Sagan Technology Metro • View topic - Loops won't play after pasting
Postby Paul » Wed May 15, 2013 4:07 am
Hi there,
I have had this problem since quite a while so I thought I'd make a bug report. I have loaded a drumloop in Kontakt 5. I then step-record a 1-bar note to trigger that loop, after which I copy the bar and paste it four times (so I overwriting the 1st bar as well, this way I don't have to first select bar 2). When playing back the four bars, bar 2 won't trigger the loop. In this case, bars 3 and 4 do trigger the beat. When I shorten the note slightly, the second bar will play.
The problem also exists when using ABL2 by Audio Realism.
I'm currently on Metro 7.0.1, OSX 10.7.5.
Paul
Re: Loops won't play after pasting
Postby Jerm » Wed May 15, 2013 10:00 pm
Please send me a MIDI file and I will provide analysis.
Postby Paul » Fri May 17, 2013 2:31 am
Would you like a Metro-file or a standard midi file? Where can I send this file to? It won't contain much data, other than the four notes I described...
Paul
Paul
Postby Jerm » Fri May 17, 2013 2:37 am
If it is what I think it is, it is fixed in 7.1. Due out by the end of this month.
You can send a Metro file or a MIDI file to info AT sagantech.biz
Postby Jerm » Sat May 18, 2013 6:09 pm
Thanks for the file Paul.
This should definitely be corrected in 7.1.
Postby Paul » Wed May 22, 2013 5:16 am
Cool, thanks Jerm!
Any insight into what it was?
Paul
Postby Jerm » Wed May 22, 2013 12:19 pm
It was round off error. As you have noticed, if you shorten the duration of the note by 1 clock it will work.
The problem is the MIDI concept of note on and note off. These need to be calculated at very high precision for soft synths. The order sent to the plug-in has to also be very precise as a note on at the same time as a note off will cut off the note on, as you are seeing.
