Sagan Technology Metro • View topic - OS X Mach-O VST plug-ins cannot be nested within folders
Postby Jerm » Sun Mar 23, 2003 12:50 am
The title says it all. Mach-O VST's which are packages need to be directly contained in /Library/Audio/Plug-ins/VST/ to be found, not
/Library/Audio/Plug-ins/VST/mymanufacturersVST
This is fixed in 6.05i7.
