Sagan Technology Metro • View topic - Undo In Edit Menue
Undo In Edit Menue
Undo In Edit Menue
Postby fastlanephil » Tue Nov 20, 2012 9:04 pm
I noticed that when I render a MIDI track(s) into audio the Edit menu says Undo Mix Audio and not Undo Render Audio.
Phil
Re: Undo In Edit Menue
Postby Jerm » Wed Nov 21, 2012 3:53 am
I saved a few bytes. :lol:
