Sagan Technology Metro • View topic - Mac AU Plugins Not Showing
Postby Vigner » Tue Jan 22, 2013 10:26 am
Hi!
I bought metro LX yesterday!! Very cool!!
But i am very upset cause a lot of AU plugins dont show their interfaces when i open them im the Intantantiated Synth/Effetcs!!
I hope that Jeremy will correct that!!
I am in Mountain Lion, Mac!
Interfaces of several Native instruments change after reopen them in the graphic window. First time they show uo normally, but after i close and open them, interface is diferrent!!
Vigner
Re: Mac AU Plugins Not Showing
Postby Jerm » Tue Jan 22, 2013 11:43 am
Please post the names of the plug-ins in question (and pictures if possible). Most likely this is just a setting that needs to be adjusted.
Postby Jerm » Sun Jan 27, 2013 3:27 pm
There does seem to be a problem with some NI AU plug-ins. The easy solution is to right-click on them in the plug-ins window and select one or both of the following options:
    Plug-in prefers Cabon editor
    Retain Editor on Window Close
More info on plug-in options can be found here.
This will be fixed in the next release.
