Sagan Technology Metro • View topic - Metro 6.3.5 & VIs
Metro 6.3.5 & VIs
Metro 6.3.5 & VIs
Postby fastlanephil » Thu Mar 09, 2006 11:23 am
I upgraded to Metro 6.3.5 from 6.3.3 and there is no connection to SampleTank 2.1, ect. They show up in the output menu and the level meter shows keyboard activity but no response with my keyboards or using the mouse on the module keyboard. I went back to 6.3.3 and there is no problem. I have a iMac G5 1.8 using Apple's latest OSX. I reset the midi inputs in Metro and checked audio/midi prefs.
Postby Jerm » Thu Mar 09, 2006 12:39 pm
Did you check your outputs? If you double click on the aux buss that sampletank is installed on from the mixer window, where does it say the output is going? If you get sound from the ST2 then perhaps auto midi thru is not on.
Metro 6.3.5 & VIs
Postby fastlanephil » Thu Mar 09, 2006 12:58 pm
I cntrl clicked on one of my VIs in the plug-ins window and selected To Aux Bus. They are working fine now. I think you helped me with this before and I did the same thing. I'll try and remember to check from now on.
Thanks a lot for the quick help.
Phil
