Sagan Technology Metro • View topic - Knobs & Sliders Problem
Postby fastlanephil » Thu Nov 08, 2012 8:11 pm
Hi Jeremy,
Getting back into it again and there seems to be a problem with OSX 10.8.2, Metro's Remote Control and my Axion 49 volume sliders and pans. I can program channels 1 and 2 but 3 through 8 only control the 1st channel again. The transport functions do work.
Phil
Re: Knobs & Sliders Problem
Postby Jerm » Fri Nov 09, 2012 1:52 am
The Axiom has a lot of preset configurations so it may be that you just selected the wrong preset.
Another thing to check is to look in the remote control window and be sure that all the ports are coming from the axiom and that they don't have '[' around them.
I doubt it has anything to do with 10.8
Postby fastlanephil » Fri Nov 09, 2012 10:55 pm
I didn't have the Parameters set correctly. The numbers overlap each other in the Controller Window and I over looked it.
Postby Jerm » Fri Nov 09, 2012 11:35 pm
Is it fixed now?
:idea: I should make the column sizes in the remote control window adjustable. If only it were really easy to do.
Postby fastlanephil » Sat Nov 10, 2012 9:58 am
Yes, everything is working. It displays correctly with the 9 point font but it's way too small for my eyes.
Maybe there is a way to just give the Parameters column more space?
Phil
Postby Jerm » Sat Nov 10, 2012 1:17 pm
I think if you change the main font size it will change in the remote control window. Of course that won't help with the spacing.
