Sagan Technology Metro • View topic - select beat division in graphic editor
Postby TAUL » Mon Jan 06, 2014 8:43 am
Hi
However I do not remember it from which version.
When I want to select the range of beat division (with in graphic editor window), that occurs selected a bar division, by clicking nearly around the bar-number-flags.
_Metro version 7.1.1 / MacBookPro15' late2008 / Mac mini mid2011_
Thanks.
TAUL
Re: select beat division in graphic editor
Postby Jerm » Mon Jan 06, 2014 3:22 pm
I really do not know what you mean.
Are you saying that you are trying to select beats and instead Metro is selecting bars?
Have you tried Metro 7.2?
Postby TAUL » Tue Jan 07, 2014 6:24 am
Thank you replying.
Yes, you are correct.
I'm sorry for my poor English. :oops:
I'll attach some pictures about the symptom.
trying to select beat length 01.jpg (34.32 KiB) Viewed 5009 times
trying to select beat length 02.jpg (36.77 KiB) Viewed 5009 times
The result changes In the difference of a delicate positioning.
Can you confirm it?
TAUL
Postby Jerm » Tue Jan 07, 2014 2:42 pm
Thank you for the pictures. I will look into this right away.
What version are you using and what font is selected?
Postby Jerm » Tue Jan 07, 2014 3:10 pm
I am unable to select a full measure by clicking in the beat selection area (white part of bar header). If I click exactly on the beat, Metro selects an insert cursor but never the entire bar. This is version 7.2.
Can you email me the Metro document you are using? Also please tell me the operating system, version of Metro and details of your computer hardware.
Postby TAUL » Wed Jan 08, 2014 9:02 am
Thank you for sparing time for me.
The situation occurs in both my MacBookPro and MacMini computer.
Instantly, I tried "safe boot mode", and/or tried version 7.2, but it was not improved.
I'll looking for some cause and report it after few days.
_MacOSX10.9.1_Metro:font=geneva-9pt_
Thanks again. :|
TAUL
Postby Jerm » Wed Jan 08, 2014 3:25 pm
Hello Taul,
No problem. I would like very much to get to the bottom of this. Do you have a screen recorder program? If yes perhaps you could make a video?
In the meantime I will check with 10.9.
Also and very important... What is your setting under the switches menu for 'Note Edit Quantizing Mode' ?
Postby Jerm » Wed Jan 08, 2014 3:39 pm
I think I am able to repeat this with OS X 10.9. I will keep you informed with progress.
Postby Jerm » Wed Jan 08, 2014 5:26 pm
Okay, thanks :x to Apple for breaking a routine that returns the dimensions of an icon in OS X 10.9. This causes the problem you are seeing. I have subsequently worked around this bug and have posted Metro 7.2.0.2.
Simply login from the downloads page and re-download 7.2, install it and this problem should be fixed. Please report back here on your results.
Thanks.
Postby TAUL » Thu Jan 09, 2014 5:41 am
Oh! how rapid response!
Yes, the problem has vanished, ...while I did nothing. :o
Great thanks for your work!!
TAUL
