Sagan Technology Metro • View topic - 1. Master fader question and 2. (unexpected?) AU dialog
Postby Scoot » Tue Mar 14, 2006 4:36 am
errors or features?
1. Should the Master Fader display clipping on playback?
If you have an audio track open and you add an effect like a compressor so you can boost the output, you can easily get the audio track 1 to max out and have a full VU. The Master goes up along with it (as there is only one track they match) but there is never a clip on the master. Does it not work in playback?
2. Have two audio tracks open with an effect on each. (any AU's)
Open the effects/synth window
Start playback
Click on the green power light to turn off the effect on track 1
Goto track 2 in the effects synth window and click the green light on
Dialog appears
-10876
AudioUnitErr No Connection
Thing is if you just click the green power light on and off on the same track it doesn't happen.
No problems with red individual on/off lights........I suppose cause the effect is on standby to come on as the green light is powered and ready??
Re: 1. Master fader question and 2. (unexpected?) AU dialog
Postby Jerm » Tue Mar 14, 2006 12:58 pm
Scoot wrote:errors or features?
It should probably accumulate all of the other clip indicators and display that but currently it does not.
Scoot wrote:2. Have two audio tracks open with an effect on each.
Don't know. Will check it out. In the meantime there is really no reason to turn the power off. Use bypass instead.
Users browsing this forum: No registered users and 22 guests
