*, short, long long, unsigned long long*, void*, unsigned long long*) + 978
2 com.apple.CoreServices.CarbonCore 0x960e4e01 PBReadForkSync + 118
3 com.apple.CoreServices.CarbonCore 0x960e4d76 FSReadFork + 57
4 biz.sagantech.Metro 0x00049403 0x1000 + 295939
5 biz.sagantech.Metro 0x00050359 0x1000 + 324441
6 biz.sagantech.Metro 0x0004e14c 0x1000 + 315724
7 biz.sagantech.Metro 0x00050721 0x1000 + 325409
8 biz.sagantech.Metro 0x00039ab0 0x1000 + 232112
9 biz.sagantech.Metro 0x0001324f 0x1000 + 74319
10 biz.sagantech.Metro 0x000ad7ff 0x1000 + 706559
11 biz.sagantech.Metro 0x000662e7 0x1000 + 414439
12 com.apple.HIToolbox 0x92b53d89 _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
13 com.apple.HIToolbox 0x929a735f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1452
14 com.apple.HIToolbox 0x929a6678 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 386
15 com.apple.HIToolbox 0x929b9821 SendEventToEventTarget + 88
16 com.apple.HIToolbox 0x92b53c2e SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 478
17 com.apple.HIToolbox 0x92a1cf17 SendMenuCommandWithContextAndModifiers + 70
18 com.apple.HIToolbox 0x92a1cec4 SendMenuItemSelectedEvent + 199
19 com.apple.HIToolbox 0x92a1cd92 FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 134
20 com.apple.HIToolbox 0x92ba859d MenuSelectCore(MenuData*, Point, double, unsigned long, OpaqueMenuRef**, unsigned short*) + 722
21 com.apple.HIToolbox 0x92ba920a MenuSelect + 171
22 com.apple.HIToolbox 0x92b57366 HIMenuBar::HandleMouseEvent(OpaqueEventRef*) + 96
23 com.apple.HIToolbox 0x92b57164 HIMenuBar::HandleEvent(OpaqueEventHandlerCallRef*, OpaqueEventRef*) + 60
24 com.apple.HITool
Re: fixing an issue
Postby Jerm » Sun May 11, 2014 2:30 pm
I think his answer is unlikely. Can you give me the steps to repeat this problem? Also your crash log is INCOMPLETE. The crash is on thread 20.
Re: fixing an issue
Postby françois » Sun May 11, 2014 3:35 pm
is it good like that ?
24 com.apple.HIToolbox 0x929a7961 HIObject::EventHook(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 163
25 com.apple.HIToolbox 0x92b53d89 _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
26 com.apple.HIToolbox 0x929a735f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1452
27 com.apple.HIToolbox 0x929a6678 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 386
28 com.apple.HIToolbox 0x929b9821 SendEventToEventTarget + 88
29 com.apple.HIToolbox 0x929da9c8 ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 3116
30 com.apple.HIToolbox 0x929a77a5 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2546
31 com.apple.HIToolbox 0x929a6678 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 386
32 com.apple.HIToolbox 0x929b9821 SendEventToEventTarget + 88
33 com.apple.HIToolbox 0x92b53473 ToolboxEventDispatcher + 82
34 com.apple.HIToolbox 0x92b53333 RunApplicationEventLoop + 240
35 biz.sagantech.Metro 0x000abf26 0x1000 + 700198
36 biz.sagantech.Metro 0x00002952 0x1000 + 6482
37 biz.sagantech.Metro 0x00002879 0x1000 + 6265
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x9564b992 kevent64 + 10
1 libdispatch.dylib 0x95e3c8ad _dispatch_mgr_invoke + 238
2 libdispatch.dylib 0x95e3c546 _dispatch_mgr_thread + 52
Thread 2:: jpegdecompress_MPLoop
0 libsystem_kernel.dylib 0x9564a7ca __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x953fbd8a _pthread_cond_wait + 837
2 libsystem_pthread.dylib 0x953fdfa3 pthread_cond_wait + 48
3 com.apple.QuickTimeComponents.component 0x910526aa 0x90cce000 + 3688106
4 libsystem_pthread.dylib 0x953f95fb _pthread_body + 144
5 libsystem_pthread.dylib 0x953f9485 _pthread_start + 130
6 libsystem_pthread.dylib 0x953fecf2 thread_start + 34
Thread 3:: jpegdecompress_MPLoop
Thread 4:: jpegdecompress_MPLoop
Thread 5:: jpegdecompress_MPLoop
Thread 6:: jpegdecompress_MPLoop
Thread 7:: jpegdecompress_MPLoop
Thread 8:: jpegdecompress_MPLoop
Thread 9:
2 libsystem_pthread.dylib 0x953fc042 pthread_cond_timedwait_relative_np + 47
3 com.apple.CoreServices.CarbonCore 0x9618f88d TSWaitOnConditionTimedRelative + 161
4 com.apple.CoreServices.CarbonCore 0x9618f44a TSWaitOnSemaphoreCommon + 531
5 com.apple.CoreServices.CarbonCore 0x9618f5fd TSWaitOnSemaphoreRelative + 24
6 com.apple.CoreServices.CarbonCore 0x9616fc00 TimerThread + 89
7 libsystem_pthread.dylib 0x953f95fb _pthread_body + 144
8 libsystem_pthread.dylib 0x953f9485 _pthread_start + 130
9 libsystem_pthread.dylib 0x953fecf2 thread_start + 34
Thread 10:
0 libsystem_kernel.dylib 0x95645f7a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x9564516c mach_msg + 68
2 com.apple.audio.midi.CoreMIDI 0x003d11c3 XServerMachPort::ReceiveMessage(int&, void*, int&) + 119
3 com.apple.audio.midi.CoreMIDI 0x003eceef MIDIProcess::RunMIDIInThread() + 151
4 com.apple.audio.midi.CoreMIDI 0x003f55ce MIDIProcess::MIDIInPortThread::Run() + 24
5 com.apple.audio.midi.CoreMIDI 0x003d2543 XThread::RunHelper(void*) + 17
6 com.apple.audio.midi.CoreMIDI 0x003d20d2 CAPThread::Entry(CAPThread*) + 134
Thread 11:
0 libsystem_kernel.dylib 0x95645fce semaphore_timedwait_trap + 10
1 biz.sagantech.Metro 0x00182779 0x1000 + 1578873
2 libsystem_pthread.dylib 0x953f95fb _pthread_body + 144
3 libsystem_pthread.dylib 0x953f9485 _pthread_start + 130
4 libsystem_pthread.dylib 0x953fecf2 thread_start + 34
Thread 12:
Thread 13:: com.apple.audio.IOThread.client
2 com.apple.audio.CoreAudio 0x9012ae9a HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned long, unsigned long, mach_msg_header_t*, bool, unsigned int) + 138
3 com.apple.audio.CoreAudio 0x9012534e HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 68
4 com.apple.audio.CoreAudio 0x90123b27 HALC_ProxyIOContext::IOWorkLoop() + 1111
5 com.apple.audio.CoreAudio 0x901235ff HALC_ProxyIOContext::IOThreadEntry(void*) + 167
6 com.apple.audio.CoreAudio 0x9012df52 ___ZN19HALC_ProxyIOContextC2Emj_block_invoke + 20
7 com.apple.audio.CoreAudio 0x901234fb HALB_IOThread::Entry(void*) + 69
8 libsystem_pthread.dylib 0x953f95fb _pthread_body + 144
9 libsystem_pthread.dylib 0x953f9485 _pthread_start + 130
10 libsystem_pthread.dylib 0x953fecf2 thread_start + 34
Thread 14:: com.apple.audio.IOThread.client
Thread 15:: APP
0 libsystem_kernel.dylib 0x95645fb6 semaphore_wait_trap + 10
1 libdispatch.dylib 0x95e3f0b8 _dispatch_semaphore_wait_slow + 274
2 libdispatch.dylib 0x95e3ef33 dispatch_semaphore_wait + 37
3 ??? 0x0d14c592 0 + 219465106
4 ??? 0x0d15693e 0 + 219507006
5 ??? 0x0cfd72bc 0 + 217936572
6 ??? 0x0d1b7c9e 0 + 219905182
7 ??? 0x0d1b7693 0 + 219903635
Thread 16:: HelpTimer
0 libsystem_kernel.dylib 0x9564ab76 __semwait_signal + 10
1 libsystem_c.dylib 0x949a8fb7 nanosleep$UNIX2003 + 219
2 libsystem_c.dylib 0x949a8e62 usleep$UNIX2003 + 60
3 ??? 0x0d14c7c1 0 + 219465665
4 ??? 0x0d1b5f44 0 + 219897668
5 libsystem_pthread.dylib 0x953f95fb _pthread_body + 144
6 libsystem_pthread.dylib 0x953f9485 _pthread_start + 130
7 libsystem_pthread.dylib 0x953fecf2 thread_start + 34
Thread 17:: editorwindow
4 ??? 0x0d1b75fb 0 + 219903483
Thread 18:: PreviewCounter
4 ??? 0x0cff10d4 0 + 218042580
Thread 19:: timeline
4 ??? 0x0cf5bbf8 0 + 217431032
Thread 20 Crashed:: anim
0 ??? 0x0d14c7c1 0 + 219465665
1 ??? 0x0d1a8f18 0 + 219844376
Thread 21:
0 libsystem_kernel.dylib 0x9564b046 __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x953fadcf _pthread_wqthread + 372
2 libsystem_pthread.dylib 0x953fecce start_wqthread + 30
Thread 22:
Thread 23:
Thread 24:: ContextLooper
Thread 20 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x03c707d4 ecx: 0xb0fcf044 edx: 0xffffffff
edi: 0x03c70200 esi: 0x0d1a8e8e ebp: 0xb0fcef68 esp: 0xb0fcef60
ss: 0x00000023 efl: 0x00010282 eip: 0x0d14c7c1 cs: 0x0000001b
ds: 0x00000023 es: 0x00000023 fs: 0x00000023 gs: 0x0000000f
cr2: 0x0d14c7c1
Logical CPU: 0
Error Code: 0x00000014
Trap Number: 14
Binary Images:
0x1000 - 0x2e2fe2 +biz.sagantech.Metro (7.2.4 - 6.0) <758178C7-858F-E3D8-49E2-D1FE85080526> /Applications/Metro Folder/Metro.app/Contents/MacOS/Metro
0x3c3000 - 0x401ff2 com.apple.audio.midi.CoreMIDI (1.10 - 88) <F8F76923-2681-30C9-B4F4-4BF1D97C2A84> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x425000 - 0x44ffff com.apple.audio.CoreAudioKit (1.6.6 - 1.6.6) <30C0DC77-EDFD-36B3-AB1C-A520B472A869> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
0x462000 - 0x478ff8 libexpat.1.dylib (12) <B0AC9020-01C4-368F-98D6-7FFC067A1B04> /usr/lib/libexpat.1.dylib
0x4078000 - 0x4080ff7 libCGCMS.A.dylib (599.21.1) <5444E100-B3C8-338B-A691-DBB5717E0E48> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGCMS.A.dylib
0x408a000 - 0x40b2ff7 libRIP.A.dylib (599.21.1) <9F0E2AB0-09F5-3B2D-8008-091A86114A3D> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x40c5000 - 0x40c8ffa libCGXType.A.dylib (599.21.1) <010A4DBA-F793-3D1A-A212-3FE8B80CA6DA> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x471f000 - 0x4725fff +biz.sagantech.SaganTech-Metronome (1.0.5 - 1.0.5) <829BF197-BD3B-97EB-1738-1CF7D5BE8EC6> /Applications/Metro Folder/*/SaganTech-Metronome
0x4778000 - 0x4778ffd +cl_kernels (???) <F50B791C-E79D-42EF-93B3-ADF77FE6544B> cl_kernels
0x4799000 - 0x47a0ff8 com.apple.AppleGVAHW.component (1.2 - 1) <03305334-A3AE-3F51-A076-BBA13E0916F9> /System/Library/QuickTime/AppleGVAHW.component/Contents/MacOS/AppleGVAHW
0x47a7000 - 0x47dfff7 com.apple.QuickTimeFireWireDV.component (7.7.3 - 2826.17) <CEDCAC9B-679F-36E0-BAB9-6A387857710C> /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
0x47eb000 - 0x47effff com.apple.AppleMPEG2Codec (1.0.2 - 220.1) <017135BD-3E54-30EC-9489-6ACADA56D51F> /Library/QuickTime/AppleMPEG2Codec.component/Contents/MacOS/AppleMPEG2Codec
0xa1e9000 - 0xa2c5fd7 com.apple.AppleProResDecoder (3.0.4 - 6305.11) <50F80B48-00A2-37F0-BE25-CD0258A474BE> /System/Library/QuickTime/AppleProResDecoder.component/Contents/MacOS/AppleProResDecoder
0xa2d0000 - 0xa314ff7 com.apple.AppleVAH264HW.component (3.0 - 3.0) <593296F6-F8CD-33D4-AE26-88E46A71F14C> /System/Library/QuickTime/AppleVAH264HW.component/Contents/MacOS/AppleVAH264HW
0xa3d7000 - 0xa48cfff com.apple.AppleGVAFramework (7.1.10 - 7.1.10) <7F8C0D33-0E54-3A6E-B677-A2A10B5E7D86> /System/Library/PrivateFrameworks/AppleGVA.framework/Versions/A/AppleGVA
0xa49c000 - 0xa4ceff7 com.apple.AppleIntermediateCodec (2.0.2 - 6305.11) <397782CB-2454-37D5-A10C-B992A4E1D439> /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
0xa4d6000 - 0xa4efff2 com.apple.applepixletvideo (1.2.31 - 1.2d31) <3691A649-1F8F-3C0A-89F4-5C2DD4E38EEC> /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
0xa5cb000 - 0xa5f0ff9 com.apple.framework.familycontrols (4.1 - 410) <A33A97EE-C735-38BA-9B49-5D78DAA3DEDA> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0xa605000 - 0xa610ffa com.apple.CommerceCore (1.0 - 42) <E59717F2-6770-3DBC-8510-F7AA61E60F57> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0xa7f4000 - 0xa7f8fff com.apple.CommonCocoaPanels (4.0 - 16) <E7B9104D-3811-3ED0-B516-67FB00A3DA63> /System/Library/CoreServices/CommonCocoaPanels.bundle/Contents/MacOS/CommonCocoaPanels
0xacdd000 - 0xacefffd libTraditionalChineseConverter.dylib (61) <EFC81138-0455-321B-A93A-F4E9C4A3EB31> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
0xacf3000 - 0xad01fff libSimplifiedChineseConverter.dylib (61) <6E42E198-9C8D-3F0F-9660-6D9975C2461E> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
0xb606000 - 0xb607ff8 ATSHI.dylib (363.3) <62AF40CE-1110-31D5-931C-2B2AFB5C1A18> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
0xb60c000 - 0xb610ffd libFontRegistryUI.dylib (127) <C207DFF5-0C48-3831-B9F1-2363D9A7A365> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resources/libFontRegistryUI.dylib
0xb618000 - 0xb61cffd com.apple.audio.AppleHDAHALPlugIn (2.6.0 - 2.6.0f1) <D5FE0F6F-95E3-3F9D-A6AF-D721CBD801AC> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0xb622000 - 0xb64cff7 +com.grame.JackRouter (JackRouter - 0.9.6) <6EBFF75F-6232-E783-3DB9-2ED76BD23FE1> /Library/Audio/Plug-Ins/HAL/JackRouter.plugin/Contents/MacOS/JackRouter
0xb662000 - 0xb690fff Jackmp (1) <6B37811A-1CA7-32D0-192B-A3BFB105F9E3> /System/Library/Frameworks/Jackmp.framework/Versions/A/Jackmp
0xb99c000 - 0xbb9cffd com.apple.audio.units.Components (1.10 - 1.10) <5BF69E31-FBA9-3B6D-8CC1-6D8C851804A5> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0xbcd4000 - 0xbcdaffc libCGXCoreImage.A.dylib (599.21.1) <DFE21701-5409-3F1C-BDFE-DB6B972E8EF8> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
0xc900000 - 0xc9ebff7 unorm8_bgra.dylib (2.3.58) <2DC35A3D-E1D6-3378-953F-D5EADE3400D2> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
0xd702000 - 0xd7b2fff ColorSyncDeprecated.dylib (426) <F54DBFF3-3165-3D15-8AE4-37B603502A5F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x8fe68000 - 0x8fe9a417 dyld (239.4) <2E655535-479B-3E48-ADD3-6278819CA38A> /usr/lib/dyld
0x90008000 - 0x90009fff libSystem.B.dylib (1197.1.1) <C58F0CC9-C1FD-3024-9358-D3359A6BBCAD> /usr/lib/libSystem.B.dylib
0x90090000 - 0x90110ff7 com.apple.CoreServices.OSServices (600.4 - 600.4) <1227DF22-E2DA-3764-A1CA-10CC0CEBE377> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x90111000 - 0x90111fff com.apple.ApplicationServices (48 - 48) <7967F6FA-2984-3CC3-AD9A-7B9AEC562A2A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x90112000 - 0x90167ff7 com.apple.audio.CoreAudio (4.2.0 - 4.2.0) <0F1C111F-1E64-33BB-A69F-14643B3037D5> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x90168000 - 0x90171fff com.apple.AppleSRP (5.0 - 1) <6B946F4B-7DC4-3E82-BF2C-BE0930E3CF47> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x90172000 - 0x901a8fff com.apple.IconServices (25 - 25.17) <A4B5242B-765E-3D58-B066-BBEDB5947AAD> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x901a9000 - 0x901daffb com.apple.GSS (4.0 - 2.0) <E935DA55-0DBE-3D5A-9DFB-FBBFDB457F33> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x901db000 - 0x902e3ff7 com.apple.QuickTimeImporters.component (7.7.3 - 2826.17) <9B883A02-F284-3331-B4C0-CB1EF043BB06> /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
0x902e4000 - 0x902e5fff libDiagnosticMessagesClient.dylib (100) <B936B1D4-90BB-395D-8EA9-E1237608E7D0> /usr/lib/libDiagnosticMessagesClient.dylib
0x902e6000 - 0x90385ff7 libCoreStorage.dylib (380) <55467C87-E1A3-3057-B428-9BCEFD39E36D> /usr/lib/libCoreStorage.dylib
0x903a0000 - 0x903d0ff7 com.apple.CoreServicesInternal (184.9 - 184.9) <999FEDEC-7657-3F32-A9AE-F29E0BE0AAF5> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x903d1000 - 0x9040fff7 com.apple.NavigationServices (3.8 - 215) <A093AAF0-248E-313E-BA82-01F69E269895> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x90418000 - 0x90447ff7 com.apple.framework.SystemAdministration (1.0 - 1.0) <1BD6205B-7C66-3B7B-AC8C-11BE34F7CF6B> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x90448000 - 0x90473ff7 libpcap.A.dylib (42) <66FBEAD3-FE91-3A89-8706-FB95229068AC> /usr/lib/libpcap.A.dylib
0x904a5000 - 0x904b4fff libGL.dylib (9.6) <58C42A46-27D0-3228-B3C1-EC3923D49BAD> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x90c76000 - 0x90c77fff libremovefile.dylib (33) <ED35EA79-EB06-3B84-A6D4-B1A9D6B8648D> /usr/lib/system/libremovefile.dylib
0x90cce000 - 0x91628fe3 com.apple.QuickTimeComponents.component (7.7.3 - 2826.17) <AEF44853-2A48-3797-91AA-2510B523E052> /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x91629000 - 0x9167dfff com.apple.AppleVAFramework (5.0.27 - 5.0.27) <95A1E1CF-FC3E-3203-8683-34823CD70B6B> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x9167f000 - 0x91791ffc libsqlite3.dylib (158) <B3DB0FED-FE4C-314D-8329-CF7708C8AAF4> /usr/lib/libsqlite3.dylib
0x91794000 - 0x91794ffd com.apple.audio.units.AudioUnit (1.10 - 1.10) <85316395-817E-342D-8F41-88838EC6FB63> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x917a1000 - 0x917aafff com.apple.speech.recognition.framework (4.2.4 - 4.2.4) <CF8E5706-F744-3139-8A51-D52BF055D19F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x917ab000 - 0x91896ff4 com.apple.DiskImagesFramework (10.9 - 371.1) <FC13BD5A-0FB7-35D5-A8DF-0510CFA996FE> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x91897000 - 0x91b30ff3 com.apple.RawCamera.bundle (5.04 - 736) <B9CA1B5A-6FA9-3140-BE9F-27A6F3E620B9> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x91b31000 - 0x91b31fff libkeymgr.dylib (28) <1B097DEA-011E-3B1C-86D5-6C7FAD5C765A> /usr/lib/system/libkeymgr.dylib
0x91b32000 - 0x91b5cfff libxslt.1.dylib (13) <249D54AB-1D82-38FE-ABEC-0D575450C73B> /usr/lib/libxslt.1.dylib
0x91bf8000 - 0x91bfaff2 com.apple.EFILogin (2.0 - 2) <BC558029-74C0-3A69-B376-8F4CBF8C338F> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x91d6e000 - 0x91d6fffa libsystem_sandbox.dylib (278.11) <E8BE1DF7-2F3D-3202-B807-A85C99220AB6> /usr/lib/system/libsystem_sandbox.dylib
0x91d70000 - 0x91d7cff7 com.apple.OpenDirectory (10.9 - 173.90.1) <B7440CD7-04F8-3558-B5AA-FD48381B14DE> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x91d7d000 - 0x91d9affb libresolv.9.dylib (54) <3EC12A7F-6BA1-3976-9F1F-6A4B76303028> /usr/lib/libresolv.9.dylib
0x91d9b000 - 0x91dccffa libsystem_m.dylib (3047.16) <28E614E8-7802-3E84-960A-AD4721EF10F7> /usr/lib/system/libsystem_m.dylib
0x91dcd000 - 0x91de4ff4 com.apple.CoreMediaAuthoring (2.2 - 947) <BF917B77-0935-3F56-A2B9-E62A58A713B8> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x91de5000 - 0x91e36ffb com.apple.CoreMedia (1.0 - 1273.49) <26F891C5-DF9F-3A2C-995A-827595F03CF2> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x91ee3000 - 0x91ee8ff6 libcompiler_rt.dylib (35) <9924DF2E-D80B-3A21-920D-544A4597203F> /usr/lib/system/libcompiler_rt.dylib
0x91ee9000 - 0x91ef7fff libxar.1.dylib (202) <B73748D4-F830-3C71-98B3-7A3ABF5136FD> /usr/lib/libxar.1.dylib
0x91ef8000 - 0x9232cff7 com.apple.vision.FaceCore (3.0.0 - 3.0.0) <5B12F3E9-84F6-3183-B85D-FD19EF800ADB> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x9232d000 - 0x9243dfed com.apple.MediaControlSender (2.0 - 200.34.4) <48A88743-4EB7-364B-968F-43C17FFCEB97> /System/Library/PrivateFrameworks/MediaControlSender.framework/Versions/A/MediaControlSender
0x9243e000 - 0x92442fff libheimdal-asn1.dylib (323.92.1) <DD8BAEED-28AC-389E-9DC4-E32DA60CB05A> /usr/lib/libheimdal-asn1.dylib
0x924ef000 - 0x924f1ffb libRadiance.dylib (1042.2) <3AE35DFA-AAF0-37C0-8544-1B19E9B5FCE1> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x924f2000 - 0x924f5ff7 libdyld.dylib (239.4) <F4604F64-945B-3871-8F26-E9C55488BC27> /usr/lib/system/libdyld.dylib
0x924f6000 - 0x924f6fff com.apple.Cocoa (6.8 - 20) <407DC9E6-BBCE-3D34-9BBB-00C90584FFDF> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x924f7000 - 0x9299efe7 com.apple.CoreAUC (6.22.08 - 6.22.08) <3F9E2986-8FF9-3339-A0C8-DC1186C4A5EC> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x9299f000 - 0x92d14ff9 com.apple.HIToolbox (2.1 - 697.4) <8CB677B7-43FC-3534-A685-5A5445C95F7D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x92d15000 - 0x92d3cfff com.apple.CoreVideo (1.8 - 117.2) <A53FDD90-F200-3F7C-8A8E-5DE36D3DFBB0> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x92d3d000 - 0x92eb0ffb com.apple.audio.toolbox.AudioToolbox (1.10 - 1.10) <AAF3AB26-3BAD-3E5F-8192-9805B7AA1CB1> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x92eb1000 - 0x92eb1fff com.apple.Carbon (154 - 157) <6E680560-FD53-3C00-BDF7-7AFA28747DC8> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92eb6000 - 0x92ec0ff7 com.apple.DirectoryService.Framework (10.9 - 173.90.1) <6CD2D996-2972-30A3-B4AD-BB1B816EFDCC> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x92ec1000 - 0x92ec1fff com.apple.CoreServices (59 - 59) <06747539-5035-3307-8645-9BC4E7F89023> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x93430000 - 0x93472fff libGLU.dylib (9.6) <6A7E248D-3936-3B0D-9BF2-E4F0D2FE5306> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x93473000 - 0x9347eff6 com.apple.NetAuth (5.0 - 5.0) <3B2E9615-EE12-38FC-BDCF-09529FF9464B> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x9347f000 - 0x9358cfff com.apple.ImageIO.framework (3.3.0 - 1042) <19F7AA81-5144-37F3-AAAC-4D200C7417D8> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x935bf000 - 0x937c1fff com.apple.CoreFoundation (6.9 - 855.16) <6283B27F-3C46-365F-932C-1A7102D8A3CF> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x937c2000 - 0x93be7fe3 com.apple.VideoToolbox (1.0 - 1273.49) <A581EEA0-25DF-386C-904D-26E51C3ED640> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x93be8000 - 0x93cc3ff7 com.apple.LaunchServices (572.26 - 572.26) <5915A9AC-7928-30B1-9329-94048ADE81D9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x93cc4000 - 0x93cefff5 com.apple.ChunkingLibrary (2.0 - 155.1) <50BBBBF8-F30B-39EA-A512-11A47F429F2C> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x93cf0000 - 0x940e8fff com.apple.CoreGraphics (1.600.0 - 599.21.1) <A872AE6C-F92C-3EE9-B79F-E98EE33B1B1B> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x940e9000 - 0x940edff7 libmacho.dylib (845) <D8E93E59-1F80-3413-B9CF-78B848F6E873> /usr/lib/system/libmacho.dylib
0x940f7000 - 0x940fffff libcopyfile.dylib (103) <1B1484BD-08B6-3BA9-94CA-A7C24B610EB3> /usr/lib/system/libcopyfile.dylib
0x94100000 - 0x9437cfe7 com.apple.QuickTime (7.7.3 - 2826.17) <E8F7EFCE-41FD-3E30-AAA5-5C232317E9D2> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x9437d000 - 0x9438afff com.apple.Librarian (1.2 - 1) <F85681E3-3398-327B-829B-1D8078C38C22> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Librarian
0x9438b000 - 0x943c3fff com.apple.LDAPFramework (2.4.28 - 194.5) <4399D209-B119-3ACC-97AF-F2E14DD207CB> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x943c4000 - 0x943e8ff7 libxpc.dylib (300.90.2) <5ACBBE2C-74EB-3E88-BCBF-C573095318A5> /usr/lib/system/libxpc.dylib
0x943f2000 - 0x94424ffb com.apple.CoreAVCHD (5.7.0 - 5700.4.3) <30CF0E7B-3511-318F-AC31-06C29EDC111E> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x94425000 - 0x944d9ff7 com.apple.QuickTimeMPEG4.component (7.7.3 - 2826.17) <B229F63E-BC40-364E-BB4B-A0E550976900> /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
0x9457f000 - 0x9466bff7 libxml2.2.dylib (26) <32040145-6FD6-3AD2-B98B-39F73BF9AC47> /usr/lib/libxml2.2.dylib
0x948ec000 - 0x948efffb libutil.dylib (34) <B496031E-E763-3DEB-84D2-85C0F3DF2012> /usr/lib/libutil.dylib
0x948f0000 - 0x94903fff com.apple.ImageCapture (9.0 - 9.0) <63D5C96F-1893-3F35-ADFB-EE451AFD87E6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x94904000 - 0x94928fff libJPEG.dylib (1042.2) <72940135-AAA7-3F55-A2E7-CECDDBD592BE> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x94929000 - 0x9492bffe libCVMSPluginSupport.dylib (9.6) <DF20981B-DAD0-3125-8089-C96CB3226888> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x9492d000 - 0x949bfff9 libsystem_c.dylib (997.90.3) <80D21D3D-1031-314C-B1F0-0B35B977CEFB> /usr/lib/system/libsystem_c.dylib
0x949c0000 - 0x949c5ff7 com.apple.print.framework.Print (9.0 - 260) <A6C465F6-C5D1-353A-9F33-19B9CEDBBC2A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x949c6000 - 0x94a02ff4 com.apple.RemoteViewServices (2.0 - 94) <BEEE6ADF-7DA3-3D68-BCB0-9863BE1A1F46> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x94a03000 - 0x94a6efff com.apple.Heimdal (4.0 - 2.0) <3DEF31F9-7F59-3DEF-9DC8-7DDD23CA816F> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x94a6f000 - 0x94a72ff7 com.apple.help (1.3.3 - 46) <AB6292FA-D3BC-3D56-B3A5-2BE630A503E7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x94a73000 - 0x94aa8ffd libssl.0.9.8.dylib (50) <F3BEA2DF-DB84-37F0-B4C7-97C0A4DF19C9> /usr/lib/libssl.0.9.8.dylib
0x94aa9000 - 0x94b55ffb libvMisc.dylib (423.32) <43873EFF-FB43-3301-BEE8-F2C3A046D7A6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x94b56000 - 0x94beeff7 com.apple.Metadata (10.7.0 - 800.23) <6590358F-9677-3257-8780-FF0462852EDD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x94bef000 - 0x94bf0fff libsystem_blocks.dylib (63) <2AC67D5E-ECD4-3644-A53C-9684F9B7AA33> /usr/lib/system/libsystem_blocks.dylib
0x94bf8000 - 0x94bfcffc libpam.2.dylib (20) <50623D44-795F-3E28-AA85-23E0E7E2AE0E> /usr/lib/libpam.2.dylib
0x94c5f000 - 0x94cb8ffe libTIFF.dylib (1042.2) <5589DBDB-4324-3DAE-8530-0B8273D3F21C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x94cb9000 - 0x94cc5ffc libbz2.1.0.dylib (29) <3CEF1E92-BA42-3F8A-8E8D-9E1F7658E5C7> /usr/lib/libbz2.1.0.dylib
0x94cc6000 - 0x94d96fef libvDSP.dylib (423.32) <E2FA7230-A001-3F6B-9ACF-6998C51AD7DC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x94d97000 - 0x94df8ff7 com.apple.Symbolication (1.4 - 129) <E5948C08-6ADF-3D86-9134-6AE49CF1DA0F> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x95132000 - 0x952da4af libobjc.A.dylib (551.1) <31CBE178-E972-30D1-ADC6-4B8345CAE326> /usr/lib/libobjc.A.dylib
0x952db000 - 0x952e9ff3 com.apple.opengl (9.6.0 - 9.6.0) <63941A8D-AACC-3C71-BE8C-4DAA913A1439> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x952ea000 - 0x952f8ff7 libz.1.dylib (53) <858B4D9F-D87E-3D81-B07A-DF9632BD185F> /usr/lib/libz.1.dylib
0x952f9000 - 0x953f7fff libJP2.dylib (1042.2) <24326770-81EE-3FA8-AAE1-A1E0CA12184B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x953f8000 - 0x953ffffb libsystem_pthread.dylib (53.1.4) <8B1B7B84-1B5D-32A8-AC0D-1E689E5C8A4C> /usr/lib/system/libsystem_pthread.dylib
0x95400000 - 0x954c7ff7 com.apple.DiscRecording (8.0 - 8000.4.6) <84A7EC09-3BBD-3E04-A88C-6D3B724448FF> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x954c8000 - 0x954ccffa libcache.dylib (62) <9730D7F2-D226-3F30-8D26-BF598CB781F6> /usr/lib/system/libcache.dylib
0x954df000 - 0x9553dffd com.apple.AE (665.5 - 665.5) <54F2F247-160C-3A22-A6E3-5D49655A67AB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x9553e000 - 0x95632fff libFontParser.dylib (111.1) <D8F9B2A4-41A6-3407-8D80-13A841F97BE5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x95633000 - 0x95650ff4 libsystem_kernel.dylib (2422.92.1) <20AE426A-E386-3119-A740-14E13CBD0596> /usr/lib/system/libsystem_kernel.dylib
0x95922000 - 0x9592affe libGFXShared.dylib (9.6) <D75FE2D7-0CF9-351E-9EE3-893F2B2114BE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x9592b000 - 0x95ad7fff com.apple.QuartzCore (1.8 - 332.3) <00167BF7-E3C4-3AA7-8DA0-466BD4175350> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x95ad8000 - 0x95af3ff6 libPng.dylib (1042.2) <85BC9AE9-7924-34B8-842F-B11BBAD64D22> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x95bcf000 - 0x95bd1ffe com.apple.QuickTimeH264.component (7.7.3 - 2826.17) <A02A7AE1-0DAD-3A98-9C72-889510D59AB2> /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
0x95bd5000 - 0x95bdeffc com.apple.CommonAuth (4.0 - 2.0) <99219CEB-D340-3E1F-9C04-FD0FA700BD67> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x95bdf000 - 0x95c45ffb com.apple.CoreUtils (2.0 - 200.34.4) <F14AAB3C-1C8A-37D7-85BE-76646F9F6098> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x95cab000 - 0x95cadfff com.apple.securityhi (9.0 - 55005) <51765C73-80D1-33E3-9589-3E88380CE007> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x95cae000 - 0x95cb7fff com.apple.DiskArbitration (2.6 - 2.6) <92F7575A-AA20-34D9-BB26-2CC8C3CCAFEB> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x95cb8000 - 0x95d0eff6 com.apple.ScalableUserInterface (1.0 - 1) <2C81641B-FA30-32FF-8B3E-3CB9BF53B2D9> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
0x95d0f000 - 0x95d16ffe com.apple.agl (3.2.3 - AGL-3.2.3) <E26A1D2C-596E-31F0-8E70-FC381874F8DA> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x95e2f000 - 0x95e38fff com.apple.audio.SoundManager (4.1 - 4.1) <68B7CEB7-AF09-3E24-8548-6ABF065B5186> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x95e39000 - 0x95e51ffd libdispatch.dylib (339.90.1) <871AC354-D1B6-3475-889E-AF594448CF43> /usr/lib/system/libdispatch.dylib
0x95e52000 - 0x95e8fffb libGLImage.dylib (9.6) <EAC640A8-CD71-3AB2-9918-21CACCBCCB0D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x95e90000 - 0x95e94ffe libCoreVMClient.dylib (58.1) <0EB8FFD7-AFED-3A63-810E-29629831D43D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x95eb8000 - 0x95ec2fff com.apple.bsd.ServiceManagement (2.0 - 2.0) <B84F3916-236A-347B-9C1F-3DE571496737> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x95f2a000 - 0x95f91ffc com.apple.framework.CoreWLAN (4.3.2 - 432.47) <A02FAF3F-A8F4-3293-9321-AED904B5F069> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x95f92000 - 0x95ffbffa com.apple.datadetectorscore (5.0 - 354.3) <566882DE-B726-331E-BA89-ACBB3D5BEEC4> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x95ffc000 - 0x95ffdfff liblangid.dylib (117) <F18F76C6-7E4B-34AD-AE81-C1C031BF2F7D> /usr/lib/liblangid.dylib
0x95ffe000 - 0x96053fff libc++.1.dylib (120) <10C0A136-64F9-3CC2-9420-013247032120> /usr/lib/libc++.1.dylib
0x96054000 - 0x9606cff7 libsystem_malloc.dylib (23.10.1) <CB52555E-0F5B-31E3-A42A-FD4F930E2192> /usr/lib/system/libsystem_malloc.dylib
0x9606d000 - 0x9607ffff libsystem_asl.dylib (217.1.4) <51EB17C9-9F5B-39F3-B6CD-8EF238B05B89> /usr/lib/system/libsystem_asl.dylib
0x96080000 - 0x9609cfff libCRFSuite.dylib (34) <FFF76EBA-DF35-3A5F-857F-3F4B1C9F4C77> /usr/lib/libCRFSuite.dylib
0x9609d000 - 0x9609ffff libquarantine.dylib (71) <EE3B510E-1AEC-3171-8A1A-D6A5A42CF35C> /usr/lib/system/libquarantine.dylib
0x960a0000 - 0x960abfff com.apple.CrashReporterSupport (10.9 - 538) <7A5FF845-433C-33E3-99B5-F6AA5B825734> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x960ac000 - 0x960b7fff libcsfde.dylib (380) <C9E61AFB-1A9D-324B-9827-06B182CDD7B0> /usr/lib/libcsfde.dylib
0x960b8000 - 0x960beffb libunwind.dylib (35.3) <099D1A6F-A1F0-3D05-BF1C-0A7BB32D39C2> /usr/lib/system/libunwind.dylib
0x960bf000 - 0x960cfff7 libsasl2.2.dylib (170) <CA1C07F6-8E17-315E-AE49-AB696DDE6707> /usr/lib/libsasl2.2.dylib
0x960d0000 - 0x963d1ffb com.apple.CoreServices.CarbonCore (1077.17 - 1077.17) <02C72D54-E3D3-32B0-A081-E85A7038489D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x963d2000 - 0x9641eff7 libcups.2.dylib (372.2) <ED7CEA7C-9FD7-34E0-B960-268BD6AFA056> /usr/lib/libcups.2.dylib
0x9641f000 - 0x9648dffb libType1Scaler.dylib (112.1) <8DF02425-1C46-3B86-9E02-71F8D13FF3B1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
0x9648e000 - 0x96503ffb com.apple.framework.IOKit (2.0.1 - 907.90.2) <AFF50D8E-7D1D-38B9-A77E-DF0C0C4C97E0> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x96806000 - 0x96813ff7 com.apple.AppleFSCompression (56 - 1.0) <0C44B3E4-C4A7-3A65-9C1A-334CA3E35BDB> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x96814000 - 0x968a5fff com.apple.ColorSync (4.9.0 - 4.9.0) <8366AE10-0396-3100-B87A-A176E8ECE7B6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x968a6000 - 0x96bd1ffe com.apple.Foundation (6.9 - 1056.13) <C33A8984-7E97-36BE-B842-EE4FE35F53EA> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x96bd2000 - 0x96bfbff5 com.apple.shortcut (2.6 - 2.6) <F9F32E6F-E641-36D0-B648-058D5E146D38> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x96bfc000 - 0x96c04fff liblaunch.dylib (842.90.1) <B259692D-D60B-3BCE-9E03-32F457CB5046> /usr/lib/system/liblaunch.dylib
0x96c05000 - 0x96c06ffd libunc.dylib (28) <22A126A1-DCFB-3BE5-A66B-C973F0A5D839> /usr/lib/system/libunc.dylib
0x96c07000 - 0x96c26ff9 com.apple.framework.Apple80211 (9.3.1 - 931.58) <120A58B6-9DC7-3001-9735-C08661A3ECC0> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x96c27000 - 0x96c52ff7 libsystem_network.dylib (241.3) <71EBA489-386D-3608-ADE6-CB50EBD1AB1B> /usr/lib/system/libsystem_network.dylib
0x96c53000 - 0x96e19ffb libicucore.A.dylib (511.31) <9C25D145-E785-357B-9833-1980A1A738C9> /usr/lib/libicucore.A.dylib
0x96e1a000 - 0x96e1efff com.apple.CommonPanels (1.2.6 - 96) <E7CA63C6-CEE9-3F0A-93A7-C12C653FFB80> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x96e45000 - 0x96e60ff5 com.apple.openscripting (1.4 - 157) <5C161A52-8D2F-3D56-A988-05727BED7A59> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x96ec0000 - 0x96ec0fff com.apple.Accelerate.vecLib (3.9 - vecLib 3.9) <DDAC0B59-F886-3AB1-98E8-C71FFF161CD4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x96ec1000 - 0x96f11ff7 libcorecrypto.dylib (161.1) <135FD99E-2211-3DF4-825C-C9F816107F0C> /usr/lib/system/libcorecrypto.dylib
0x96f12000 - 0x96f2cff7 com.apple.GenerationalStorage (2.0 - 160.2) <8755F7F1-2402-387C-A32A-2270E7D680C8> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x96f2d000 - 0x97217fd2 com.apple.vImage (7.0 - 7.0) <256972F0-3DBC-3CE1-9EE8-B48243868729> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x97218000 - 0x9721afff libsystem_configuration.dylib (596.13) <57095AFE-3FF1-3F42-A43E-ED679409B827> /usr/lib/system/libsystem_configuration.dylib
0x9721b000 - 0x9721effe com.apple.LoginUICore (3.0 - 3.0) <6FE961A4-3C17-3004-B50B-FD78FDC28350> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0x9721f000 - 0x97226ff2 com.apple.NetFS (6.0 - 4.0) <915AA303-C02B-3B0C-8208-D8AAA4350DB4> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x97227000 - 0x9722dff7 com.apple.AOSNotification (1.7.0 - 760.3) <63F7E7F8-6FA3-38D3-9907-CDF360CA9354> /System/Library/PrivateFrameworks/AOSNotification.framework/Versions/A/AOSNotification
0x9726e000 - 0x972b6fff com.apple.PerformanceAnalysis (1.47 - 47) <16935C0F-7F9F-316E-9D46-11973DE0904A> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x972b7000 - 0x972dffff libsystem_info.dylib (449.1.3) <BB68E8CC-422F-3121-8C86-D0F766FB696D> /usr/lib/system/libsystem_info.dylib
0x972e0000 - 0x9730eff3 com.apple.DebugSymbols (106 - 106) <FC70F4C9-B2A6-352F-9563-6C085E9DDDB8> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x9730f000 - 0x97333ff3 libc++abi.dylib (49.1) <43A04ACF-97A5-35ED-B454-6B5C0CF0F99D> /usr/lib/libc++abi.dylib
0x97334000 - 0x9733cfff libsystem_dnssd.dylib (522.90.2) <A73663C9-CE65-3FF3-B41B-686728BBFB00> /usr/lib/system/libsystem_dnssd.dylib
0x9733d000 - 0x973d9fff com.apple.QD (3.50 - 298) <F73FD4D4-17A4-37D6-AC06-7CA5A8BA1212> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x973ee000 - 0x97652ff7 com.apple.CoreData (107 - 481.01) <85EE4DFF-3A61-3D3B-A818-524F0A427A4D> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x98714000 - 0x98722ff7 com.apple.Sharing (132.2 - 132.2) <87DBFC7A-9689-3B8E-AD16-5A9DFF9DE625> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x98723000 - 0x98806ff7 libcrypto.0.9.8.dylib (50) <B367D3A3-FC1F-326C-92EC-CAD81666524D> /usr/lib/libcrypto.0.9.8.dylib
0x9895b000 - 0x98993ff7 com.apple.MediaKit (15 - 709) <82E0F8C0-313C-379C-9994-4D21587D0C0C> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x98994000 - 0x9899eff7 com.apple.speech.synthesis.framework (4.7.1 - 4.7.1) <C4CC55E5-6CC4-307E-9499-AF89A6463AF4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x9899f000 - 0x989dfff7 com.apple.bom (14.0 - 193.1) <FFF1C8E5-41FF-357B-8681-69B21DCED2E4> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x989e0000 - 0x98a49fff com.apple.SystemConfiguration (1.13 - 1.13) <144317BE-7AE5-3B8D-90CD-62DCDE9399E7> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x98a4a000 - 0x98a4bffc com.apple.TrustEvaluationAgent (2.0 - 25) <064B485D-56E0-3DD7-BBE2-E08A5BFFF8B3> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x98a4c000 - 0x98ad5fff com.apple.CoreSymbolication (3.0 - 141) <178DDF5C-B6DA-39BD-84F5-FD3FA7E93BF8> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x98ad6000 - 0x98ad6fff libodfde.dylib (20) <98FC02AE-C596-3ED5-80D1-C502FF6115ED> /usr/lib/libodfde.dylib
0x98ad7000 - 0x98b14ff7 libauto.dylib (185.5) <CD008E66-4A0C-35F5-8D72-80D76A716A03> /usr/lib/libauto.dylib
0x98b6b000 - 0x98c2eff1 com.apple.CoreText (352.0 - 367.19) <14FD889D-4D6D-3D53-B28E-2E23975B3C9D> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x98c2f000 - 0x98c2ffff com.apple.Accelerate (1.9 - Accelerate 1.9) <C85070A7-D942-3CFA-981F-5864480788C8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x98c30000 - 0x98c76ff7 libcurl.4.dylib (78.92.2) <FB33F24B-9A7B-3D79-8AE8-DFA9CB86597B> /usr/lib/libcurl.4.dylib
0x98c77000 - 0x98dcdff0 libBLAS.dylib (1094.5) <74310C2F-4FDB-3995-A01A-5AFB83010A43> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x98dd3000 - 0x98e26fff com.apple.htmlrendering (77 - 1.1.4) <408FA30F-4FE9-3162-9FFD-677E8569C1EA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x98e27000 - 0x98e32ffb libcommonCrypto.dylib (60049) <F8E60C43-22EE-3E0B-9546-3365056901F1> /usr/lib/system/libcommonCrypto.dylib
0x98e33000 - 0x98e38ff3 libsystem_platform.dylib (24.90.1) <0613F163-9A7A-3908-B30B-AC1627503933> /usr/lib/system/libsystem_platform.dylib
0x98e8d000 - 0x98f7dffb libiconv.2.dylib (41) <848FEBA7-2E3E-3ECB-BD59-007F32468787> /usr/lib/libiconv.2.dylib
0x98f7e000 - 0x992ecfff com.apple.MediaToolbox (1.0 - 1273.49) <236C702F-BC87-3255-A8B3-C7B2C597DBCA> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x992ee000 - 0x99361fff com.apple.SearchKit (1.4.0 - 1.4.0) <6F607AB6-7553-37BA-BEC5-98FD7C27FAD7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x99c89000 - 0x99cd8ff1 com.apple.HIServices (1.22 - 467.2) <F47161AA-E19F-3357-862F-5B4C8DA97975> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x99cd9000 - 0x9a8f7ff3 com.apple.AppKit (6.9 - 1265.19) <07125263-9E97-3A47-BBD3-6FB462910565> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x9a8f8000 - 0x9a8f8ffd libOpenScriptingUtil.dylib (157) <4D06E8ED-D312-34EA-A448-DFF45ADC3CE5> /usr/lib/libOpenScriptingUtil.dylib
0x9a8f9000 - 0x9a8fdffc com.apple.IOSurface (91 - 91) <DECEEB72-3C7E-3C21-9237-E5AD293F8B09> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x9a8fe000 - 0x9a9ccff7 com.apple.backup.framework (1.5.2 - 1.5.2) <BE2F37D3-F610-30EE-B106-44B5DAE35603> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x9a9cd000 - 0x9a9d6fff libsystem_notify.dylib (121) <623269F5-1518-3035-A916-8AF83C972154> /usr/lib/system/libsystem_notify.dylib
0x9a9d7000 - 0x9a9dcfff com.apple.MediaAccessibility (1.0 - 43) <1CC2B661-146A-3FF3-B843-508F611F7B4B> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x9a9dd000 - 0x9aa0fff7 libTrueTypeScaler.dylib (111.1) <A568EE4C-1588-3F8B-8640-F02CEFC5AF09> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x9aa1b000 - 0x9aa2bff5 com.apple.LangAnalysis (1.7.0 - 1.7.0) <71DE7754-0A47-3F35-B1BF-B1FE7E1311E0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x9aa2c000 - 0x9ab8effb com.apple.CFNetwork (673.4 - 673.4) <3B6BDE2F-BFA3-3B7E-BC53-7B6B75EB12D3> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x9ab8f000 - 0x9aba1fff libbsm.0.dylib (33) <1BE92DB5-0D2F-3BB5-BCC6-8A71EF2A3450> /usr/lib/libbsm.0.dylib
0x9aba2000 - 0x9abaeffe libkxld.dylib (2422.92.1) <EDA98A27-A9F0-3487-A635-B7FE6AC1C8B6> /usr/lib/system/libkxld.dylib
0x9abf0000 - 0x9ac87ff7 com.apple.ink.framework (10.9 - 207) <EF00BCCB-B270-3F3D-9424-EF5F4BC23E25> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x9ac88000 - 0x9acb8ff3 libtidy.A.dylib (15.12) <3DBE95FE-8FA7-3584-9202-E37B54B3B064> /usr/lib/libtidy.A.dylib
0x9acb9000 - 0x9acd2fff com.apple.Kerberos (3.0 - 1) <91F17EB2-C70C-359C-B09D-96B52D2A9C9F> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x9acd3000 - 0x9ad19ff7 libFontRegistry.dylib (127) <A0930DB2-A6C6-3C6E-B4A2-119E0D76FD7D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x9ad1a000 - 0x9af88ff6 com.apple.security (7.0 - 55471.14.1) <025B3E5C-1582-357F-BFE5-B1AA3ACD18F2> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x9af94000 - 0x9b009ff1 com.apple.ApplicationServices.ATS (360 - 363.3) <FD423680-01A1-357A-89A7-33910A87DE65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x9b00a000 - 0x9b05afff com.apple.opencl (2.3.59 - 2.3.59) <4BEFE83C-1C89-3BB6-A445-9BE680C84FB3> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x9b05b000 - 0x9b05eff9 com.apple.TCC (1.0 - 1) <A5FCF7AA-3F56-3A19-9DF1-661F1F02F79D> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x9b05f000 - 0x9b0d5ff3 com.apple.securityfoundation (6.0 - 55122.1) <18024F59-DE2B-3FC5-A29F-8F2B27349685> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x9b0d6000 - 0x9b0eaff9 com.apple.MultitouchSupport.framework (245.13 - 245.13) <6860A0D0-3654-3B02-B2E9-C4D2637167B8> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x9b0eb000 - 0x9b0efffa libGIF.dylib (1042.2) <6B0C937C-5950-33D1-9B39-6CE1E1BB3FD2> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x9b0f0000 - 0x9b108fff com.apple.CFOpenDirectory (10.9 - 173.90.1) <13B70F7C-9A4D-3CCA-AEB8-3958F5B6167E> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x9b5d0000 - 0x9b995ff6 libLAPACK.dylib (1094.5) <E6286E68-3501-31AC-813E-75B3B3968011> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x9b996000 - 0x9b9b2ff9 com.apple.Ubiquity (1.3 - 289) <1CEDC83D-7282-3B4D-8CF7-4FE045012391> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
0x9b9b3000 - 0x9ba1dff7 com.apple.framework.CoreWiFi (2.0 - 200.21.1) <13EE6C12-B981-3132-864A-D493B91AE37E> /System/Library/Frameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x9ba1e000 - 0x9bb55fff com.apple.desktopservices (1.8.2 - 1.8.2) <CCE6EB2B-1799-349A-8F13-003077CDFF31> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x9bb56000 - 0x9bba7ff1 libstdc++.6.dylib (60) <354F284B-2343-3810-9CA2-E28038824F6E> /usr/lib/libstdc++.6.dylib
0x9bc0b000 - 0x9bc13fee libcldcpuengine.dylib (2.3.58) <A393291F-F561-3424-8BD2-AE4496B85F4A> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x9bc14000 - 0x9bcfaff7 com.apple.coreui (2.1 - 231) <1C1AE894-C5C2-3F1C-BF29-B152ECD9BD88> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x9c022000 - 0x9c317ff8 com.apple.CoreImage (9.2.7) <AD2199E4-B18B-3CFC-94C4-B1B8D20CFB8B> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x9c318000 - 0x9c325ff7 com.apple.HelpData (2.1.4 - 90) <5BACC236-5B40-33AC-B088-87EDEFAF1D3E> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x9c328000 - 0x9c384ffa com.apple.print.framework.PrintCore (9.0 - 428) <3E248391-2669-328B-B84F-8763FE8E92BB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x9c38d000 - 0x9c3b9ff7 com.apple.DictionaryServices (1.2 - 208) <33873336-BECD-3F62-A315-C45F24C1818C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0xba300000 - 0xba301fff libCyrillicConverter.dylib (61) <C9E7F2C5-6B9E-3313-86BC-63E550E40E8B> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
0xba900000 - 0xba91cffd libJapaneseConverter.dylib (61) <3153973E-B2A9-3D17-B99B-31E53EC5B0F8> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0xbab00000 - 0xbab21ffc libKoreanConverter.dylib (61) <28867732-7E92-3581-97FD-E43D80F4E0D0> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
0xbad00000 - 0xbad01fff libLatin2Converter.dylib (61) <0FA237A8-3790-376E-BDDD-1FDAF8019745> /System/Library/CoreServices/Encodings/libLatin2Converter.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 3
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 33811
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=180.5M resident=49.8M(28%) swapped_out_or_unallocated=130.7M(72%)
Writable regions: Total=238.1M written=41.8M(18%) resident=97.8M(41%) swapped_out=12K(0%) unallocated=140.4M(59%)
REGION TYPE VIRTUAL
ATS (font support) 33.1M
CG backing stores 22.2M
CG image 4K
CG raster data 176K
CG shared images 212K
CoreGraphics 8K
CoreImage 4K
Foundation 4K
Kernel Alloc Once 4K
MALLOC 145.3M
MALLOC (admin) 48K
Memory Tag 242 12K
Memory Tag 249 156K
OpenCL 8K
Stack 75.4M
Stack (reserved) 516K reserved VM address space (unallocated)
VM_ALLOCATE 19.1M
VM_ALLOCATE (reserved) 148K reserved VM address space (unallocated)
__DATA 16.7M
__IMAGE 528K
__IMPORT 32K
__LINKEDIT 45.1M
__OBJC 2004K
__PAGEZERO 4K
__TEXT 135.5M
__UNICODE 544K
mapped file 132.6M
shared memory 4K
TOTAL 629.2M
TOTAL, minus reserved VM space 628.5M
Model: MacBookPro9,1, BootROM MBP91.00D3.B09, 4 processors, Intel Core i7, 2.3 GHz, 4 GB, SMC 2.1f173
Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In, 1024 MB
Graphics: NVIDIA GeForce GT 650M, NVIDIA GeForce GT 650M, PCIe, 512 MB
Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1600 MHz, 0x802C, 0x384A54463235363634485A2D3147364D3120
Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1600 MHz, 0x802C, 0x384A54463235363634485A2D3147364D3120
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xF5), Broadcom BCM43xx 1.0 (5.106.98.100.22)
Bluetooth: Version 4.2.3f10 13477, 3 services, 23 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: APPLE HDD HTS545050A7E362, 500,11 GB
Serial ATA Device: HL-DT-ST DVDRW GS31N
USB Device: Hub
USB Device: FaceTime HD Camera (Built-in)
USB Device: Hub
USB Device: Hub
USB Device: Apple Internal Keyboard / Trackpad
USB Device: IR Receiver
USB Device: BRCM20702 Hub
Re: fixing an issue
Postby Jerm » Sun May 11, 2014 3:45 pm
Well it now shows the crash in thread 20:
That is not within Metro. If you can tell me the steps to repeat it, I might be able to provide more information for the RC guy to try to prove it is not a problem with Metro.
