by Jerm » Fri Feb 01, 2013 2:16 am
Hello Phil,
Okay. I got your file and was able to easily repeat the problem with it. It is definitely a bug that was introduced in 7.0.
It was introduced when I added support for latency compensation on aux busses (for plug-ins with no audio inputs). Unfortunately there is no work-around other than to use track-inserts. If you are not using multiple sections you should put all your plug-ins on tracks and then count-off will work until the release of Metro 7.0.2 or greater (which fixes the problem).
Thank you for bringing this to my attention and following up with a sample file. I only hope the new fix, which I tested and it does fix count-off for plug-ins on aux busses, does not break the latency compensation for aux busses.
Jeremy
