Sagan Technology Metro • View topic - Something wrong with groove quantize?
Postby Paul » Fri Oct 30, 2009 4:10 pm
I record two bars of music, go to the quantize menu and select "Groove named: 16th triplet". What I end up with then is a bunch of notes played on beat 1 of the first bar (all together) and a bunch of notes all played on beat 1 of the third bar (which wasn't even there before).
Is this a bug? When I quantize using 16th notes (so no 'groove named'), there is no problem.
Problem occurs on both midi and virtual instrument tracks. I'm on a G5, using 10.5.8.
Paul
Postby Jerm » Sat Oct 31, 2009 1:43 am
Hello Paul,
Thanks for the report. It seems to work okay for me. What version of Metro are you using? You could try removing your preferences file.
Postby Paul » Sat Oct 31, 2009 1:11 pm
Hi Jerm,
I'm on 6.4.8.
Where can I find the preference file you're refering to? If you want, I could email you some pictures of what's happening.
Paul
Postby Jerm » Sat Oct 31, 2009 3:55 pm
username:library:preferences:Metro 6 preferences
off the top of my head.
Postby Paul » Mon Nov 02, 2009 3:12 pm
OK, I removed the preferences file. When I launch Metro I get the qualification screen but it says "Invalid serial number!".
As far as I know this is a correct serial number for 6.2 (received way back in 2005). Do I need another serial number for 6.4?
Paul
Postby Jerm » Mon Nov 02, 2009 10:44 pm
Yes, you need your 6.4 serial number. Email to info (at) sagantech.biz to recover your latest serial number if you cannot find it.
Postby Paul » Wed Nov 04, 2009 3:53 pm
Jerm,
trashing the preferences did the trick. Groove quantize works fine now. Unfortunately, I'm now having a hard time remembering exactly what my preferences were...
Thanks! :wink:
Paul
