Sagan Technology Metro • View topic - Velocity Tool Issue With SharpGray
Postby fastlanephil » Fri Jan 17, 2014 11:33 pm
Using SharpGray, when you decrease the length( clip ) the velocity stem of an unhighlighted note with the Velocity Tool in the Graphic Editor the stem length doesn't change until you click the screen again.
Re: Velocity Tool Issue With SharpGray
Postby Jerm » Sat Jan 18, 2014 2:51 am
Thanks Phil,
I will check that.
Postby Jerm » Sat Jan 18, 2014 4:53 pm
Thanks. This seems to be another Mac only issue. It is now fixed and will be in the next point release to be out soon.
Postby Jerm » Wed Jan 22, 2014 8:16 pm
Fixed in 7.2.0.65.
