Sagan Technology Metro • View topic - Expand Subsections Bug
Postby fastlanephil » Sat Dec 29, 2012 12:25 am
I did figure out how to place GPO on Mixer channel but I'm not having much luck utilizing it. I also tried placing different instances of GPO on two section but when I expand them only the first instrument is there for each section. :|
I'll be looking forward to the next release of Metro 7 with more aux busses and other additions.
Phil
Re: Instrument Plug-ins On Tracks With Metro 7
Postby Jerm » Sat Dec 29, 2012 12:43 am
Can you please email me the Metro document before expansion and detail how you are doing the expansion?
Re: Expand Subsections Bug
Postby Jerm » Sat Dec 29, 2012 2:53 pm
I moved this to bug reports because this is a bug I am currently looking into....
Postby Jerm » Sat Dec 29, 2012 4:27 pm
I believe this is fixed in 7.0.1 but I will require some more testing. :wink:
Postby Jerm » Fri Jan 18, 2013 8:09 pm
Phil,
Assuming you have downloaded and installed 7.0.1, could you please post any results here.
