Sagan Technology Metro • View topic - Metro Crashing on startup
Postby simon201 » Tue Feb 21, 2012 5:14 pm
Hi
I've been using Metro for a number of years now, and although I don't use it an awful lot these days, I still kind of need it to do some midi conversions from my old Metro files. Just recently I've tried to open up Metro on my iMac (OS X 10.7.3) and it crashes with the following log.
Would this give some clues as to resolving this? I've tried it recently with Metro 6.5 also and it gives a similar result.
Incidently all works ok on my Macbook using similar plugins etc.
Process: Metro [1346]
Path: /Applications/Metro Folder 6.3/Metro.app/Contents/MacOS/Metro
Identifier: biz.sagantech.Metro
Version: 6.3.8.6 (6.3.8.6)
Code Type: X86 (Native)
Parent Process: launchd [171]
Date/Time: 2012-02-21 22:04:32.715 +0000
OS Version: Mac OS X 10.7.3 (11D50)
Report Version: 9
Interval Since Last Report: 153034 sec
Crashes Since Last Report: 48
Per-App Interval Since Last Report: 125 sec
Per-App Crashes Since Last Report: 1
Anonymous UUID: 3F320595-6B33-4430-B6AF-2114BD95D1A6
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000008
VM Regions Near 0x8:
--> __PAGEZERO 0000000000000000-0000000000001000 [ 4K] ---/--- SM=NUL /Applications/Metro Folder 6.3/Metro.app/Contents/MacOS/Metro
__TEXT 0000000000001000-000000000022a000 [ 2212K] r-x/rwx SM=COW /Applications/Metro Folder 6.3/Metro.app/Contents/MacOS/Metro
Application Specific Information:
objc[1346]: garbage collection is OFF
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_blocks.dylib 0x91981b47 _Block_object_assign + 173
1 com.apple.audio.CoreAudio 0x946925d4 __copy_helper_block_45 + 38
2 libsystem_blocks.dylib 0x91980f86 _Block_call_copy_helper + 29
3 libsystem_blocks.dylib 0x919819d3 _Block_copy_internal + 228
4 com.apple.audio.CoreAudio 0x94676c10 HALB_Executor::Push(void ( block_pointer)(HALB_Executor&)) + 18
5 com.apple.audio.CoreAudio 0x9469664f HALC_ShellDevice::_Device_GetPropertyData(HALB_Executor&, AudioObjectPropertyAddress, unsigned long, void const*, unsigned long, unsigned long&, void*) const + 579
6 com.apple.audio.CoreAudio 0x9469a50f HALC_ShellDevice::_GetPropertyData(HALB_Executor&, unsigned long, AudioObjectPropertyAddress, unsigned long, void const*, unsigned long, unsigned long&, void*) const + 735
7 com.apple.audio.CoreAudio 0x9469f363 HALC_ShellObject::GetPropertyData_Helper(HALB_Executor&, unsigned long, AudioObjectPropertyAddress, unsigned long, void const*, unsigned long, unsigned long&, void*) const + 91
8 com.apple.audio.CoreAudio 0x94676bf5 __GetPropertyData_block_invoke_9 + 123
9 com.apple.audio.CoreAudio 0x94676b4b HALB_CommandGate::ExecuteCommand(void ( block_pointer)()) const + 35
10 com.apple.audio.CoreAudio 0x9469f77b HALC_ShellObject::GetPropertyData(HALB_Executor&, unsigned long, AudioObjectPropertyAddress, unsigned long, void const*, unsigned long, unsigned long&, void*) const + 155
11 com.apple.audio.CoreAudio 0x94699f4b _ZL38_Device_GetCFStringPropertyData_HelperR13HALB_Executorm26AudioObjectPropertyAddressRPK10__CFString + 224
12 com.apple.audio.CoreAudio 0x94697d87 ___Device_GetPropertyData_block_invoke_46 + 58
13 com.apple.audio.CoreAudio 0x94671bb6 HALB_Executor::DoIt(void ( block_pointer)(HALB_Executor&)) + 62
14 com.apple.audio.CoreAudio 0x94671b45 HALB_Executor::Run(void ( block_pointer)(HALB_Executor&)) + 53
15 com.apple.audio.CoreAudio 0x946a0977 _ZL40HAL_HardwarePlugIn_ObjectGetPropertyDataPP28AudioHardwarePlugInInterfacemPK26AudioObjectPropertyAddressmPKvPmPv + 143
16 com.apple.audio.CoreAudio 0x946ae6e3 HALPlugIn::ObjectGetPropertyData(HALObject const&, AudioObjectPropertyAddress const&, unsigned long, void const*, unsigned long&, void*) const + 89
17 com.apple.audio.CoreAudio 0x946ad757 HALObject::GetPropertyData(AudioObjectPropertyAddress const&, unsigned long, void const*, unsigned long&, void*) const + 445
18 com.apple.audio.CoreAudio 0x946ab2bb HALDevice::GetPropertyData(AudioObjectPropertyAddress const&, unsigned long, void const*, unsigned long&, void*) const + 1315
19 com.apple.audio.CoreAudio 0x9467bf59 AudioDeviceGetProperty + 366
20 biz.sagantech.Metro 0x000f8055 0x1000 + 1011797
21 biz.sagantech.Metro 0x000f813c 0x1000 + 1012028
22 biz.sagantech.Metro 0x0008a12d 0x1000 + 561453
23 biz.sagantech.Metro 0x0008e509 0x1000 + 578825
24 biz.sagantech.Metro 0x000539d0 0x1000 + 338384
25 biz.sagantech.Metro 0x00083e26 0x1000 + 536102
26 biz.sagantech.Metro 0x00002682 0x1000 + 5762
27 biz.sagantech.Metro 0x000025a9 0x1000 + 5545
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x967ae90a kevent + 10
1 libdispatch.dylib 0x9acf2c58 _dispatch_mgr_invoke + 969
2 libdispatch.dylib 0x9acf16a7 _dispatch_mgr_thread + 53
Thread 2:
0 libsystem_kernel.dylib 0x967ad83e __psynch_cvwait + 10
1 libsystem_c.dylib 0x901e1e78 _pthread_cond_wait + 914
2 libsystem_c.dylib 0x901e1f7b pthread_cond_timedwait_relative_np + 47
3 com.apple.CoreServices.CarbonCore 0x920113ef TSWaitOnConditionTimedRelative + 178
4 com.apple.CoreServices.CarbonCore 0x92011165 TSWaitOnSemaphoreCommon + 490
5 com.apple.CoreServices.CarbonCore 0x92010f76 TSWaitOnSemaphoreRelative + 24
6 com.apple.CoreServices.CarbonCore 0x92086398 TimerThread + 292
7 libsystem_c.dylib 0x901dded9 _pthread_start + 335
8 libsystem_c.dylib 0x901e16de thread_start + 34
Thread 3:
0 libsystem_kernel.dylib 0x967abc22 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x967ab1f6 mach_msg + 70
2 com.apple.audio.midi.CoreMIDI 0x00306f67 XServerMachPort::ReceiveMessage(int&, void*, int&) + 101
3 com.apple.audio.midi.CoreMIDI 0x00329f5b MIDIProcess::RunMIDIInThread() + 259
4 com.apple.audio.midi.CoreMIDI 0x0032a8e2 MIDIProcess::MIDIInPortThread::Run() + 24
5 com.apple.audio.midi.CoreMIDI 0x0030853b XThread::RunHelper(void*) + 17
6 com.apple.audio.midi.CoreMIDI 0x00307f05 CAPThread::Entry(CAPThread*) + 123
Thread 4:
2 com.apple.CoreFoundation 0x91a04c7a __CFRunLoopServiceMachPort + 170
3 com.apple.CoreFoundation 0x91a0dda4 __CFRunLoopRun + 1428
4 com.apple.CoreFoundation 0x91a0d47c CFRunLoopRunSpecific + 332
5 com.apple.CoreFoundation 0x91a1e1a1 CFRunLoopRun + 129
6 com.apple.DVCPROHDMuxer 0x0c71798f AVS::DestroyAVCDeviceController(AVS::AVCDeviceController*) + 317
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x00000008 ecx: 0x01000004 edx: 0x08000000
edi: 0xbffff568 esi: 0x91981aa8 ebp: 0xbffff188 esp: 0xbffff170
ss: 0x00000023 efl: 0x00010287 eip: 0x91981b47 cs: 0x0000001b
ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f
cr2: 0x00000008
Logical CPU: 2
Binary Images:
0x1000 - 0x229ff7 +biz.sagantech.Metro (6.3.8.6 - 6.3.8.6) /Applications/Metro Folder 6.3/Metro.app/Contents/MacOS/Metro
0x2f7000 - 0x343ffb com.apple.audio.midi.CoreMIDI (1.8 - 42) <CBD34EBC-0FFD-34B4-B55A-BE1F61EF4BD8> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x1f79000 - 0x1f7bff3 com.apple.LiveType.component (2.1.4 - 2.1.4) <D60E2537-3B47-EA99-0077-6CE394378D07> /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
0x1f81000 - 0x1fc7ffb com.apple.motion.component (1.0 - 729) <494487C6-EA30-43DD-39E4-BED23C5A5B1C> /Library/QuickTime/Motion.component/Contents/MacOS/Motion
0x1fcd000 - 0x1fcfff7 Motion (729.0.0 - compatibility 1.0.0) <051B60E9-B39F-EBB2-5B96-F088D147E78C> /Library/Frameworks/Motion.framework/Versions/A/Motion
0x1fe2000 - 0x1fe3ffc ATSHI.dylib (??? - ???) <B244624E-E09E-34B2-A185-EB30AF08A95D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
0x48fc000 - 0x48fcfff libmx.A.dylib (2026.0.0 - compatibility 1.0.0) <859B5BCC-B5D9-370F-8B6C-1E2B242D5DCD> /usr/lib/libmx.A.dylib
0x4a00000 - 0x4a64fe2 com.apple.LiveType.framework (2.1.4 - 2.1.4) <7AABA687-4323-E5B9-BA04-8F61C217E6FD> /Library/Application Support/ProApps/*/LiveType.framework/Versions/A/LiveType
0x4a84000 - 0x4b21ff8 com.apple.procore.framework (4.0.2 - 757) <D3146F1E-F86D-F2A2-509B-E3F9640CBE40> /Library/Application Support/ProApps/*/ProCore.framework/Versions/A/ProCore
0x4ee0000 - 0x4ee7ffe com.apple.AppleGVAHW.component (1.0 - 1) <13BFEB64-0AD7-3ACE-94DA-806546212480> /System/Library/QuickTime/AppleGVAHW.component/Contents/MacOS/AppleGVAHW
0x93c2000 - 0x93d5fef com.apple.FCP Uncompressed 422.component (2.0 - 546.9) <DAC75D69-E415-E716-AF10-06BBD87B051A> /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
0x93da000 - 0x93e7fff +net.telestream.license (1.0.3.4-GC - 1.0.3.4-GC) <0B4D5758-8A9B-958D-1406-12377A1D9E23> /Library/Frameworks/TSLicense.framework/Versions/A/TSLicense
0x93f1000 - 0x93f3fff com.apple.MLTEFile (3.2.1 - 7) <88F40050-787E-3815-9631-DAF1B86F2A3D> /System/Library/CoreServices/MLTEFile.bundle/Contents/MacOS/MLTEFile
0x97f1000 - 0x97f7fff +biz.sagantech.SaganTech-Metronome (1.0.3 - 1.0.3) /Applications/Metro Folder 6.3/*/SaganTech-Metronome
0xa72b000 - 0xa753fe3 com.apple.AppleAVCIntraCodec (2.0 - 542.4) <408052E9-3698-D679-DB45-82B57D075B22> /Library/QuickTime/AppleAVCIntraCodec.component/Contents/MacOS/AppleAVCIntraCodec
0xa75d000 - 0xa796ff3 com.apple.QuickTimeFireWireDV.component (7.7.1 - 2315) <F2AFE0C1-1B5B-3A46-9A09-A2E04DCBE215> /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
0xa7a1000 - 0xa7defe7 com.apple.DVCPROHDCodec (2.0 - 542.4) <751976E0-619F-30A4-2EF4-60919BD28C72> /Library/QuickTime/DVCPROHDCodec.component/Contents/MacOS/DVCPROHDCodec
0xa7ee000 - 0xa7fcffb libSimplifiedChineseConverter.dylib (54.0.0 - compatibility 1.0.0) <D3F1CC34-55EB-3D33-A7C2-025D5C8025D0> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
0xb301000 - 0xb5f1feb +org.perian.Perian (1.2.3 - 1.2.3) <722FFF4F-46EF-E5BE-70A6-42B5873D2B37> /Users/USER/Library/QuickTime/Perian.component/Contents/MacOS/Perian
0xba6c000 - 0xbc5efe2 +net.telestream.wmv.import (2.3.6.5 - 2.3.6.5) <1C5C8F9A-DE50-44E2-7859-3D54006F4C6E> /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import
0xbc93000 - 0xbd40ff7 libcrypto.0.9.7.dylib (0.9.7 - compatibility 0.9.7) <7B6DB792-C9E5-3772-8734-8D0052757B8C> /usr/lib/libcrypto.0.9.7.dylib
0xbd85000 - 0xbf45ff2 +net.telestream.wmv.advanced (2.3.6.5 - 2.3.6.5) <7CC255AF-1F15-4358-98F2-F2F263D29F6A> /Library/QuickTime/Flip4Mac WMV Advanced.component/Contents/MacOS/Flip4Mac WMV Advanced
0xbf8a000 - 0xc00dff3 com.apple.AppleProResCodec (3.0 - 544.2) <A3039D9F-33F1-B503-B054-792E62263759> /Library/QuickTime/AppleProResCodec.component/Contents/MacOS/AppleProResCodec
0xc04b000 - 0xc08aff7 com.apple.AppleVAH264HW.component (3.0 - 3.0) <4460AFFB-17DE-34F0-91C7-A2C90B817146> /System/Library/QuickTime/AppleVAH264HW.component/Contents/MacOS/AppleVAH264HW
0xc14d000 - 0xc263ff3 com.apple.AppleGVAFramework (2.2.79 - 2.2.79) <7D6AA57B-BA89-398A-8522-0D6D2106669E> /System/Library/PrivateFrameworks/AppleGVA.framework/Versions/A/AppleGVA
0xc27c000 - 0xc32ffe7 com.apple.AppleHDVCodec (2.0 - 548.3) <7E6FD5F1-CAA5-6E72-1217-CF9F199F7EFE> /Library/QuickTime/AppleHDVCodec.component/Contents/MacOS/AppleHDVCodec
0xc34b000 - 0xc36cfe7 com.apple.AppleIntermediateCodec (2.0 - 542.4) <C71EE6F3-7B4D-38DA-B3D9-65B0AD4CE313> /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
0xc37b000 - 0xc391ffb com.apple.IMXCodec (2.0 - 547.2) <10CDBF62-3937-927C-6470-E355A0232686> /Library/QuickTime/IMXCodec.component/Contents/MacOS/IMXCodec
0xc3a3000 - 0xc3bbff2 com.apple.applepixletvideo (1.2.30 - 1.2d30) <72A0B4BD-DB7A-3C7F-ADB9-6D059F7ABA2B> /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
0xc3e2000 - 0xc3f4fff libTraditionalChineseConverter.dylib (54.0.0 - compatibility 1.0.0) <ADEB72F9-0048-3C87-AD9B-71AA57D523E9> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
0xc50a000 - 0xc50effb libFontRegistryUI.dylib (??? - ???) <E986346C-8132-33B6-8525-AA2A3233F99C> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resources/libFontRegistryUI.dylib
0xc52b000 - 0xc52fffb com.apple.audio.AudioIPCPlugIn (1.2.2 - 1.2.2) <E6982BB2-BEC8-3232-989D-B3D5B26AE0DF> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
0xc575000 - 0xc57bffb com.apple.audio.AppleHDAHALPlugIn (2.1.7 - 2.1.7f9) <731DE928-8747-39A9-8C7A-E1017A4D1A07> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0xc580000 - 0xc5d5fe2 com.apple.DVCPROHDAudio (1.3.2 - 1.3.2) <2E0A9883-4EA5-706F-78F6-4C1F105A4D30> /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio
0xc700000 - 0xc765fe0 com.apple.DVCPROHDMuxer (1.3.2 - 1.3.2) <483DD62C-46C4-36AA-6A1C-2DEA6F062863> /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
0x70000000 - 0x70141fff com.apple.audio.units.Components (1.7.2 - 1.7.2) <44C7D574-F577-30B8-B74D-F2EF8A5A282A> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x8fe8f000 - 0x8fec1aa7 dyld (195.6 - ???) <3A866A34-4CDD-35A4-B26E-F145B05F3644> /usr/lib/dyld
0x90112000 - 0x90117ff7 libmacho.dylib (800.0.0 - compatibility 1.0.0) <56A34E97-518E-307E-8218-C5D43A33EE34> /usr/lib/system/libmacho.dylib
0x90181000 - 0x9024cfff libsystem_c.dylib (763.12.0 - compatibility 1.0.0) <1B0A12B3-DAFA-31E2-8F82-E98D620E4D72> /usr/lib/system/libsystem_c.dylib
0x9024d000 - 0x9024fffb libRadiance.dylib (??? - ???) <4721057E-5A1F-3083-911B-200ED1CE7678> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x90250000 - 0x902ddff7 com.apple.CoreText (220.11.0 - ???) <720EFEE0-A92A-3519-9C88-D06E4DE14EAB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x902de000 - 0x902e5ffd com.apple.NetFS (4.0 - 4.0) <D0D59145-D211-3E7C-9062-35A2833FA99B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x902f8000 - 0x9038dff7 com.apple.LaunchServices (480.27.1 - 480.27.1) <8BFE799A-7E35-3834-9403-20E5ADE015D0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x9038e000 - 0x90415fff com.apple.print.framework.PrintCore (7.1 - 366.1) <BD9120A6-BFB0-3796-A903-05F627F696DF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x90416000 - 0x9043fff1 com.apple.CoreServicesInternal (113.12 - 113.12) <CFF78E35-81F5-36C2-A59F-BF85561AC16D> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x904a3000 - 0x90565fff com.apple.CoreServices.OSServices (478.37 - 478.37) <00A48B2A-2D75-3FD0-9805-61BB11710879> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x90566000 - 0x90566fff com.apple.vecLib (3.7 - vecLib 3.7) <8CCF99BF-A4B7-3C01-9219-B83D2AE5F82A> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x90567000 - 0x905c4ffb com.apple.htmlrendering (76 - 1.1.4) <743C2943-40BC-36FB-A45C-3421A394F081> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x905c6000 - 0x9062dfff libc++.1.dylib (19.0.0 - compatibility 1.0.0) <3AFF3CE8-14AE-300F-8F63-8B7FB9D4DA96> /usr/lib/libc++.1.dylib
0x9062e000 - 0x9066eff7 com.apple.NavigationServices (3.7 - 193) <16A8BCC8-7343-3A90-88B3-AAA334DF615F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x9066f000 - 0x90676ff7 libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <47DB9E1B-A7D1-3818-A747-382B2C5D9E1B> /usr/lib/system/libsystem_notify.dylib
0x910e5000 - 0x911cdfff libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <ED3F5E83-8C76-3D46-B2FF-0D5BDF8970C5> /usr/lib/libxml2.2.dylib
0x911de000 - 0x911deff0 com.apple.ApplicationServices (41 - 41) <BED33E1D-C95C-3654-9A3A-0CB3607F9F10> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x911df000 - 0x911f4fff com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <92AADDB0-BADF-3B00-8941-B8390EDC931B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x911f5000 - 0x91202fff com.apple.HelpData (2.1.2 - 72) <37D51522-EDED-38BC-9412-3224ED91A078> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x91838000 - 0x91848ff7 libCRFSuite.dylib (??? - ???) <CE616EF3-756A-355A-95AD-3472A876BEB9> /usr/lib/libCRFSuite.dylib
0x91980000 - 0x91981fff libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <B04592B1-0924-3422-82FF-976B339DF567> /usr/lib/system/libsystem_blocks.dylib
0x91982000 - 0x91992fff com.apple.LangAnalysis (1.7.0 - 1.7.0) <6D6F0C9D-2EEA-3578-AF3D-E2A09BCECAF3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x91993000 - 0x919d1fff libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <0FAB8C29-2A1B-3E25-BA34-BDD832B828DA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x919d2000 - 0x91ba9fff com.apple.CoreFoundation (6.7.1 - 635.19) <3A07EDA3-F460-3971-BFCB-AFE9A11F74F1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x91bb2000 - 0x91bb2fff com.apple.Carbon (153 - 153) <6FF98F0F-2CDE-3888-A304-4ED447D24CE3> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x91bb3000 - 0x91bfcff7 libGLU.dylib (??? - ???) <AEA2AD9A-EEDD-39B8-9B28-4C7C1BACB594> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x91bfd000 - 0x91c08ffb com.apple.speech.recognition.framework (4.0.19 - 4.0.19) <17C11291-5B27-3BE2-8614-7A806745EE8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x91f5e000 - 0x91f80ffe com.apple.framework.familycontrols (3.0 - 300) <6B0920A5-3971-30EF-AE4C-5361BB7199EB> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x91f81000 - 0x91fd2fff libFontRegistry.dylib (??? - ???) <DF69E8EC-9114-3757-8355-8F3E82156F85> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x91fd3000 - 0x922d5fff com.apple.CoreServices.CarbonCore (960.20 - 960.20) <E6300673-A013-3A91-BB1A-DD793B857E16> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x922d6000 - 0x92549ff7 com.apple.CoreImage (7.93 - 1.0.1) <88FEFE5B-83A9-3CD9-BE2E-DB1E0553EBB0> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x92c6b000 - 0x92ce7ff7 libType1Scaler.dylib (??? - ???) <2560F511-3288-3367-A4E2-AD15219B6913> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
0x92dca000 - 0x92e0aff7 libauto.dylib (??? - ???) <984C81BE-FA1C-3228-8F7E-2965E7E5EB85> /usr/lib/libauto.dylib
0x92e18000 - 0x92f27fff com.apple.DesktopServices (1.6.2 - 1.6.2) <33DCFB71-1D9E-30B6-BC4C-CD54068690BE> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x93172000 - 0x931d7ff7 libvDSP.dylib (325.4.0 - compatibility 1.0.0) <4B4B32D2-4F66-3B0D-BD61-FA8429FF8507> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x931d8000 - 0x931e0ff3 libunwind.dylib (30.0.0 - compatibility 1.0.0) <E8DA8CEC-12D6-3C8D-B2E2-5D567C8F3CB5> /usr/lib/system/libunwind.dylib
0x9325c000 - 0x9325cfff libdnsinfo.dylib (395.6.0 - compatibility 1.0.0) <959E5139-EB23-3529-8881-2BCB5724D1A9> /usr/lib/system/libdnsinfo.dylib
0x9325d000 - 0x932a0ffd libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <4BA1F5F1-F0A2-3FEB-BB62-F514DCBB3725> /usr/lib/system/libcommonCrypto.dylib
0x932a1000 - 0x932a3ffc com.apple.QuickTimeH264.component (7.7.1 - 2315) <94626300-FADD-3219-9E76-278AD69C9A1F> /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
0x932a8000 - 0x93303ff3 com.apple.Symbolication (1.3 - 91) <4D12D2EC-5010-3958-A205-9A67E972C76A> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x93345000 - 0x93374ff7 libsystem_info.dylib (??? - ???) <37640811-445B-3BB7-9934-A7C99848250D> /usr/lib/system/libsystem_info.dylib
0x93380000 - 0x9368aff3 com.apple.Foundation (6.7.1 - 833.24) <8E2AD829-587C-3146-B483-9D0209B84192> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x9368b000 - 0x93696ff3 libCSync.A.dylib (600.0.0 - compatibility 64.0.0) <DD0529E3-9D71-37B6-9EB8-D7747B2B12C6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x9369a000 - 0x936a5ffc com.apple.NetAuth (1.0 - 3.0) <C07853C0-AF32-3633-9CEF-2480860C12C5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x93700000 - 0x93707fff com.apple.agl (3.1.4 - AGL-3.1.4) <CCCE2A89-026B-3185-ABEA-68D268353164> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x93795000 - 0x938a9ff3 com.apple.QuickTimeImporters.component (7.7.1 - 2315) <5851AB10-A55E-3D80-94D3-46B90E0879DA> /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
0x9392c000 - 0x93955ffe com.apple.opencl (1.50.69 - 1.50.69) <44120D48-00A2-3C09-9055-36D309F1E7C9> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x93979000 - 0x9397afff libDiagnosticMessagesClient.dylib (??? - ???) <DB3889C2-2FC2-3087-A2A2-4C319455E35C> /usr/lib/libDiagnosticMessagesClient.dylib
0x9397b000 - 0x93a73ff7 libFontParser.dylib (??? - ???) <8C069D3D-534F-3EBC-8035-A43E2B3A431A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x93a74000 - 0x93aabfef com.apple.DebugSymbols (2.1 - 87) <EB951B78-31A5-379F-AFA1-B5C9A7BB3D23> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x93afc000 - 0x93b12ffe libxpc.dylib (77.18.0 - compatibility 1.0.0) <D40B8FD1-C671-3BD5-8C9E-054AF6D4FE9A> /usr/lib/system/libxpc.dylib
0x93b14000 - 0x93b27ffb com.apple.MultitouchSupport.framework (220.62.1 - 220.62.1) <3D94520B-C976-370F-AF56-278002BCF11D> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x93b2a000 - 0x93b2bfff liblangid.dylib (??? - ???) <C8C204E9-1785-3785-BBD7-22D59493B98B> /usr/lib/liblangid.dylib
0x93b2c000 - 0x93ba7ffb com.apple.ApplicationServices.ATS (317.5.0 - ???) <7A8B0538-8E2E-3355-81E3-0C0A7EBED28E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x93ba8000 - 0x93c3fff3 com.apple.securityfoundation (5.0 - 55107) <DF36D4ED-47F7-3F7F-AB09-32E5BFB7EF05> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x93c40000 - 0x93cb6fff com.apple.Metadata (10.7.0 - 627.28) <71AC8DA5-FA89-3411-A97C-65B6129E97BD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x93d75000 - 0x93e10ff3 com.apple.ink.framework (1.3.2 - 110) <9F6F37F9-999E-30C5-93D0-E48D4B5E20CD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x94614000 - 0x9461affd com.apple.CommerceCore (1.0 - 17) <71641C17-1CA7-3AC9-974E-AAC9EB641035> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x94657000 - 0x9465affd libCoreVMClient.dylib (??? - ???) <2D135537-F9A6-33B1-9B01-6ECE7E929C00> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x9465b000 - 0x94669ff7 libxar-nossl.dylib (??? - ???) <5BF4DA8E-C319-354A-967E-A0C725DC8BA3> /usr/lib/libxar-nossl.dylib
0x9466a000 - 0x946cbffb com.apple.audio.CoreAudio (4.0.2 - 4.0.2) <E617857C-D870-3E2D-BA13-3732DD1BC15E> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x946cc000 - 0x946cfff7 libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <69357047-7BE0-3360-A36D-000F55E39336> /usr/lib/system/libmathCommon.A.dylib
0x94750000 - 0x9476ffff com.apple.RemoteViewServices (1.3 - 44) <243F16F3-FFFE-3E81-A969-2EC947A11D89> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x947c1000 - 0x947c5ff3 libsystem_network.dylib (??? - ???) <62EBADDA-FC72-3275-AAB3-5EDD949FEFAF> /usr/lib/system/libsystem_network.dylib
0x94baa000 - 0x94bd3fff com.apple.shortcut (2.1 - 2.1) <D56F5E5E-A41F-36D1-ACD5-42EA7910B20F> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x94bd4000 - 0x94bdaffb com.apple.print.framework.Print (7.1 - 247.1) <5D7ADC17-D8EF-3958-9C0C-AA45B7717FBA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x94bdb000 - 0x94fddff6 libLAPACK.dylib (??? - ???) <00BE0221-8564-3F87-9F6B-8A910CF2F141> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x95017000 - 0x950bbfff com.apple.QD (3.40 - ???) <3881BEC6-0908-3073-BA44-346356E1CDF9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x95301000 - 0x9530efff libGL.dylib (??? - ???) <30E6DED6-0213-3A3B-B2B3-310E33301CCB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x954a9000 - 0x954b7fff com.apple.opengl (1.7.6 - 1.7.6) <5EF9685C-F8B2-3B22-B291-8012761E9AC8> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x95883000 - 0x95b3fff3 com.apple.security (7.0 - 55110) <2F4FCD65-2A30-3330-99DE-91FE1F78B9FB> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x95b40000 - 0x95b40ff2 com.apple.CoreServices (53 - 53) <7CB7AA95-D5A7-366A-BB8A-035AA9E582F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x95b90000 - 0x95caefec com.apple.vImage (5.1 - 5.1) <7757F253-B281-3612-89D4-F2B04061CBE1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x95caf000 - 0x95dc0ff7 libJP2.dylib (??? - ???) <143828CE-D429-3C66-A0DC-4F39536568E4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x95dc1000 - 0x95de6ff9 libJPEG.dylib (??? - ???) <743578F6-8C0C-39CC-9F15-3A01E1616EAE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x95de7000 - 0x962c3ff6 libBLAS.dylib (??? - ???) <134ABFC6-F29E-3DC5-8E57-E13CB6EF7B41> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x962c4000 - 0x962c7ff7 libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <7F6C14CC-0169-3F1B-B89C-372F67F1F3B5> /usr/lib/system/libcompiler_rt.dylib
0x96319000 - 0x9650eff7 com.apple.CoreData (104.1 - 358.13) <EB02DCA7-DB2A-32DD-B49E-ECE54D078610> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x9650f000 - 0x96794fe3 com.apple.QuickTime (7.7.1 - 2315) <E6249041-B569-3A96-897F-E84B1C057948> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x96795000 - 0x967b3ff7 libsystem_kernel.dylib (1699.22.73 - compatibility 1.0.0) <D32C2E9C-8184-3FAF-8694-99FC619FC71B> /usr/lib/system/libsystem_kernel.dylib
0x967b9000 - 0x967baff7 libquarantine.dylib (36.2.0 - compatibility 1.0.0) <3F974196-FBAD-3DBD-8ED0-DC16C2B3526B> /usr/lib/system/libquarantine.dylib
0x967bb000 - 0x967bbfff com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <22997C20-BEB7-301D-86C5-5BFB3B06D212> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x967bc000 - 0x967c4fff com.apple.DiskArbitration (2.4.1 - 2.4.1) <28D5D8B5-14E8-3DA1-9085-B9BC96835ACF> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x967c5000 - 0x968a8ff7 libcrypto.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <BD913D3B-388D-33AE-AA5E-4810C743C28F> /usr/lib/libcrypto.0.9.8.dylib
0x96a14000 - 0x96a29ff7 com.apple.ImageCapture (7.0 - 7.0) <116BC0CA-428E-396F-85DF-52793034D2A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x96a2a000 - 0x96d6effb com.apple.HIToolbox (1.8 - ???) <9540400F-B432-3116-AEAD-C1FBCFE67E73> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x96d6f000 - 0x96e7ffe7 libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <34E1E3CC-7B6A-3B37-8D07-1258D11E16CB> /usr/lib/libsqlite3.dylib
0x96e80000 - 0x96ee4fff com.apple.framework.IOKit (2.0 - ???) <8DAF4991-7359-3D1B-AC69-3CBA797D1E3C> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x96f21000 - 0x96f24ffc libpam.2.dylib (3.0.0 - compatibility 3.0.0) <6FFDBD60-5EC6-3EFA-996B-EE030443C16C> /usr/lib/libpam.2.dylib
0x96f25000 - 0x96f2affd libGFXShared.dylib (??? - ???) <179E77CE-C72C-3B5F-8F1E-3901517C24BB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x96f2b000 - 0x979beff6 com.apple.AppKit (6.7.3 - 1138.32) <008E7C05-C20C-344A-B51C-4A2441372785> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x979bf000 - 0x979c3ffa libcache.dylib (47.0.0 - compatibility 1.0.0) <98A82BC5-0DD9-3212-9CAE-35A77278EEB6> /usr/lib/system/libcache.dylib
0x979c4000 - 0x979c4fff com.apple.Accelerate (1.7 - Accelerate 1.7) <4192CE7A-BCE0-3D3C-AAF7-6F1B3C607386> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x979c5000 - 0x979ceff3 com.apple.CommonAuth (2.1 - 2.0) <5DA75D12-A4D6-3362-AD72-79A64C79669E> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x979cf000 - 0x979d2ffb com.apple.help (1.3.2 - 42) <DDCEBA10-5CDE-3ED2-A52F-5CD5A0632CA2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x979d3000 - 0x979d5ff7 libdyld.dylib (195.5.0 - compatibility 1.0.0) <637660EA-8D12-3B79-B644-041FEADC9C33> /usr/lib/system/libdyld.dylib
0x979fd000 - 0x97a01fff libGIF.dylib (??? - ???) <06E85451-F51C-31C4-B5A6-180819BD9738> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x97a02000 - 0x97a06fff com.apple.CommonPanels (1.2.5 - 94) <3A988595-DE53-34ED-9367-C9A737E2AF38> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x97e2e000 - 0x97f8fffb com.apple.QuartzCore (1.7 - 270.2) <4A6035C8-1237-37E5-9FFF-1EFD735D8B18> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x97f90000 - 0x97ffffff com.apple.Heimdal (2.1 - 2.0) <BCF7C3F1-23BE-315A-BBB6-5F01C79CF626> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x98156000 - 0x98225fff com.apple.ImageIO.framework (3.1.1 - 3.1.1) <D4D6EB78-8A6C-3474-921C-622C6951489B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x98226000 - 0x9822eff3 liblaunch.dylib (392.18.0 - compatibility 1.0.0) <CD470A1E-0147-3CB1-B44D-0B61F9061826> /usr/lib/system/liblaunch.dylib
0x9822f000 - 0x9835bff9 com.apple.CFNetwork (520.3.2 - 520.3.2) <58021CA7-0C91-3395-8278-8BD76E03BDCB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x9866a000 - 0x987bcfff com.apple.audio.toolbox.AudioToolbox (1.7.2 - 1.7.2) <E369AC9E-F548-3DF6-B320-9D09E486070E> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x987be000 - 0x987c8ff2 com.apple.audio.SoundManager (3.9.4.1 - 3.9.4.1) <2A089CE8-9760-3F0F-B77D-29A78940EA17> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x987c9000 - 0x987caff4 libremovefile.dylib (21.1.0 - compatibility 1.0.0) <6DE3FDC7-0BE0-3791-B6F5-C15422A8AFB8> /usr/lib/system/libremovefile.dylib
0x987cb000 - 0x990f35eb com.apple.CoreGraphics (1.600.0 - ???) <E285B0B6-F9FC-33BC-988F-ED619B32029C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x990f4000 - 0x9912aff7 com.apple.AE (527.7 - 527.7) <7BAFBF18-3997-3656-9823-FD3B455056A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x9912b000 - 0x9914efff com.apple.CoreVideo (1.7 - 70.1) <3520F013-DF91-364E-88CF-ED252A7BD0AE> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x9936b000 - 0x997e0ff7 FaceCoreLight (1.4.7 - compatibility 1.0.0) <312D0F58-B8E7-3F61-8A83-30C95F2EBEAA> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
0x997e2000 - 0x997edfff libkxld.dylib (??? - ???) <088640F2-429D-3368-AEDA-3C308C4EB80C> /usr/lib/system/libkxld.dylib
0x997ee000 - 0x9980affc libPng.dylib (??? - ???) <75F41C08-E187-354C-8115-79387F57FC2C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x9980b000 - 0x9986dff3 libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <266CE9B3-526A-3C41-BA58-7AE66A3B15FD> /usr/lib/libstdc++.6.dylib
0x9986e000 - 0x9986fff0 libunc.dylib (24.0.0 - compatibility 1.0.0) <BCD277D0-4271-3E96-A4A2-85669DBEE2E2> /usr/lib/system/libunc.dylib
0x99870000 - 0x99eebfe5 com.apple.CoreAUC (6.11.04 - 6.11.04) <B06D52C9-9F59-3EF2-B2BA-11E93C573572> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x99fe4000 - 0x9a034ff0 libTIFF.dylib (??? - ???) <F532A16A-7761-355C-8B7B-CEF988D8EEFF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x9a035000 - 0x9a0a9fff com.apple.CoreSymbolication (2.2 - 73.2) <FA9305CA-FB9B-3646-8C41-FF8DF15AB2C1> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x9a0e6000 - 0x9a0effff libc++abi.dylib (14.0.0 - compatibility 1.0.0) <FEB5330E-AD5D-37A0-8AB2-0820F311A2C8> /usr/lib/libc++abi.dylib
0x9a0f0000 - 0x9a152ffb com.apple.datadetectorscore (3.0 - 179.4) <32262124-6F75-3999-86DA-590A90BA464C> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x9a153000 - 0x9a15aff5 libsystem_dnssd.dylib (??? - ???) <B3217FA8-A7D6-3C90-ABFC-2E54AEF33547> /usr/lib/system/libsystem_dnssd.dylib
0x9a15b000 - 0x9a15eff9 libCGXType.A.dylib (600.0.0 - compatibility 64.0.0) <E06426D8-CC01-3754-B5B3-D15CBA5C8D73> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x9a43d000 - 0x9a471ff3 libTrueTypeScaler.dylib (??? - ???) <43479E0A-C47D-3CE3-B328-9CB33D3FC3B3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x9a5e3000 - 0x9a5f7ff7 com.apple.CFOpenDirectory (10.7 - 144) <665CDF77-F0C9-3AFF-8CF8-64257268B7DD> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x9a5f8000 - 0x9a623fff com.apple.GSS (2.1 - 2.0) <DA24E4F9-F9D4-3CDB-89E4-6EAA7A9F6005> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x9a624000 - 0x9a625ff7 libsystem_sandbox.dylib (??? - ???) <D272A77F-7F47-32CD-A36E-5A3FB966ED55> /usr/lib/system/libsystem_sandbox.dylib
0x9a64a000 - 0x9a678fe7 libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <07D9A827-9567-34C2-9022-AF4BF975C9A7> /usr/lib/libSystem.B.dylib
0x9a679000 - 0x9a691ff7 libexpat.1.dylib (7.2.0 - compatibility 7.0.0) <C7003CC0-28CA-3E04-9B9E-0A15138ED726> /usr/lib/libexpat.1.dylib
0x9a76a000 - 0x9a76effd IOSurface (??? - ???) <97E875C2-9F1A-3FBA-B80C-594892A02621> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x9a76f000 - 0x9a76fffe libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <7F0E8EE2-9E8F-366F-9988-E2F119DB9A82> /usr/lib/system/libkeymgr.dylib
0x9a770000 - 0x9a77efff libz.1.dylib (1.2.5 - compatibility 1.0.0) <E73A4025-835C-3F73-9853-B08606E892DB> /usr/lib/libz.1.dylib
0x9a77f000 - 0x9a809ffb com.apple.SearchKit (1.4.0 - 1.4.0) <CF074082-64AB-3A1F-831E-582DF1667827> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x9a8ff000 - 0x9a932fef libtidy.A.dylib (??? - ???) <E962D8EC-6B9D-35B7-B586-F07D92302ADD> /usr/lib/libtidy.A.dylib
0x9a975000 - 0x9a992fff libresolv.9.dylib (46.1.0 - compatibility 1.0.0) <2870320A-28DA-3B44-9D82-D56E0036F6BB> /usr/lib/libresolv.9.dylib
0x9a993000 - 0x9a9b0ff3 com.apple.openscripting (1.3.3 - ???) <31A51238-0CA1-38C7-9F0E-8A6676EE3241> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x9a9d8000 - 0x9aa31fff com.apple.HIServices (1.11 - ???) <F8B77735-B168-3E21-9B8F-921115B4C19B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x9ac7e000 - 0x9ac7ffff com.apple.TrustEvaluationAgent (2.0 - 1) <4BB39578-2F5E-3A50-AD59-9C0AB99472EB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x9acf0000 - 0x9acfefff libdispatch.dylib (187.7.0 - compatibility 1.0.0) <B50C62AD-0B5B-34C3-A491-ECFD72ED505E> /usr/lib/system/libdispatch.dylib
0x9ad24000 - 0x9ad2cff5 libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <A1BFC320-616A-30AA-A41E-29D7904FC4C7> /usr/lib/system/libcopyfile.dylib
0x9ad2d000 - 0x9ad2fff9 com.apple.securityhi (4.0 - 1) <BD367302-73C3-32F4-8080-E389AE89E434> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x9ad30000 - 0x9ba80feb com.apple.QuickTimeComponents.component (7.7.1 - 2315) <1826E4DB-15C2-3495-A278-A17ADEDB0A62> /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x9ba81000 - 0x9ba81fff com.apple.Cocoa (6.6 - ???) <650273EF-1ABC-334E-B745-B75AF028F9F4> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x9ba93000 - 0x9bee0ffb com.apple.RawCamera.bundle (3.9.1 - 586) <81E19AD7-A034-3A56-B74E-31EDBD663694> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x9bee1000 - 0x9bee5ff7 com.apple.OpenDirectory (10.7 - 146) <3D3D30CE-6D82-3681-AA98-4E3AEFFA4229> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x9c026000 - 0x9c06eff7 com.apple.SystemConfiguration (1.11.2 - 1.11) <CA077C0D-8A54-38DB-9690-5D222899B93D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x9c06f000 - 0x9c0fcfe7 libvMisc.dylib (325.4.0 - compatibility 1.0.0) <F2A8BBA3-6431-3CED-8CD3-0953410B6F96> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x9c0fd000 - 0x9c12bff7 com.apple.DictionaryServices (1.2.1 - 158.2) <DA16A8B2-F359-345A-BAF7-8E6A5A0741A1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x9c12c000 - 0x9c1ecffb com.apple.ColorSync (4.7.1 - 4.7.1) <68413C12-2380-3B73-AF74-B9E069DFB89A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x9c1ed000 - 0x9c2ddff1 libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <9E5F86A3-8405-3774-9E0C-3A074273C96D> /usr/lib/libiconv.2.dylib
0x9c386000 - 0x9c387ffd libCVMSPluginSupport.dylib (??? - ???) <6C364E11-B9B3-351A-B297-DB06FBAAFFD1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x9c388000 - 0x9c45eaab libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <2E272DCA-38A0-3530-BBF4-47AE678D20D4> /usr/lib/libobjc.A.dylib
0x9c45f000 - 0x9c4bbfff com.apple.coreui (1.2.1 - 165.3) <65526A00-D355-3932-9279-9A7D6BF76D95> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x9c4bc000 - 0x9c4f9ff7 libcups.2.dylib (2.9.0 - compatibility 2.0.0) <4508AABD-EDA8-3BF7-B03A-978D2395C9A8> /usr/lib/libcups.2.dylib
0x9c4fa000 - 0x9c516ff5 com.apple.GenerationalStorage (1.0 - 126.1) <E622F823-7D98-3D13-9C3D-7EA482567394> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x9c5ae000 - 0x9c762ff3 libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <6AD14A51-AEA8-3732-B07B-DEA37577E13A> /usr/lib/libicucore.A.dylib
0x9c763000 - 0x9c763fff com.apple.audio.units.AudioUnit (1.7.2 - 1.7.2) <2E71E880-25D1-3210-8D26-21EC47ED810C> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x9c7e9000 - 0x9c811ff7 libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <FCAC685A-724F-3FE7-8416-146108DF75FB> /usr/lib/libxslt.1.dylib
0x9c812000 - 0x9c834ff1 com.apple.PerformanceAnalysis (1.10 - 10) <45B10D4C-9B3B-37A6-982D-687A6F9EEA28> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x9c835000 - 0x9c840ffe libbz2.1.0.dylib (1.0.5 - compatibility 1.0.0) <4A7FCD28-9C09-3120-980A-BDF6EDFAAC62> /usr/lib/libbz2.1.0.dylib
0x9cd24000 - 0x9cd3efff com.apple.Kerberos (1.0 - 1) <D7920A1C-FEC4-3460-8DD0-D02491578CBB> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x9cd3f000 - 0x9cd50fff libbsm.0.dylib (??? - ???) <54ACF696-87C6-3652-808A-17BE7275C230> /usr/lib/libbsm.0.dylib
0x9cd51000 - 0x9cda2ff9 com.apple.ScalableUserInterface (1.0 - 1) <C3FA7E40-0213-3ABC-A006-2CB00B6A7EAB> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
0x9cda3000 - 0x9cddfffa libGLImage.dylib (??? - ???) <05B36DC4-6B90-33E6-AE6A-10CAA1B70606> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0xba300000 - 0xba301ffb libCyrillicConverter.dylib (54.0.0 - compatibility 1.0.0) <F098D5D3-D551-3E69-8261-208A9091BBF0> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
0xba900000 - 0xba91bffd libJapaneseConverter.dylib (54.0.0 - compatibility 1.0.0) <5635DF40-8D8E-3B8C-B075-7B3FC0F184A4> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0xbab00000 - 0xbab21ff6 libKoreanConverter.dylib (54.0.0 - compatibility 1.0.0) <17226124-8E8A-34EB-A2C4-D4A0469CF45B> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
0xbad00000 - 0xbad01fff libLatin2Converter.dylib (54.0.0 - compatibility 1.0.0) <0037D2B3-EDF4-3A68-B8CC-4A519EBF9029> /System/Library/CoreServices/Encodings/libLatin2Converter.dylib
0xeab00000 - 0xeab10ff3 libConverter.dylib (179.0.0 - compatibility 1.0.0) <7C3B724B-D38D-3070-A7D7-6FC0A8E4B0D1> /System/Library/Printers/Libraries/libConverter.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 5
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 2766
thread_create: 1
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=178.1M resident=64.4M(36%) swapped_out_or_unallocated=113.7M(64%)
Writable regions: Total=3.3G written=3.2G(95%) resident=3.2G(96%) swapped_out=0K(0%) unallocated=127.6M(4%)
REGION TYPE VIRTUAL
ATS (font support) 34.7M
CG backing stores 24.9M
CG raster data 272K
CG shared images 3448K
CoreGraphics 8K
CoreServices 6088K
MALLOC 3.2G
MALLOC guard page 48K
Memory tag=240 4K
Memory tag=242 12K
Memory tag=249 192K
Stack 66.0M
VM_ALLOCATE 16.2M
__CI_BITMAP 80K
__DATA 14.1M
__DATA/__OBJC 128K
__IMAGE 528K
__IMPORT 72K
__LINKEDIT 44.3M
__OBJC 1600K
__OBJC/__DATA 56K
__PAGEZERO 4K
__RC_CAMERAS 232K
__TEXT 133.8M
__UNICODE 544K
mapped file 133.6M
shared memory 2432K
shared pmap 8516K
TOTAL 3.7G
Model: iMac11,3, BootROM IM112.0057.B01, 4 processors, Intel Core i7, 2.93 GHz, 8 GB, SMC 1.59f2
Graphics: ATI Radeon HD 5750, ATI Radeon HD 5750, PCIe, 1024 MB
Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1333 MHz, 0x029E, 0x434D534F324758334D314131333333433920
Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353637334648302D4348392020
Memory Module: BANK 0/DIMM1, 2 GB, DDR3, 1333 MHz, 0x029E, 0x434D534F324758334D314131333333433920
Memory Module: BANK 1/DIMM1, 2 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353637334648302D4348392020
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x8F), Atheros 9280: 4.0.61.4-P2P
Bluetooth: Version 4.0.3f12, 2 service, 18 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Serial ATA Device: ST31000528AS, 1 TB
Serial ATA Device: HL-DT-STDVDRW GA32N
Serial ATA Device: C300-CTFDDAC256MAG, 256.06 GB
USB Device: hub_device, 0x0424 (SMSC), 0x2514, 0xfa100000 / 2
USB Device: USB Audio, 0x0d8c (C-MEDIA ELECTRONICS INC.), 0x0006, 0xfa130000 / 6
USB Device: Ext HDD 1021, 0x1058 (Western Digital Technologies, Inc.), 0x1021, 0xfa140000 / 5
USB Device: Internal Memory Card Reader, apple_vendor_id, 0x8403, 0xfa120000 / 4
USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0xfa110000 / 3
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8215, 0xfa111000 / 8
USB Device: hub_device, 0x0424 (SMSC), 0x2514, 0xfd100000 / 2
USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd120000 / 3
USB Device: Generic USB Hub, 0x058f (Alcor Micro, Corp.), 0x9254, 0xfd140000 / 5
USB Device: Controller, 0x045e (Microsoft Corporation), 0x028e, 0xfd141000 / 6
USB Device: Built-in iSight, apple_vendor_id, 0x8502, 0xfd110000 / 4
FireWire Device: My Book Device, WD, 800mbit_speed
FireWire Device: FW 410, M-AUDIO, 400mbit_speed
simon201
Re: Metro Crashing on startup
Postby Jerm » Tue Feb 21, 2012 7:12 pm
From the crash log, it looks like it is crashing deep within CoreAudio. Metro is simply querying a property when the crash occurs. So perhaps you have a Lion incompatible device driver. If you are not using the built-in device you could try removing the Metro preferences file from library/preferences. I believe under Lion they made that folder difficult to access so search this forum for a solution to that if need be.
Postby matro » Mon Mar 30, 2015 5:56 pm
When I recently upgraded from Mountain Lion to Yosemete, my Metro 6.5.x stopped launching.
So I just upgraded Metro to 7.2.4 and and it still doesn't launch. I tried taking out plugins, also then put them back and deleted preferences. No luck.
When I click on the link in my dock, the dock restarts.
When I click on the link from a finder window, finder restarts.
Here's my system log:
3/30/15 3:53:12.323 PM diagnosticd[100]: error evaluating process info - pid: 1001, punique: 1001
3/30/15 3:53:14.174 PM garcon[1006]: host connection <NSXPCConnection: 0x60000010d380> connection from pid 1001 invalidated
3/30/15 3:53:14.185 PM FinderSyncAPIExtension[1007]: host connection <NSXPCConnection: 0x608000118420> connection from pid 1001 invalidated
3/30/15 3:53:14.255 PM com.apple.xpc.launchd[1]: (com.apple.Finder[1001]) Service exited due to signal: Segmentation fault: 11
3/30/15 3:53:14.277 PM ReportCrash[999]: Saved crash report for Finder[1001] version 10.10.2 (10.10.2) to /Users/matthewkeogh/Library/Logs/DiagnosticReports/Finder_2015-03-30-155314_mkmpb.crash
3/30/15 3:53:14.553 PM Finder[1016]: assertion failed: 14C1514: libxpc.dylib + 97940 [876216DC-D5D3-381E-8AF9-49AE464E5107]: 0x89
3/30/15 3:53:14.566 PM pkd[456]: enabling pid=1016 for plug-in com.google.GoogleDrive.FinderSyncAPIExtension(1) F49C46AC-4497-4D13-BAC0-5D19DCBFE99F /Applications/Google Drive.app/Contents/PlugIns/FinderSyncAPIExtension.appex
3/30/15 3:53:14.573 PM pkd[456]: enabling pid=1016 for plug-in com.getdropbox.dropbox.garcon(1.8) A29A581B-36F4-4390-B10E-FCB25D07D414 /Applications/Dropbox.app/Contents/PlugIns/garcon.appex
3/30/15 3:53:14.645 PM taskgated[86]: no application identifier provided, can't use provisioning profiles [pid=1018]
3/30/15 3:53:14.647 PM taskgated[86]: no application identifier provided, can't use provisioning profiles [pid=1019]
3/30/15 3:53:14.737 PM FinderSyncAPIExtension[1018]: Loading Google Drive Finder extension
3/30/15 3:53:14.744 PM FinderSyncAPIExtension[1018]: The Finder version 1.0 is not supported by Google Drive!
3/30/15 3:53:14.820 PM garcon[1019]: Failed to connect (colorGridView) outlet from (NSApplication) to (NSColorPickerGridView): missing setter or instance variable
3/30/15 3:53:14.820 PM garcon[1019]: Failed to connect (view) outlet from (NSApplication) to (NSColorPickerGridView): missing setter or instance variable
3/30/15 3:53:14.842 PM FinderSyncAPIExtension[1018]: Failed to connect (colorGridView) outlet from (NSApplication) to (NSColorPickerGridView): missing setter or instance variable
3/30/15 3:53:14.842 PM FinderSyncAPIExtension[1018]: Failed to connect (view) outlet from (NSApplication) to (NSColorPickerGridView): missing setter or instance variable
3/30/15 3:53:14.000 PM kernel[0]: Sandbox: appleeventsd(29) deny file-read-metadata /Library
(repeated a bunch)
3/30/15 3:53:14.000 PM kernel[0]: Sandbox: appleeventsd(29) deny mach-lookup com.apple.ocspd
(repeated a bunch)
(repeated a bunch)
(repeated a bunch)
3/30/15 3:53:14.912 PM sandboxd[268]: ([29]) appleeventsd(29) deny file-read-metadata /Library/Preferences/com.apple.security-common.plist
3/30/15 3:53:14.951 PM sandboxd[268]: ([29]) appleeventsd(29) deny file-read-data /Library/Preferences/com.apple.security-common.plist
3/30/15 3:53:14.960 PM sandboxd[268]: ([29]) appleeventsd(29) deny file-read-metadata /Library
(repeated a bunch)
3/30/15 3:53:15.147 PM sandboxd[268]: ([29]) appleeventsd(29) deny file-read-metadata /Library
3/30/15 3:53:15.181 PM FinderSyncAPIExtension[1018]: Pipe path is a symbolic link, connecting to target.
3/30/15 3:53:15.183 PM FinderSyncAPIExtension[1018]: /Users/matthewkeogh/Library/Application Support/Google/Drive/GoogleDriveIpcPipe is a symbolic link to /Users/matthewkeogh/Library/Group Containers/gdrive/tmprZSlna, connecting to link target.
3/30/15 3:53:15.423 PM garcon[1019]: Initialized badges.
3/30/15 3:53:15.424 PM garcon[1019]: Connecting to Dropbox on 'com.getdropbox.dropbox.garcon.cafe_505'
3/30/15 3:53:15.442 PM garcon[1019]: Connected to Dropbox on 'com.getdropbox.dropbox.garcon.cafe_505'.
3/30/15 3:53:15.444 PM garcon[1019]: Invalidating watch set.
3/30/15 3:53:15.452 PM garcon[1019]: Watch set is now: {(
file:///Users/matthewkeogh/Dropbox/
3/30/15 3:53:18.107 PM apsd[61]: Failed entitlement check 'com.apple.private.aps-connection-initiate' for ManagedClientAgent[1021]
3/30/15 3:53:18.107 PM apsd[61]: Peer connection [pid=1021] lacks APSConnectionInitiateEntitlement
3/30/15 3:53:18.111 PM com.apple.xpc.launchd[1]: (com.apple.PubSub.Agent[1022]) Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.pubsub.ipc
3/30/15 3:53:18.111 PM com.apple.xpc.launchd[1]: (com.apple.PubSub.Agent[1022]) Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.pubsub.notification
3/30/15 3:53:19.252 PM WindowServer[252]: disable_update_timeout: UI updates were forcibly disabled by application "Finder" for over 1.00 seconds. Server has re-enabled them.
3/30/15 3:53:20.219 PM WindowServer[252]: common_reenable_update: UI updates were finally reenabled by application "Finder" after 1.97 seconds (server forcibly re-enabled them after 1.00 seconds)
3/30/15 3:53:21.270 PM ManagedClientAgent[1021]: No Device Enrollment record info was found
3/30/15 3:53:21.990 PM Finder[1016]: Attempt to use XPC with a MachService that has HideUntilCheckIn set. This will result in unpredictable behavior: com.apple.backupd.status.xpc
Thanks!
matro
Postby matro » Mon Mar 30, 2015 5:57 pm
(I guess finder isn't crashing, but I thought it was)
matro
Postby Jerm » Mon Mar 30, 2015 6:10 pm
I will need more information to diagnose this problem. When you try to launch, what exactly happens? If it crashes, please post or email me the crash log. Have you enabled non-apple store applications?
Postby Jerm » Mon Mar 30, 2015 6:57 pm
It also might be a permissions issue. See this.
Postby matro » Mon Mar 30, 2015 7:47 pm
Thanks for your quick response!
I had it set to App store and identified developers, tried it with anywhere selected and the same thing... it doesn't launch. It seems to crash the dock and do nothing in finder.
I think this is the log, right?
3/33/30/15 4:55:57.078 PM diagnosticd[100]: error evaluating process info - pid: 1130, punique: 1130
3/30/15 4:56:01.729 PM FinderSyncAPIExtension[1135]: host connection <NSXPCConnection: 0x600000114d00> connection from pid 1130 invalidated
3/30/15 4:56:01.734 PM garcon[1134]: host connection <NSXPCConnection: 0x608000101710> connection from pid 1130 invalidated
3/30/15 4:56:01.841 PM com.apple.xpc.launchd[1]: (com.apple.Finder[1130]) Service exited due to signal: Segmentation fault: 11
3/30/15 4:56:02.154 PM ReportCrash[1150]: Saved crash report for Finder[1130] version 10.10.2 (10.10.2) to /Users/matthewkeogh/Library/Logs/DiagnosticReports/Finder_2015-03-30-165602_mkmpb.crash
3/30/15 4:56:02.201 PM Finder[1151]: assertion failed: 14C1514: libxpc.dylib + 97940 [876216DC-D5D3-381E-8AF9-49AE464E5107]: 0x89
3/30/15 4:56:02.218 PM pkd[456]: enabling pid=1151 for plug-in com.google.GoogleDrive.FinderSyncAPIExtension(1) F49C46AC-4497-4D13-BAC0-5D19DCBFE99F /Applications/Google Drive.app/Contents/PlugIns/FinderSyncAPIExtension.appex
3/30/15 4:56:02.220 PM pkd[456]: enabling pid=1151 for plug-in com.getdropbox.dropbox.garcon(1.8) A29A581B-36F4-4390-B10E-FCB25D07D414 /Applications/Dropbox.app/Contents/PlugIns/garcon.appex
3/30/15 4:56:02.286 PM taskgated[86]: no application identifier provided, can't use provisioning profiles [pid=1156]
3/30/15 4:56:02.290 PM taskgated[86]: no application identifier provided, can't use provisioning profiles [pid=1157]
3/30/15 4:56:02.311 PM com.apple.xpc.launchd[1]: (com.apple.imfoundation.IMRemoteURLConnectionAgent) The _DirtyJetsamMemoryLimit key is not available on this platform.
3/30/15 4:56:02.393 PM FinderSyncAPIExtension[1156]: Loading Google Drive Finder extension
3/30/15 4:56:02.401 PM FinderSyncAPIExtension[1156]: The Finder version 1.0 is not supported by Google Drive!
3/30/15 4:56:02.520 PM garcon[1157]: Failed to connect (colorGridView) outlet from (NSApplication) to (NSColorPickerGridView): missing setter or instance variable
3/30/15 4:56:02.520 PM FinderSyncAPIExtension[1156]: Failed to connect (colorGridView) outlet from (NSApplication) to (NSColorPickerGridView): missing setter or instance variable
3/30/15 4:56:02.520 PM garcon[1157]: Failed to connect (view) outlet from (NSApplication) to (NSColorPickerGridView): missing setter or instance variable
3/30/15 4:56:02.520 PM FinderSyncAPIExtension[1156]: Failed to connect (view) outlet from (NSApplication) to (NSColorPickerGridView): missing setter or instance variable
3/30/15 4:56:02.000 PM kernel[0]: Sandbox: appleeventsd(29) deny file-read-metadata /Library/Preferences/com.apple.security-common.plist
3/30/15 4:56:02.000 PM kernel[0]: Sandbox: appleeventsd(29) deny file-read-data /Library/Preferences/com.apple.security-common.plist
3/30/15 4:56:02.000 PM kernel[0]: Sandbox: appleeventsd(29) deny mach-lookup com.apple.ocspd
3/30/15 4:56:02.900 PM FinderSyncAPIExtension[1156]: Pipe path is a symbolic link, connecting to target.
matro
Postby Jerm » Mon Mar 30, 2015 8:49 pm
Your log info has a duration of only a couple of seconds. Try doing this:
*From your utilities folder, Launch the terminal program
* in the finder, navigate to the Metro Icon
* right click it and select 'show package contents'
* open the contents folder and then the Mac OS folder
* drag the Metro inside of the Mac OS folder to the terminal window
* switch to the terminal app and press enter
Post everything in the terminal window to this forum.
Postby matro » Tue Mar 31, 2015 12:36 am
OK, I did that and the program launched and got to the qualify screen, but after I checked my email and went to paste in the name, the app must have crashed (no error boxes).
Here's what terminal had to say:
mkmpb:~ matthewkeogh$ /Applications/Metro\ Folder/Metro.app/Contents/MacOS/Metro
Mar 30 22:24:18 mkmpb.local Metro[1527] <Error>: ImageIO: CreateMetadataFromXMPBufferInternal Threw error #203 (Duplicate property or field node)
FontPanelDisable
SpellSupportDisable
TaskAutoscroll
FontPanelEnable
TaskDefault
Mmkmpb:~ matthewkeogh$ M
Thanks again for the help!
matro
Postby Jerm » Tue Mar 31, 2015 1:01 am
Can you post the crash log from the console program? Did you try running again? Do you have any virus software or other security type software? Did you 'repair permissions' with disk utility?
Postby matro » Tue Mar 31, 2015 1:28 am
No antivirus installed. After repairing permissions (a little minor stuff) still doesn't launch unless I try from terminal.
When I clicked on it normally, it looked like it was starting to open but then the finder crashed. I had restarted and tried earlier.
The square that zooms in/enlarges around the app began to appear around the app for a second. It didn't get to a title screen that way.
Here's the error log from that first crash after sending qualifying info...
3/30/15 10:22:19.341 PM com.apple.dock.ecti[1498]: Failed to connect (textField) outlet from (ECTIHelperApp) to (NSTextField): missing setter or instance variable
3/30/15 10:22:28.579 PM login[1505]: USER_PROCESS: 1505 ttys000
3/30/15 10:22:28.674 PM iconservicesagent[1510]: iconservicesagent launched.
3/30/15 10:22:28.687 PM iconservicesagent[1510]: Starting service with cache path: /var/folders/pw/50tmw2zn08v77g6tz9zntn8r0000gs/C/com.apple.iconservices
3/30/15 10:22:28.735 PM iconservicesd[1511]: iconservicesd launched.
3/30/15 10:22:28.736 PM iconservicesd[1511]: Cache path: /Library/Caches/com.apple.iconservices.store
3/30/15 10:23:10.824 PM com.apple.xpc.launchd[1]: (com.apple.imfoundation.IMRemoteURLConnectionAgent) The _DirtyJetsamMemoryLimit key is not available on this platform.
3/30/15 10:23:16.749 PM com.apple.xpc.launchd[1]: (com.apple.quicklook[1514]) Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.quicklook
3/30/15 10:23:17.639 PM QuickLookSatellite[1515]: CGSConnectionByID: 0 is not a valid connection ID.
3/30/15 10:23:17.640 PM QuickLookSatellite[1515]: Invalid Connection ID 0
3/30/15 10:23:17.000 PM kernel[0]: Sandbox: QuickLookSatelli(1515) deny file-read-data /Users/matthewkeogh/Library/Preferences/com.apple.security.revocation.plist
3/30/15 10:23:17.824 PM QuickLookSatellite[1515]: CGSConnectionByID: 0 is not a valid connection ID.
3/30/15 10:23:17.825 PM QuickLookSatellite[1515]: CGSConnectionByID: 0 is not a valid connection ID.
3/30/15 10:23:22.627 PM QuickLookSatellite[1515]: In -[NSApplication(NSQuietSafeQuit) _updateCanQuitQuietlyAndSafely], _LSSetApplicationInformationItem(NSCanQuitQuietlyAndSafely) returned error -50
3/30/15 10:23:36.614 PM mdworker[1519]: code validation failed in the process of getting signing information: Error Domain=NSOSStatusErrorDomain Code=-67062 "The operation couldn’t be completed. (OSStatus error -67062.)"
3/30/15 10:23:36.632 PM mdworker[1519]: code validation failed in the process of getting signing information: Error Domain=NSOSStatusErrorDomain Code=-67062 "The operation couldn’t be completed. (OSStatus error -67062.)"
3/30/15 10:23:56.000 PM kernel[0]: nspace-handler-set-snapshot-time: 1427779438
3/30/15 10:23:56.618 PM com.apple.mtmd[26]: Set snapshot time: 2015-03-30 22:23:58 -0700 (current time: 2015-03-30 22:23:56 -0700)
3/30/15 10:24:06.000 PM kernel[0]: Google Chrome He (map: 0xffffff8038b33f00) triggered DYLD shared region unnest for map: 0xffffff8038b33f00, region 0x7fff94400000->0x7fff94600000. While not abnormal for debuggers, this increases system memory footprint until the target exits.
3/30/15 10:24:07.743 PM login[1505]: DEAD_PROCESS: 1505 ttys000
3/30/15 10:24:12.093 PM login[1522]: USER_PROCESS: 1522 ttys000
3/30/15 10:24:14.636 PM apsd[61]: Failed entitlement check 'com.apple.private.aps-connection-initiate' for ManagedClientAgent[1526]
3/30/15 10:24:14.637 PM apsd[61]: Peer connection [pid=1526] lacks APSConnectionInitiateEntitlement
3/30/15 10:24:17.077 PM Metro[1527]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.2 instead of 10.10.2. Use NSProcessInfo's operatingSystemVersion property to get correct system version number.
Call location:
3/30/15 10:24:17.082 PM Metro[1527]: 0 CarbonCore 0x954787c7 ___Gestalt_SystemVersion_block_invoke + 135
3/30/15 10:24:17.082 PM Metro[1527]: 1 libdispatch.dylib 0x96ecc0b5 dispatch_once_f + 251
3/30/15 10:24:17.082 PM Metro[1527]: 2 libdispatch.dylib 0x96ecd0d8 dispatch_once + 31
3/30/15 10:24:17.082 PM Metro[1527]: 3 CarbonCore 0x9540ae88 _Gestalt_SystemVersion + 1050
3/30/15 10:24:17.083 PM Metro[1527]: 4 CarbonCore 0x9540aa39 Gestalt + 150
3/30/15 10:24:17.083 PM Metro[1527]: 5 Metro 0x00061c7c Metro + 396412
3/30/15 10:24:17.083 PM Metro[1527]: 6 Metro 0x00063690 Metro + 403088
3/30/15 10:24:18.084 PM ManagedClientAgent[1526]: No Device Enrollment record info was found
3/30/15 10:24:18.764 PM Metro[1527]: ImageIO: CreateMetadataFromXMPBufferInternal Threw error #203 (Duplicate property or field node)
3/30/15 10:24:31.345 PM com.apple.backupd-helper[1449]: Attempt to use XPC with a MachService that has HideUntilCheckIn set. This will result in unpredictable behavior: com.apple.backupd.status.xpc
matro
Postby Jerm » Tue Mar 31, 2015 1:56 am
That is not a crash log. That is just console output. In the console program there should be a folder called 'crash reporter' or something.
Postby matro » Wed Apr 01, 2015 12:07 am
I couldn't find a recent crash log anywhere in the side options of Console so I went inside the Metro app contents/Mac Os folder launched the executable.
It seemed to be working for a minute (I saw my midi input levels), but when I tried to open a file, it crashed before the dialog box opened.
It did give me a crash report though...
Process: Metro [8194]
Path: /Applications/Metro Folder/Metro.app/Contents/MacOS/Metro
Identifier: biz.sagantech.Metro
Version: 7.2.4 (6.0)
Code Type: X86 (Native)
Parent Process: bash [8191]
Responsible: Terminal [336]
User ID: 505
Date/Time: 2015-03-31 21:56:49.771 -0700
OS Version: Mac OS X 10.10.2 (14C1514)
Report Version: 11
Anonymous UUID: 17D2EBF9-76E4-9D2E-E8F4-7D778BC55D95
Time Awake Since Boot: 44000 seconds
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
VM Regions Near 0:
__TEXT 0000000000001000-00000000002e3000 [ 2952K] r-x/rwx SM=COW /Applications/Metro Folder/Metro.app/Contents/MacOS/Metro
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.apple.CoreFoundation 0x95ace542 CFStringGetLength + 18
1 com.apple.CoreFoundation 0x95c0f0dc _CFURLCreateWithFileSystemPath + 60
2 com.apple.CoreFoundation 0x95acfcd8 CFURLCreateWithFileSystemPath + 40
3 com.apple.AppKit 0x92ef0799 _NSNavCustomControl + 3105
4 com.apple.NavigationServices 0x957238a1 NavCustomControl + 50
5 biz.sagantech.Metro 0x0004d1b8 0x1000 + 311736
6 com.apple.AppKit 0x92ef30a4 -[NSNavSavePanel sendCBEvent:withData:] + 1460
7 com.apple.AppKit 0x92ef106e -[NSNavSavePanel _popupSelectionAction:] + 230
8 com.apple.AppKit 0x92eed097 -[NSNavCustomView selectFirstNavPopupMenuItem] + 177
9 com.apple.AppKit 0x92eefb0a -[NSNavSavePanel willBecomeVisibleNotification:] + 486
10 com.apple.Foundation 0x9896b213 __57-[NSNotificationCenter addObserver:selector:name:object:]_block_invoke + 50
11 com.apple.CoreFoundation 0x95beb714 __CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER__ + 20
12 com.apple.CoreFoundation 0x95acc451 _CFXNotificationPost + 3713
13 com.apple.Foundation 0x98959134 -[NSNotificationCenter postNotificationName:object:userInfo:] + 92
14 com.apple.Foundation 0x989779a2 -[NSNotificationCenter postNotificationName:object:] + 56
15 com.apple.AppKit 0x9279bf2c -[NSWindow _reallyDoOrderWindow:relativeTo:findKey:forCounter:force:isModal:] + 1776
16 com.apple.AppKit 0x92ef437b -[NSNavSavePanel _reallyDoOrderWindow:relativeTo:findKey:forCounter:force:isModal:] + 525
17 com.apple.AppKit 0x9279b827 -[NSWindow _doOrderWindowWithoutAnimation:relativeTo:findKey:forCounter:force:isModal:] + 81
18 com.apple.AppKit 0x9279b56b -[NSWindow _doOrderWindow:relativeTo:findKey:forCounter:force:isModal:] + 856
19 com.apple.AppKit 0x92991b45 -[NSApplication _orderFrontModalWindow:relativeToWindow:] + 811
20 com.apple.AppKit 0x929914d1 -[NSApplication _commonBeginModalSessionForWindow:relativeToWindow:modalDelegate:didEndSelector:contextInfo:] + 913
21 com.apple.AppKit 0x9299b250 -[NSApplication beginModalSessionForWindow:] + 72
22 com.apple.AppKit 0x9299b0f9 -[NSApplication runModalForWindow:] + 138
23 com.apple.AppKit 0x92cae6cc -[NSSavePanel runModal] + 403
24 com.apple.AppKit 0x92cad8b0 -[NSSavePanel runModalForDirectory:file:types:] + 301
25 com.apple.AppKit 0x92ef4645 -[NSNavOpenPanel run] + 244
26 com.apple.AppKit 0x92ef8dbb _NSNavDialogRun + 168
27 com.apple.NavigationServices 0x95723570 NavGetFile + 186
28 biz.sagantech.Metro 0x0004d671 0x1000 + 312945
29 biz.sagantech.Metro 0x00050169 0x1000 + 323945
30 biz.sagantech.Metro 0x00011a5f 0x1000 + 68191
31 biz.sagantech.Metro 0x000399de 0x1000 + 231902
32 biz.sagantech.Metro 0x0001324f 0x1000 + 74319
33 biz.sagantech.Metro 0x000ad7ff 0x1000 + 706559
34 biz.sagantech.Metro 0x000662e7 0x1000 + 414439
35 com.apple.HIToolbox 0x970e0624 _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
36 com.apple.HIToolbox 0x96f2a651 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2291
37 com.apple.HIToolbox 0x96f2962c SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 402
38 com.apple.HIToolbox 0x96f3ce65 SendEventToEventTarget + 88
39 com.apple.HIToolbox 0x970e04a2 SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 447
40 com.apple.HIToolbox 0x96fa11fc SendMenuCommandWithContextAndModifiers + 72
41 com.apple.HIToolbox 0x96fa11a8 SendMenuItemSelectedEvent + 207
42 com.apple.HIToolbox 0x96fa106c FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 145
43 com.apple.HIToolbox 0x97137c96 MenuSelectCore(MenuData*, Point, double, unsigned long, OpaqueMenuRef**, unsigned short*) + 775
44 com.apple.HIToolbox 0x971383de MenuSelect + 162
45 com.apple.HIToolbox 0x970e3e58 HIMenuBar::HandleMouseEvent(OpaqueEventRef*) + 96
46 com.apple.HIToolbox 0x970e3c56 HIMenuBar::HandleEvent(OpaqueEventHandlerCallRef*, OpaqueEventRef*) + 60
47 com.apple.HIToolbox 0x96f2acaf HIObject::EventHook(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 163
48 com.apple.HIToolbox 0x970e0624 _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
49 com.apple.HIToolbox 0x96f2a651 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2291
50 com.apple.HIToolbox 0x96f2962c SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 402
51 com.apple.HIToolbox 0x96f3ce65 SendEventToEventTarget + 88
52 com.apple.HIToolbox 0x96f5db30 ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 3294
53 com.apple.HIToolbox 0x96f2aa1b DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 3261
54 com.apple.HIToolbox 0x96f2962c SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 402
55 com.apple.HIToolbox 0x96f3ce65 SendEventToEventTarget + 88
56 com.apple.HIToolbox 0x970dfd05 ToolboxEventDispatcher + 82
57 com.apple.HIToolbox 0x970dfbc9 RunApplicationEventLoop + 240
58 biz.sagantech.Metro 0x000abf26 0x1000 + 700198
59 biz.sagantech.Metro 0x00002952 0x1000 + 6482
60 biz.sagantech.Metro 0x00002879 0x1000 + 6265
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x911a48ce kevent64 + 10
1 libdispatch.dylib 0x96ecf73f _dispatch_mgr_invoke + 245
2 libdispatch.dylib 0x96ecf3a2 _dispatch_mgr_thread + 52
Thread 2:
0 libsystem_kernel.dylib 0x911a3512 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x9c20fabe _pthread_cond_wait + 842
2 libsystem_pthread.dylib 0x9c20fce1 pthread_cond_timedwait_relative_np + 47
3 com.apple.CoreServices.CarbonCore 0x954b42f6 TSWaitOnConditionTimedRelative + 167
4 com.apple.CoreServices.CarbonCore 0x954b3e55 TSWaitOnSemaphoreCommon + 499
5 com.apple.CoreServices.CarbonCore 0x954b4050 TSWaitOnSemaphoreRelative + 24
6 com.apple.CoreServices.CarbonCore 0x9549431c TimerThread + 93
7 libsystem_pthread.dylib 0x9c20ee13 _pthread_body + 138
8 libsystem_pthread.dylib 0x9c20ed89 _pthread_start + 162
9 libsystem_pthread.dylib 0x9c20ce52 thread_start + 34
Thread 3:
0 libsystem_kernel.dylib 0x9119d9ce mach_msg_trap + 10
1 libsystem_kernel.dylib 0x9119ca70 mach_msg + 68
2 com.apple.audio.midi.CoreMIDI 0x003d1ab3 XServerMachPort::ReceiveMessage(int&, void*, int&) + 123
3 com.apple.audio.midi.CoreMIDI 0x003ee529 MIDIProcess::RunMIDIInThread() + 151
4 com.apple.audio.midi.CoreMIDI 0x003f2904 MIDIProcess::MIDIInPortThread::Run() + 24
5 com.apple.audio.midi.CoreMIDI 0x003d2e1b XThread::RunHelper(void*) + 17
6 com.apple.audio.midi.CoreMIDI 0x003d295c CAPThread::Entry(CAPThread*) + 134
Thread 4:
0 libsystem_kernel.dylib 0x911a3e6a __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x9c20f2b1 _pthread_wqthread + 939
2 libsystem_pthread.dylib 0x9c20ce2e start_wqthread + 30
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:: CVDisplayLink
3 com.apple.CoreVideo 0x9bb4465d CVDisplayLink::waitUntil(unsigned long long) + 285
4 com.apple.CoreVideo 0x9bb436f2 CVDisplayLink::runIOThread() + 674
5 com.apple.CoreVideo 0x9bb43439 startIOThread(void*) + 159
6 libsystem_pthread.dylib 0x9c20ee13 _pthread_body + 138
7 libsystem_pthread.dylib 0x9c20ed89 _pthread_start + 162
8 libsystem_pthread.dylib 0x9c20ce52 thread_start + 34
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0xdd267be7 ebx: 0x92eefb89 ecx: 0x00000000 edx: 0x00000000
edi: 0x95ace53e esi: 0x00000000 ebp: 0xbfffc378 esp: 0xbfffc360
ss: 0x00000023 efl: 0x00010286 eip: 0x95ace542 cs: 0x0000001b
ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f
cr2: 0x00000000
Logical CPU: 2
Error Code: 0x00000004
Trap Number: 14
(continued in next post, too many characters)
matro
Postby matro » Wed Apr 01, 2015 12:08 am
(continued)
Binary Images:
0x1000 - 0x2e2fe2 +biz.sagantech.Metro (7.2.4 - 6.0) <758178C7-858F-E3D8-49E2-D1FE85080526> /Applications/Metro Folder/Metro.app/Contents/MacOS/Metro
0x3c3000 - 0x3fcff7 com.apple.audio.midi.CoreMIDI (1.10 - 88) <9C73D6BB-F3A8-34AB-BF87-24088C71D014> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x41f000 - 0x448fff com.apple.audio.CoreAudioKit (1.6.6 - 1.6.6) <597AA516-9AC9-3B20-9E32-FF8BF662554A> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
0x45b000 - 0x472ffb libexpat.1.dylib (12) <751B1CA1-D871-37AA-BE43-4131FF8B7747> /usr/lib/libexpat.1.dylib
0x15cd000 - 0x15d0fef com.apple.LiveType.component (2.1.3 - 2.1.3) /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
0x172c000 - 0x172cff9 +cl_kernels (???) <27935449-6277-4074-BE7C-5C55E413371C> cl_kernels
0x1730000 - 0x1730ffb +cl_kernels (???) <4E368E1C-420A-4851-8211-5D5055874F84> cl_kernels
0x1760000 - 0x1761ffb ATSHI.dylib (375) <43D88214-DA8A-3ECA-906F-AC704FD0441E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
0x1773000 - 0x17d8fde com.apple.LiveType.framework (2.1.3 - 2.1.3) /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType
0x4ce1000 - 0x4cf3fff libTraditionalChineseConverter.dylib (64) <17B4AEB7-F556-3E48-84DE-F6E4BEC9BAFA> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
0x726a000 - 0x7355ff7 unorm8_bgra.dylib (2.4.5) <A9015D26-FCF1-3BCD-A052-54912C2ED206> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
0xa31a000 - 0xa31efff com.apple.CommonCocoaPanels (4.0 - 16) <37952A3F-5ABF-30CD-85B6-BB24BFF8525C> /System/Library/CoreServices/CommonCocoaPanels.bundle/Contents/MacOS/CommonCocoaPanels
0xa35b000 - 0xa36afff libSimplifiedChineseConverter.dylib (64) <68D79299-8F39-3AD1-8BCA-0A614F679DDA> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
0xa376000 - 0xa378ffb com.apple.MLTEFile (3.2.1 - 7) <BB33BCEE-D283-340B-AF1D-5D0524FE5954> /System/Library/CoreServices/MLTEFile.bundle/Contents/MacOS/MLTEFile
0xa47a000 - 0xa47efff com.apple.audio.AppleHDAHALPlugIn (269.25 - 269.25) <1C1933F4-E56F-36BD-AC8A-209C6543178C> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0xa493000 - 0xa493fff com.apple.quartzframework (1.5 - 1.5) <6D85B29E-D684-3DDE-8F02-D292D86A014F> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0xa5b0000 - 0xa5b1ff7 com.apple.AddressBook.ContactsData (9.0 - 1563) <126E9B88-D396-3E63-B48C-B46F41296EC7> /System/Library/PrivateFrameworks/ContactsData.framework/Versions/A/ContactsData
0xad85000 - 0xad90fff com.apple.IntlPreferences (2.0 - 150.1) <D36A70DB-B54F-37A3-9F8D-2B7562B6FF59> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
0xae21000 - 0xae33ff7 com.apple.FCP Uncompressed 422.component (2.0.2 - 6337.11) <658180EB-E040-34E4-BCB7-1DD0D6AAD2C4> /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
0xae38000 - 0xae42fff com.apple.DirectoryService.Framework (10.10 - 187) <49B89287-2162-3B96-A7FC-987AB78DD611> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0xaf9e000 - 0xafa4fff +biz.sagantech.SaganTech-Metronome (1.0.5 - 1.0.5) <829BF197-BD3B-97EB-1738-1CF7D5BE8EC6> /Applications/Metro Folder/*/SaganTech-Metronome
0xafbd000 - 0xafbdff0 +cl_kernels (???) <20765AF4-29B1-474D-94E6-2A54ECD31818> cl_kernels
0xafc5000 - 0xafd3fff com.apple.AddressBook.ContactsFoundation (9.0 - 1563) <6D7AED29-EA9A-36E6-826A-62A5EA01BE54> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
0xb410000 - 0xb449ff7 com.apple.QuickTimeFireWireDV.component (7.7.3 - 2890) <13B38C0C-7FF1-3F7B-9A5C-211638F2C460> /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
0xb454000 - 0xb465ff3 +net.telestream.license (1.1.0.1 -GC - 1.1.0.1 -GC) <31F542E7-D868-3FE7-985B-F28952FF84E2> /Library/Frameworks/TSLicense.framework/Versions/A/TSLicense
0xb476000 - 0xb48dfff +com.eSellerate.EWSMac67108872 (4.0.0.8 - 4.0.0.8) <B0C10E16-53DB-A83E-BB2D-319CEF2EC0FC> /Users/USER/Library/Frameworks/EWSMac-GC.framework/EWSMac-GC67108872
0xb49a000 - 0xb4baffb com.apple.addressbook.vCard (9.0 - 1563) <D2C15678-F4DC-3E12-9BD0-D3A439E9617A> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
0xb4d8000 - 0xb4dfff3 com.apple.phonenumbers (1.1.1 - 105) <19A59F22-DD76-345E-AF7B-96405D71DB5A> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
0xb4e6000 - 0xb4e8ff7 com.apple.SafariServices.framework (10600 - 10600.3.18) <6375C6B2-6F73-3B05-ABB6-F2B7E76E0279> /System/Library/PrivateFrameworks/SafariServices.framework/Versions/A/SafariServices
0xb4f0000 - 0xb4f3fff com.apple.AppleSystemInfo (3.1 - 3.1) <F3BD3065-65F8-31BC-A01E-A922E51FAACD> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0xbf94000 - 0xc284feb +org.perian.Perian (1.2.3 - 1.2.3) <722FFF4F-46EF-E5BE-70A6-42B5873D2B37> /Users/USER/Library/QuickTime/Perian.component/Contents/MacOS/Perian
0xc5ff000 - 0xc710ff7 +net.telestream.wmv.import (3.1.0.24 - 3.1.0.24) <6AC5940B-A623-3E3A-818E-6F5A191B2CAB> /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import
0xc7da000 - 0xca42fff com.apple.AddressBook.framework (9.0 - 1563) <B350506E-C8A2-35BC-9391-E49096F91393> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0xcbf6000 - 0xcce0ff7 com.apple.QuickLookUIFramework (5.0 - 675.13) <CB237A15-5CB5-38A8-91C1-DE32257B2D26> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0xcd64000 - 0xcd80ff7 com.apple.aps.framework (4.0 - 4.0) <115AA5F3-86DF-37AB-8546-3A63A3FD0507> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0xcd97000 - 0xcdc8ffb com.apple.securityinterface (10.0 - 55058) <95726911-E181-3115-8451-EE1FA35A2937> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0xcde7000 - 0xce47ff3 com.apple.QuickLookFramework (5.0 - 675.13) <B731ABD0-8B4A-350E-8EFF-5FD855622599> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0xce7f000 - 0xd3f2ff7 com.apple.QuartzComposer (5.1 - 325.1) <82DA95F6-1324-33A0-B253-3EBE1A3F5780> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0xd659000 - 0xd703ff7 com.apple.PDFKit (3.1 - 3.1) <A580FC1A-7796-3D6C-8D50-DE1993AD7175> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0xd754000 - 0xd77aff7 com.apple.quartzfilters (1.10.0 - 1.10.0) <5712F712-4A1C-35BF-AE1D-F55DA1D9877D> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0xd798000 - 0xda23fff com.apple.imageKit (2.6.1 - 840) <41498F5D-1BEB-3426-9DE1-C2B78D6C423D> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0xdbcb000 - 0xdc55ff3 com.apple.CorePDF (4.0 - 4) <DA26FFBC-901A-3EF5-AF2F-9699683CB185> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0xdc96000 - 0xdca0fff com.apple.DisplayServicesFW (2.9 - 372.1) <01C3D99D-7F75-3401-95E8-5175E028EE21> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0xdcaa000 - 0xdd02ff3 com.apple.ImageCaptureCore (6.0 - 6.0) <FC5102A0-87F5-39F7-9725-0C74749BF918> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0xdd2f000 - 0xdef4feb +net.telestream.wmv.advanced (3.1.0.24 - 3.1.0.24) <2C95E4A2-B342-31EA-91FC-90182E2FF9A6> /Library/QuickTime/Flip4Mac WMV Advanced.component/Contents/MacOS/Flip4Mac WMV Advanced
0xdf3f000 - 0xe01efc7 com.apple.AppleProResDecoder (3.0.5 - 6806.41) <28E1497B-A240-3C1F-97C1-1EADAE338020> /System/Library/QuickTime/AppleProResDecoder.component/Contents/MacOS/AppleProResDecoder
0xe029000 - 0xe096fff com.apple.AppleVAH264HW.component (3.0 - 3.0) <A075F7EC-1D36-37CC-8CEF-1E446A9AF2F0> /System/Library/QuickTime/AppleVAH264HW.component/Contents/MacOS/AppleVAH264HW
0xe159000 - 0xe161ff7 com.apple.AppleGVAHW.component (1.2 - 1) <34692F20-A16D-3152-9F4C-1E98A6060C48> /System/Library/QuickTime/AppleGVAHW.component/Contents/MacOS/AppleGVAHW
0xe168000 - 0xe29cfff com.apple.AppleGVAFramework (8.2.10 - 8.2.10) <1CAFF938-84B6-35CD-9805-C0D7B6056210> /System/Library/PrivateFrameworks/AppleGVA.framework/Versions/A/AppleGVA
0xe2ad000 - 0xe2dfff7 com.apple.AppleIntermediateCodec (2.0.2 - 6305.11) <29802E54-A127-3224-BBAB-8002477C4593> /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
0xe2e7000 - 0xe2ebff7 com.apple.AppleMPEG2Codec (1.0.2 - 220.1) <3B9D5E31-955C-3AAF-837A-D168F90A2176> /Library/QuickTime/AppleMPEG2Codec.component/Contents/MacOS/AppleMPEG2Codec
0xe2f0000 - 0xe30bff3 com.apple.applepixletvideo (1.2.31 - 1.2d31) <575EB52C-4270-3D4A-B9CB-ACC5872EDC9A> /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
0xef8f000 - 0xefd1ffb com.apple.CloudDocs (1.0 - 280.6) <5C3C95B5-C470-3C3C-969D-008A045F5284> /System/Library/PrivateFrameworks/CloudDocs.framework/CloudDocs
0xf012000 - 0xf012ff0 +cl_kernels (???) <E12E61CA-6987-4899-BAE1-46B5752947D3> cl_kernels
0xf0e4000 - 0xf0e4ffb +cl_kernels (???) <D39699DF-9402-44A6-B736-58281A5415F8> cl_kernels
0xf31a000 - 0xf31efff com.apple.LoginUICore (3.0 - 3.0) <919867AC-1E71-3702-A0A9-79DB28E26E6B> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0xf336000 - 0xf589fff com.apple.audio.units.Components (1.12 - 1.12) <F6F9FBFD-AD62-3933-8B5C-3FCF7A8645E9> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0xf684000 - 0xf68fff7 com.apple.AppleFSCompression (68.1.1 - 1.0) <51462B36-AAE0-3AF3-B882-5D74B0B61651> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0xf696000 - 0xf696ff7 libodfde.dylib (22) <A0BC85E8-EA17-32ED-AA45-8E7F0ABA2943> /usr/lib/libodfde.dylib
0xf70e000 - 0xf71bff3 libGPUSupport.dylib (11.1.1) <488C6CF4-10C0-3F1B-9C13-AFC5163EEC9C> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport.dylib
0x11ee7000 - 0x12218fff com.apple.FinderKit (1.3.2 - 1.3.2) <9E01E77B-36CC-3FAF-9A32-40175C86C91C> /System/Library/PrivateFrameworks/FinderKit.framework/FinderKit
0x1240c000 - 0x1246affb com.apple.Suggestions (4.0 - 165) <06A8826C-CE3E-3BDC-884A-463ACE91639C> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
0x1249e000 - 0x124e0ff7 com.apple.bom (14.0 - 193.6) <8A66E20C-4275-3861-9C2D-F2F804105FBB> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x124f2000 - 0x12522ff7 com.apple.framework.SystemAdministration (1.0 - 1.0) <00146784-3C0A-379F-AC70-D9285073D45C> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x14000000 - 0x1481effb libclh.dylib (4.0.3 - 4.0.3) <E361905B-2B9B-3715-A618-7A89320EE2D0> /System/Library/Extensions/GeForceTeslaGLDriver.bundle/Contents/MacOS/libclh.dylib
0x40000000 - 0x40365fff com.apple.driver.AppleIntelHDGraphicsGLDriver (10.0.19 - 10.0.0) <FAC1E100-5CB1-38D7-B21D-5B62BE358276> /System/Library/Extensions/AppleIntelHDGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHDGraphicsGLDriver
0x48000000 - 0x488f0fff com.apple.GeForceTeslaGLDriver (10.0.19 - 10.0.0) <B3E00313-2879-3640-8ACB-86D6FE3B974D> /System/Library/Extensions/GeForceTeslaGLDriver.bundle/Contents/MacOS/GeForceTeslaGLDriver
0x8feb1000 - 0x8fee4e03 dyld (353.2.1) <06B1254D-9BB9-327C-BA15-8F18FFF97586> /usr/lib/dyld
0x90008000 - 0x9005dff7 com.apple.htmlrendering (77 - 1.1.4) <B85A63B9-C9DD-3ECC-B5DC-E12533C7FDF9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x9005e000 - 0x90075fff libsystem_asl.dylib (267) <85BD88AD-618E-3325-AC31-10DBAB8E9AF3> /usr/lib/system/libsystem_asl.dylib
0x90076000 - 0x900b9fff libGLU.dylib (11.1.1) <2DC476EE-5C4F-3353-A916-39F2FDB5D6B1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x900ba000 - 0x904f5feb com.apple.vImage (8.0 - 8.0) <56F6B317-9D70-3DC5-9868-BB6D7CB6E55D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x904f8000 - 0x90541ffb libFontRegistry.dylib (134) <023BB8A2-8BBA-30DC-B0C2-A5F0AE3667D8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x90542000 - 0x90550ff7 libz.1.dylib (55) <DF3B8F77-8931-3A6B-8BDF-DB67315050E6> /usr/lib/libz.1.dylib
0x90551000 - 0x90553fff libsystem_configuration.dylib (699.1.5) <76B9BA28-179E-34FA-B10B-E625022A29CB> /usr/lib/system/libsystem_configuration.dylib
0x90554000 - 0x90ab0ff3 com.apple.MediaToolbox (1.0 - 1562.107) <AA1B8DFA-C1C3-3610-BBFD-3C26E063168F> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x90abe000 - 0x90acffff libbsm.0.dylib (34) <C9F0C608-2794-3F6B-8078-583FC0046039> /usr/lib/libbsm.0.dylib
0x90ad0000 - 0x90b6dfff com.apple.ink.framework (10.9 - 213) <F47949BC-ABEE-329B-B568-71C6FEF761F6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x90b6e000 - 0x90b94ff7 com.apple.IconServices (47.1 - 47.1) <9C537499-B375-3F84-BF4A-EEF757FC26A9> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x90b95000 - 0x90b97fff com.apple.SecCodeWrapper (4.0 - 238.10.1) <0622F76C-3C56-3ABD-924E-FBC75E7E6445> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x90b98000 - 0x90ef0ff7 libmecabra.dylib (666.2) <DB0D4D7E-AA7B-3D2D-8936-07F03038F4DF> /usr/lib/libmecabra.dylib
0x90ef1000 - 0x90f0afff com.apple.Kerberos (3.0 - 1) <92735F11-CF1C-3FA6-8682-9A30AC9E2651> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x90f0b000 - 0x9100bff7 com.apple.LaunchServices (644.12.4 - 644.12.4) <D41066A1-FC8B-34A2-A980-4B011AA77F38> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x910ae000 - 0x910aefff libunc.dylib (29) <CE960997-9D4A-3848-BAC7-B2255E6765FD> /usr/lib/system/libunc.dylib
0x910af000 - 0x91104ff3 com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <F5A586C3-A440-3E0E-966A-7841A182E5B2> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x91105000 - 0x91184fff com.apple.SystemConfiguration (1.14 - 1.14) <21296E7B-11A3-35C0-BDC7-838392DE8298> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x9118a000 - 0x911a9fff libsystem_kernel.dylib (2782.10.72) <C88D4054-EF6D-31F9-A9DC-B74160B91C26> /usr/lib/system/libsystem_kernel.dylib
0x911aa000 - 0x911aafff liblaunch.dylib (559.10.3) <DF6BB29C-8F20-3E04-81FF-19FFBC82BD46> /usr/lib/system/liblaunch.dylib
0x91265000 - 0x913d6ffb libBLAS.dylib (1128) <ACEF468C-5DB1-38F3-BCB2-6F3D7F2B2040> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x913d7000 - 0x913d9fff libsystem_coreservices.dylib (9) <20E66A47-8D67-344A-A393-73926F0E5FB2> /usr/lib/system/libsystem_coreservices.dylib
0x913da000 - 0x9147afff com.apple.QD (301 - 301) <4DFE3689-59DE-3FBC-806B-6A4056573E52> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x9150b000 - 0x91513feb libcldcpuengine.dylib (2.4.5) <3E336292-C1DC-3B11-BDA5-BB495FC47F5B> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x91514000 - 0x91562ff7 libcurl.4.dylib (83.1.2) <F5D7DC22-1308-34FD-8A4E-A4DC3F8351E4> /usr/lib/libcurl.4.dylib
0x91563000 - 0x91578ffb com.apple.MultitouchSupport.framework (262.33.1 - 262.33.1) <E8AF5A36-89A1-38CC-9905-D74A692D0898> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x91579000 - 0x91663fff libcrypto.0.9.8.dylib (52.10.1) <DD3EA46B-C906-39AA-848E-7C7240EB31F9> /usr/lib/libcrypto.0.9.8.dylib
0x91664000 - 0x918e9fff com.apple.QuickTime (7.7.3 - 2890) <34289D2B-07CC-3D12-8F32-6F97D96DEE81> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x918ea000 - 0x918fcff7 libsasl2.2.dylib (193) <B5813595-A89D-39D4-BB06-F6013D3BD98C> /usr/lib/libsasl2.2.dylib
0x918fd000 - 0x9191affb com.apple.Ubiquity (1.3 - 313) <9ED23769-0725-3D4B-B7F4-AF08020D73C3> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
0x9191b000 - 0x91971fff libc++.1.dylib (120) <D8DE4962-66CD-3491-904E-9291EEE5E570> /usr/lib/libc++.1.dylib
0x91972000 - 0x91975fff libpam.2.dylib (20) <E2F34522-448A-3392-BC1D-6625BEB612B9> /usr/lib/libpam.2.dylib
0x91976000 - 0x919c9fff libstdc++.6.dylib (104.1) <D0EB2C99-5939-3ABA-9C18-D9AD75CE23A1> /usr/lib/libstdc++.6.dylib
0x919ca000 - 0x91bceff3 com.apple.CFNetwork (720.2.4 - 720.2.4) <2BDDB692-8973-3B53-A53C-71D42BDBABBF> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x91bcf000 - 0x91bd7ff7 libCGCMS.A.dylib (775.16) <8464ED9C-1365-3E92-BCD4-FEAD13EA9836> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGCMS.A.dylib
0x91bd8000 - 0x91bd8fff com.apple.Accelerate (1.10 - Accelerate 1.10) <C2367B5B-AE20-3084-A864-104743BE478E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x91bfc000 - 0x91bfeffb libsystem_secinit.dylib (18) <3CBA3BD3-8BA2-358D-BD1A-A1C3DF5D84E6> /usr/lib/system/libsystem_secinit.dylib
0x91bff000 - 0x91c00fff libSystem.B.dylib (1213) <BFFB2AB8-29F6-3779-B358-EE1F46520FC8> /usr/lib/libSystem.B.dylib
0x91c01000 - 0x91c14fff com.apple.ProtectedCloudStorage (1.0 - 1) <0A330FB7-44EE-359F-BAB7-48351AACD305> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x91c15000 - 0x91c15fff libkeymgr.dylib (28) <06DDCEF8-EB84-3F68-9E19-FD1A12B764FD> /usr/lib/system/libkeymgr.dylib
0x91c6a000 - 0x91c71fff libMatch.1.dylib (24) <428CD037-5261-39A6-83EE-A7D9ABF446EB> /usr/lib/libMatch.1.dylib
0x91c72000 - 0x91eeeff7 com.apple.security (7.0 - 57031.10.10) <3EF32688-A176-33DD-BA59-25F37D6C08DA> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x91eef000 - 0x91f08fff libsystem_malloc.dylib (53.1.1) <58CD8BC7-55D1-3862-8E5D-728EE2EBE447> /usr/lib/system/libsystem_malloc.dylib
0x91f09000 - 0x91f46ff7 libsystem_network.dylib (411.1) <EB71DD61-9515-3F6C-817E-25AF7F108CB8> /usr/lib/system/libsystem_network.dylib
0x91f47000 - 0x91f54ff7 com.apple.HelpData (2.1.4 - 90) <26BCEACC-25FF-3E97-9C00-D3D25447431D> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x91f55000 - 0x91f95fff com.apple.Symbolication (1.4 - 56045) <BE1C4846-DA11-365D-9B46-3FF130401839> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x91f96000 - 0x91fa9fff com.apple.CoreBluetooth (1.0 - 1) <DF406F6F-C173-3598-8785-8A2014F770EF> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x91faa000 - 0x91fd7ff7 GLRendererFloat (11.1.1) <C8DA6CFC-9574-31A2-B012-5394A007268F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x91fd8000 - 0x920a3fff com.apple.DiscRecording (9.0 - 9000.4.2) <79272AB7-6389-34D8-ADEE-612E1DBE6B54> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x920a4000 - 0x92268ff3 com.apple.QuartzCore (1.10 - 361.15) <4DD4BF91-26D4-3325-BB42-9642318307FA> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x92269000 - 0x9226afff libremovefile.dylib (35) <49DCAF7B-4466-3775-9E58-EA5D7CBA8AE0> /usr/lib/system/libremovefile.dylib
0x9226b000 - 0x9245a2ef libobjc.A.dylib (647) <7648C174-3098-3B26-AD20-490DBFFD5D4C> /usr/lib/libobjc.A.dylib
0x9245b000 - 0x9245bfff com.apple.ApplicationServices (48 - 48) <76C301A4-705B-33DE-BA11-C89DCF1EDCDD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x9245c000 - 0x92462ff7 libsystem_networkextension.dylib (167.1.10) <FC20E3AD-A53D-3346-AC71-829E82832AE8> /usr/lib/system/libsystem_networkextension.dylib
0x92463000 - 0x9246cffb com.apple.CommonAuth (4.0 - 2.0) <FFE760A3-FEF7-3009-92E8-893ABB3BC91A> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x9246d000 - 0x924d8ff7 com.apple.framework.CoreWiFi (3.0 - 300.4) <632A811D-4706-3ED7-85E3-DD2CDB47CF8F> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x924d9000 - 0x92513fff com.apple.LDAPFramework (2.4.28 - 194.5) <C3BD6DBA-5EE4-3992-A013-CF5333AAB648> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x92514000 - 0x9262aff7 com.apple.CoreText (352.0 - 454.3) <6448E389-AB2E-34EF-AE07-FE364ECC98E5> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x9262b000 - 0x92645ff7 liblzma.5.dylib (7) <D0BC984D-5B33-328C-8F1E-7E9C41813433> /usr/lib/liblzma.5.dylib
0x92646000 - 0x9323bfff com.apple.AppKit (6.9 - 1344.72) <B84FF828-3016-353A-BF86-C1547F448FB1> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x9323c000 - 0x9323eff3 com.apple.EFILogin (2.0 - 2) <CA5B7995-F183-31F3-B918-27965B2BDE8F> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x9323f000 - 0x93268ff3 com.apple.shortcut (2.13 - 2.13) <EAB70BDD-40B9-34F3-9458-1ED52B71D795> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x93269000 - 0x94219fff com.apple.WebCore (10600 - 10600.3.15) <FF6008C2-ADF4-35F1-A227-0F6DA88B9597> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x9421a000 - 0x9424eff7 libTrueTypeScaler.dylib (134.1) <0E422818-27BC-3FEB-8C34-4664546A42D2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x9424f000 - 0x9425aff7 com.apple.CrashReporterSupport (10.10 - 629) <BA5611B6-EF99-3A44-90DD-3305FDA4975E> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x9425b000 - 0x9428efe3 libsystem_m.dylib (3086.1) <951F633F-57B7-398B-912F-F6ED4DB1C597> /usr/lib/system/libsystem_m.dylib
0x94548000 - 0x9465dffb com.apple.desktopservices (1.9.2 - 1.9.2) <DCA5B074-BD3C-35E9-BF11-628019FE3CC0> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x9465e000 - 0x9478cfff com.apple.coreui (2.1 - 305.6.1) <6535A234-0DFF-3467-837B-118E2C9D2875> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x9478d000 - 0x947d4ff3 com.apple.AppleJPEG (1.0 - 1) <C14A2B49-A664-3EDE-9B9B-6A678ED7F8DE> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x947d5000 - 0x9480ffff com.apple.MediaKit (16 - 757) <430EC569-B083-3608-B91F-3EC6B6065519> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x94810000 - 0x94869ffb libAVFAudio.dylib (118.3) <65762748-F772-3959-8D14-197AFB778132> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
0x9486a000 - 0x9486dfff libextension.dylib (55.1) <E0A4ADBE-596E-3363-8780-51D8AE39B755> /usr/lib/libextension.dylib
0x9486e000 - 0x94b1fff3 com.apple.RawCamera.bundle (6.03 - 777) <E870A09A-CB51-3B3D-BEB7-8984300C83B4> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x94b20000 - 0x94b5cff3 com.apple.RemoteViewServices (2.0 - 99) <2839C2F1-88DA-3843-87BF-441A374A8967> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x94b5d000 - 0x94b60ff7 com.apple.help (1.3.3 - 46) <FDF183E4-3B95-3CBD-A390-2536C8E7E258> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x94b61000 - 0x94bc1fff com.apple.AppleVAFramework (5.0.31 - 5.0.31) <45401678-26FE-3EFD-B1A1-88864B470871> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x94bc2000 - 0x94bd0ff7 com.apple.SpeechRecognitionCore (2.0.32 - 2.0.32) <637E7AB2-1077-319C-A6A2-D0D0F01951BA> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x94bd1000 - 0x94c81ff3 com.apple.Bluetooth (4.3.2 - 4.3.2f6) <FC787129-45BB-3B94-ACAD-A0CECEB77AEC> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x94c82000 - 0x94c8fff7 com.apple.speech.synthesis.framework (5.3.3 - 5.3.3) <EB79D0BE-75B8-3570-9D91-AE07E42611BD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x94c90000 - 0x94c99fff com.apple.AppleSRP (5.0 - 1) <41C48FA8-C249-3800-A551-7F4AFA3E723F> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x94c9a000 - 0x94c9bfff com.apple.TrustEvaluationAgent (2.0 - 25) <28BBD931-EF7C-3753-B50E-6568F4075086> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x94c9c000 - 0x94c9dfff libDiagnosticMessagesClient.dylib (100) <3EE83437-AA9C-356B-810B-589346B73797> /usr/lib/libDiagnosticMessagesClient.dylib
0x94cee000 - 0x94dfcfff com.apple.QuickTimeImporters.component (7.7.3 - 2890) <477BB49E-127B-3B46-9B56-B162AF155B43> /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
0x94e06000 - 0x94e40fff com.apple.AirPlaySupport (2.0 - 215.15) <A7147999-EE77-3BC9-BC26-506D026B5587> /System/Library/PrivateFrameworks/AirPlaySupport.framework/Versions/A/AirPlaySupport
0x94e41000 - 0x94e44ffb libutil.dylib (38) <B5A16C6B-A79E-3504-BDA6-64A063F6612D> /usr/lib/libutil.dylib
0x94e45000 - 0x94e96fff libcups.2.dylib (408) <08C5D411-533C-345A-B820-092C96215F2E> /usr/lib/libcups.2.dylib
0x94e97000 - 0x94ea0fff libcopyfile.dylib (118.1.2) <FAF3268F-C580-33D3-A5B4-74B8A8713216> /usr/lib/system/libcopyfile.dylib
0x94ea1000 - 0x94ebefff libCRFSuite.dylib (34) <781A92EF-410E-39B2-953D-FEE12748D834> /usr/lib/libCRFSuite.dylib
0x94ebf000 - 0x94f2bff3 com.apple.datadetectorscore (6.0 - 396.1.1) <93F59488-6CA9-3C90-8E96-B0DE5942252F> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x94f2c000 - 0x94f33fff com.apple.agl (3.3.0 - AGL-3.3.0) <B458FD69-5241-32A3-813B-6C8AE16E8F2E> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x94f34000 - 0x94f44fff libGL.dylib (11.1.1) <244536CD-5B87-3A3E-AD68-03BF04BD2D33> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x94f45000 - 0x95259fef com.apple.CoreAUC (211.0.0 - 211.0.0) <78C567D8-532D-3A08-BF7D-0C25A859F64A> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x9525a000 - 0x953e9ff3 libsqlite3.dylib (168) <C3F78985-C19B-3320-9F71-543969632128> /usr/lib/libsqlite3.dylib
0x953ea000 - 0x953f6ff3 libcommonCrypto.dylib (60061) <024B3913-15C6-3005-9E5A-EB24918F6977> /usr/lib/system/libcommonCrypto.dylib
0x953f7000 - 0x956f5ff7 com.apple.CoreServices.CarbonCore (1108.2 - 1108.2) <D3DD9764-A787-3B6B-9DAD-55CEED944DCF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x956f6000 - 0x956f6fff com.apple.audio.units.AudioUnit (1.12 - 1.12) <64ED443E-25D5-3A2C-A028-0D0C7FAF57C6> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x956f7000 - 0x95736fff com.apple.NavigationServices (3.8 - 215.1) <46D8B66D-CB59-36F5-BD26-FD8309337BB3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x95737000 - 0x95756ffb libresolv.9.dylib (57) <C2C3810A-A45E-3375-B41D-6E1BECE1BA3C> /usr/lib/libresolv.9.dylib
0x95757000 - 0x9575cff7 libcompiler_rt.dylib (35) <6630682F-AB76-3E55-BE51-0A3E61B6CFC2> /usr/lib/system/libcompiler_rt.dylib
0x9575d000 - 0x9584effb libiconv.2.dylib (42) <4AF77F10-0BEC-3BE0-99DF-C5170EDB316B> /usr/lib/libiconv.2.dylib
0x9584f000 - 0x95873ffb com.apple.framework.Apple80211 (10.1 - 1010.64) <377A2686-2C1F-3257-8420-37DB5C8F33AD> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x95874000 - 0x958aeff7 com.apple.DebugSymbols (115 - 115) <D01FFA10-1734-31C5-B5A1-9CB61463FC15> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x958af000 - 0x958c1fff com.apple.Sharing (328.3.2 - 328.3.2) <4F0D4D68-B6A6-3E66-8A89-CDD9AFEA82EA> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x958c2000 - 0x958c6ff3 com.apple.TCC (1.0 - 1) <3E7036F2-9706-3116-8126-16F26AA2FC11> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x958c7000 - 0x958c9fff libquarantine.dylib (76) <9ADD861F-A66E-3AD1-A77E-C622E91BD203> /usr/lib/system/libquarantine.dylib
0x958ca000 - 0x958cafff com.apple.CoreServices (62 - 62) <FF296ED2-0F90-3055-BBE4-7BF9E42322EF> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x958cb000 - 0x958e2ff7 com.apple.CoreMediaAuthoring (2.2 - 951) <02B870F3-BA89-3CFD-95E2-39359DF39D68> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x958e3000 - 0x958e9ff7 libsystem_trace.dylib (72.1.3) <E1985F9C-78FC-3098-8683-81F0DCEE54BB> /usr/lib/system/libsystem_trace.dylib
0x958ea000 - 0x958f3fff com.apple.DiskArbitration (2.6 - 2.6) <D906604A-1D8C-31BF-8F22-EA219FFC858F> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x958f4000 - 0x9590bffb com.apple.AppContainer (4.0 - 238.10.1) <76D88956-AF52-35AA-8213-9B6285B623CD> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x9590c000 - 0x959fcff3 com.apple.DiskImagesFramework (10.10.1 - 396) <976D6EB2-1729-33FF-BEAC-83EE6653CF74> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x959fd000 - 0x95a0efff libsystem_coretls.dylib (35.10.1) <602048AB-2CF0-3083-9D84-5DF19B95EEE1> /usr/lib/system/libsystem_coretls.dylib
0x95a0f000 - 0x95a11fff com.apple.QuickTimeH264.component (7.7.3 - 2890) <79C75A3F-6B01-335F-BC15-089976EE2D60> /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
0x95a12000 - 0x95a3bff7 libsystem_info.dylib (459) <4F7A7111-7F0D-3891-9DC9-41F5D79949FE> /usr/lib/system/libsystem_info.dylib
0x95a3c000 - 0x95a6aff7 libarchive.2.dylib (30) <8758D35F-ADF8-30F6-8EB2-9B852876EAC8> /usr/lib/libarchive.2.dylib
0x95a6b000 - 0x95abcfff com.apple.opencl (2.4.2 - 2.4.2) <327699CD-6BF9-3B63-999E-A5A56014E540> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x95abd000 - 0x95e6fff7 com.apple.CoreFoundation (6.9 - 1152) <93C32AF9-FD62-3DBD-85F7-35727E6CAA55> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x95e70000 - 0x95ee3ffb com.apple.framework.CoreWLAN (5.0 - 500.35.2) <22CC0615-70EF-3155-8410-A1427793DBBC> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x95ee4000 - 0x95ee8ffb com.apple.IOSurface (97.0.1 - 97.0.1) <AE872EA9-0D22-32CF-91AB-DD7C056EB01E> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x95ee9000 - 0x95f04ff3 com.apple.openscripting (1.4 - 162) <EB1D1BA6-C0B0-3D3B-AE54-676324FFF3E6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x95f05000 - 0x9607aff7 com.apple.QTKit (7.7.3 - 2890) <16C43187-DFFE-3BB3-AA2C-741FBEBB5585> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x9607b000 - 0x96083ffb com.apple.NetFS (6.0 - 4.0) <141BFE7E-634E-32A0-8EC9-0A1A4DFEA7D9> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x96992000 - 0x969b1ff7 com.apple.GenerationalStorage (2.0 - 209.11) <34CF76B2-8052-359D-816D-092608FB6919> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x969b2000 - 0x969d8ffb libxpc.dylib (559.10.3) <6C4CEB0F-0044-3B62-A286-5693C3FD239E> /usr/lib/system/libxpc.dylib
0x969d9000 - 0x969e2ff7 libsystem_notify.dylib (133.1.1) <B8503E99-214B-3AC3-A7CA-CC837ABD7B25> /usr/lib/system/libsystem_notify.dylib
0x969e3000 - 0x969e7ffb libcache.dylib (69) <55501A00-AF64-3554-8F46-8D5AFEDEC332> /usr/lib/system/libcache.dylib
0x969e8000 - 0x96b96ffb GLEngine (11.1.1) <3F96C2B6-72EF-30DB-BE7C-50411D9B360F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x96b97000 - 0x96b98fff liblangid.dylib (117) <34A0F807-755F-300B-B01F-AABAE3838451> /usr/lib/liblangid.dylib
0x96b99000 - 0x96e37ffb com.apple.WebKit (10600 - 10600.3.18) <EB9B4EAA-C074-3B29-88C1-35E23889C636> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x96e38000 - 0x96ecafff com.apple.CoreSymbolication (3.1 - 57020) <EAC6745A-AB1D-38CC-A12C-99ECD8F071ED> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x96ecb000 - 0x96ef2fff libdispatch.dylib (442.1.4) <B26A176C-39F7-3362-B128-27B1211068B9> /usr/lib/system/libdispatch.dylib
0x96ef3000 - 0x96ef7fff com.apple.CommonPanels (1.2.6 - 96) <955375E6-2416-38E1-AFC6-477827119329> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x96ef8000 - 0x96f21fff libRIP.A.dylib (775.16) <5587B04F-D31C-3F70-961F-0F6282E8FB29> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x96f22000 - 0x972faff7 com.apple.HIToolbox (2.1.1 - 757.3) <642A3B29-036D-3A87-AC81-935843AB6A32> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x972fb000 - 0x97327ffb libsandbox.1.dylib (358.1.1) <776BDC0D-F352-3F49-9B0A-8B6B0D164C6A> /usr/lib/libsandbox.1.dylib
0x97328000 - 0x973d0ff7 com.apple.CoreMedia (1.0 - 1562.107) <A175F33D-8502-3D36-8C9C-0D74BA904CF2> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x973d1000 - 0x97483fff libCoreStorage.dylib (471.10.6) <E7A963AC-C277-31A8-A1E8-BFAC38A24B69> /usr/lib/libCoreStorage.dylib
0x97484000 - 0x975b6ffb com.apple.UIFoundation (1.0 - 1) <00A59CFF-A217-3998-B22E-6E452278A302> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x975b7000 - 0x975b7fff libOpenScriptingUtil.dylib (162) <9872C464-DF90-37C2-9871-8A3F53C615EC> /usr/lib/libOpenScriptingUtil.dylib
0x975b8000 - 0x9762ffff com.apple.CoreUtils (1.0 - 101.1) <7169E4D1-0771-36AD-85C8-60CF37FFF16E> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x97630000 - 0x97630fff com.apple.Cocoa (6.8 - 21) <6AF80DDB-C28E-36FF-BC11-D7D561AC52A9> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x97631000 - 0x97671ffb libGLImage.dylib (11.1.1) <B49A6796-40A3-33D0-8199-6AED149ADFDF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x98025000 - 0x98132fe3 libvDSP.dylib (516) <53F7A960-01E1-3B79-A7FD-67BD19471420> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x98133000 - 0x9813bfff com.apple.CoreServices.FSEvents (1210 - 1210) <FC372799-6E8E-3290-9816-6981D39BC9D6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x9813c000 - 0x981d6fff com.apple.ColorSync (4.9.0 - 4.9.0) <091CDCEC-1B25-3FE7-94C2-8AEFA6564E95> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x981d7000 - 0x9860aff3 com.apple.vision.FaceCore (3.1.6 - 3.1.6) <EF92C25B-3E33-379F-A862-75C2FCA8B386> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x9860b000 - 0x98701ff7 libxml2.2.dylib (26) <2F37833C-4D55-3A09-9A0C-5904E8B6892A> /usr/lib/libxml2.2.dylib
0x98702000 - 0x9872cfff libxslt.1.dylib (13) <0F55B64A-6C55-304E-ACE0-B531027AA066> /usr/lib/libxslt.1.dylib
0x9872d000 - 0x9873afff com.apple.OpenDirectory (10.10 - 187) <14AA5E0C-238A-32C4-BAF3-81893750B5A9> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x9873b000 - 0x98798ff3 com.apple.print.framework.PrintCore (10.0 - 451) <2563665B-7B7F-3B8A-83B1-E5AC8D389909> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x98799000 - 0x98924ffb com.apple.audio.toolbox.AudioToolbox (1.12 - 1.12) <44BCEAB8-306D-307F-92C8-6656F3578220> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x98925000 - 0x98931ff7 libkxld.dylib (2782.10.72) <FF699F52-D950-3DAD-A37B-834EBF0D0FFD> /usr/lib/system/libkxld.dylib
0x98932000 - 0x98934fff libCVMSPluginSupport.dylib (11.1.1) <2AEAFC0D-982C-3E26-B50B-B6EB12FE71F4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x98938000 - 0x98943ff7 com.apple.AppSandbox (4.0 - 238.10.1) <89DA7A61-B7F6-3365-8D49-65FA766EF720> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x98944000 - 0x9894cfff libsystem_dnssd.dylib (561.1.1) <45CDAF46-03DE-33DB-A627-14F245993EF2> /usr/lib/system/libsystem_dnssd.dylib
0x9894d000 - 0x98955ff7 com.apple.icloud.FindMyDevice (1.0 - 1) <A0C38380-8B46-39CF-A0A1-27ABDAD1D574> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
0x98956000 - 0x98cb5ffb com.apple.Foundation (6.9 - 1152.14) <F74F139D-8789-3B60-ADF6-AB6F39444AC4> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x98cb6000 - 0x99639fe3 com.apple.QuickTimeComponents.component (7.7.3 - 2890) <806183BE-2A07-3217-80A4-4B2CC3D40962> /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x9963a000 - 0x99660ff3 libc++abi.dylib (125) <E9AF8CA1-D54D-37E3-8363-A3E8C0840F71> /usr/lib/libc++abi.dylib
0x99661000 - 0x99667ff7 com.apple.MediaAccessibility (1.0 - 61) <81E9530E-882C-313C-A4D5-2F43EB569E4F> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x99668000 - 0x9966afff com.apple.loginsupport (1.0 - 1) <8B651D8C-53D0-314D-BDD6-74147C4B2E73> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x9966b000 - 0x9969efff com.apple.CoreAVCHD (5.7.5 - 5750.4.1) <103A5EA0-9B75-3B23-BE72-C4DD52744A6A> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x9969f000 - 0x9978bfe7 libvMisc.dylib (516) <8575A3B5-F6FB-35BF-9E50-E81BD0813100> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x9978c000 - 0x99797ff7 com.apple.NetAuth (5.0 - 5.0) <D6C31218-47E4-3553-9208-D1091A81044E> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x99798000 - 0x997abfff libcmph.dylib (1) <2449B048-208E-36FB-9DFA-47E0F3BCF132> /usr/lib/libcmph.dylib
0x997ac000 - 0x997b0ffb libGIF.dylib (1232) <037E01F1-885C-3F4A-A353-87DB1F9CB504> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x997b1000 - 0x997b1fff com.apple.Carbon (154 - 157) <514DC1B6-3D3B-3A96-814D-71D6E022CB3D> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x997b2000 - 0x998f6fff com.apple.ImageIO.framework (3.3.0 - 1232) <3C219D4C-9B88-3A4A-A266-AEA6C6495676> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x998f7000 - 0x998f8fff libsystem_blocks.dylib (65) <5D98F022-E863-31D4-8ADE-D53B2AE0D331> /usr/lib/system/libsystem_blocks.dylib
0x998f9000 - 0x998f9fff com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <F968D12F-F59D-3148-951D-76735C3C1B57> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x998fa000 - 0x99908ff3 libxar.1.dylib (254) <D7C4FDEB-61AA-3FC1-8B7B-0AE3A3A64492> /usr/lib/libxar.1.dylib
0x999b7000 - 0x999d2ff7 com.apple.CFOpenDirectory (10.10 - 187) <5302DBFA-92CE-349C-981C-2BF6E9BEEBB0> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x999d3000 - 0x999fffff com.apple.ChunkingLibrary (2.1 - 163.1) <2B0CBB85-EF91-351A-8750-A185996E4CDB> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x99a00000 - 0x99a07fff com.apple.XPCService (2.0 - 1) <9A59D63D-446A-33A4-BB21-56E42417DA93> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
0x99a08000 - 0x99d8bff7 com.apple.VideoToolbox (1.0 - 1562.107) <D9840509-340B-3503-BD58-4907AC4AAA51> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x99d8c000 - 0x99e02ff7 com.apple.SearchKit (1.4.0 - 1.4.0) <B6F346D2-BF88-3925-B962-E59267FA2268> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x99e03000 - 0x99e73ff3 libType1Scaler.dylib (114.1.9) <999115B6-B745-3D44-A24F-4F038B1C2423> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
0x99e74000 - 0x99e7effb com.apple.audio.SoundManager (4.2 - 4.2) <4312D0A7-4B6F-3A1E-9A47-24C6E8C65E51> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x99e7f000 - 0x99e94ff3 libCGInterfaces.dylib (294.1) <631D5E39-4815-3BDA-BD16-B34D5EB36240> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x99e95000 - 0x99e9afff com.apple.print.framework.Print (10.0 - 265) <7C3984BB-8337-3B90-A414-17C181A45744> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x99e9b000 - 0x99eeffff com.apple.HIServices (1.22 - 520.12) <8950B516-7DFD-3154-B34F-067809086832> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x99ef0000 - 0x99fe7ff7 libFontParser.dylib (134.1) <AF60B79A-410B-389E-9B24-09B5BC61E19F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x99fe8000 - 0x99ff4ff7 libcsfde.dylib (471.10.6) <C14E5F82-9F30-3934-8E71-B2AA5A2AA353> /usr/lib/libcsfde.dylib
0x99ff5000 - 0x9a048fff com.apple.CoreMediaIO (601.0 - 4749) <0A48F432-BEB4-3420-B156-12F576A6C0FD> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x9a049000 - 0x9a056ff7 com.apple.ProtocolBuffer (1 - 225.1) <E5744DE6-B3FC-3289-9E71-98E88DECE545> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x9a057000 - 0x9a07afff libJPEG.dylib (1232) <C7B71F9A-E740-307B-A9FA-A83760EE747B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x9a07b000 - 0x9a18efff com.apple.MediaControlSender (2.0 - 215.15) <83A34306-9F4B-31B3-A395-3F3DF3F6BBED> /System/Library/PrivateFrameworks/MediaControlSender.framework/Versions/A/MediaControlSender
0x9a18f000 - 0x9a192fff com.apple.xpc.ServiceManagement (1.0 - 1) <D0A00D0C-D37D-3CF1-9EE0-41A88BC112BB> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x9a193000 - 0x9a1c6fff com.apple.CoreServicesInternal (221.2.2 - 221.2.2) <06F52EEC-72B7-380D-B66D-7A487EA24741> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x9a1c7000 - 0x9a291ff7 com.apple.backup.framework (1.6.2 - 1.6.2) <AE8234C3-6BB3-317B-A4E7-EF3478445DFF> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x9a292000 - 0x9a2fbff7 libcorecrypto.dylib (233.1.2) <F188C1A7-E88F-3EC5-A6AA-22C02E3F0C93> /usr/lib/system/libcorecrypto.dylib
0x9a2fc000 - 0x9a303ff3 libunwind.dylib (35.3) <29D9343F-9A0A-3535-B0AE-E7CC761D95EE> /usr/lib/system/libunwind.dylib
0x9a304000 - 0x9a46dfff com.apple.avfoundation (2.0 - 889.102) <864AFE74-25CA-3704-9246-5BD9CB5AB360> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x9a46e000 - 0x9a856ff7 libLAPACK.dylib (1128) <4E3D1289-2C98-3E53-BB8D-AD911357FF66> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x9a857000 - 0x9aa4dfff libicucore.A.dylib (531.31) <430BD572-4521-3C85-B815-56514F9E2BBF> /usr/lib/libicucore.A.dylib
0x9aa4e000 - 0x9aa82ffb com.apple.frameworks.CoreDaemon (1.3 - 1.3) <F527DB82-0D3F-359E-979B-951DFF46D45C> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x9aa83000 - 0x9ab18fff libsystem_c.dylib (1044.10.1) <584F66B1-ABBA-354C-8118-1DA5386A065E> /usr/lib/system/libsystem_c.dylib
0x9ab19000 - 0x9ac3fffb com.apple.WebKitLegacy (10600 - 10600.3.18) <D9337FD7-C42B-38AC-8080-09CEB6348BF5> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x9ac40000 - 0x9ac80fff libauto.dylib (186) <1609D0F9-6E3A-3C67-87EF-BB0BD93EDAC9> /usr/lib/libauto.dylib
0x9ac81000 - 0x9ac8eff7 libbz2.1.0.dylib (36) <6BC7B049-8F03-3217-9840-B1804CCBF742> /usr/lib/libbz2.1.0.dylib
0x9ac8f000 - 0x9af22fff com.apple.CoreData (111 - 526.1) <74375077-8AE6-3D1B-B6A4-CF3B0724EB60> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x9af23000 - 0x9af7efff com.apple.LanguageModeling (1.0 - 1) <9B39E059-F48E-31AF-B1B3-B0872F362627> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x9af7f000 - 0x9b426ff7 com.apple.JavaScriptCore (10600 - 10600.3.13) <21BA75F3-8A70-3159-8696-7392EDEBEF70> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x9b427000 - 0x9b4aefff com.apple.CoreServices.OSServices (640.3 - 640.3) <C53DBDE3-F9E0-3B90-963E-0FAEEF3DA225> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x9b4af000 - 0x9b4beff3 com.apple.opengl (11.1.1 - 11.1.1) <212B409C-AF1E-3C69-B4AA-57A39C35BB62> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x9b4bf000 - 0x9b4c4ff7 libmacho.dylib (862) <48DE74F8-09E3-344F-A82F-665083A3BF8F> /usr/lib/system/libmacho.dylib
0x9b4c5000 - 0x9b7b7ffb com.apple.CoreImage (10.0.33) <75B23F45-8D99-3521-89AE-AF2AF4487096> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x9b7b8000 - 0x9b7baffb libCGXType.A.dylib (775.16) <B3ED365B-0CE2-3847-A503-A35892E7790A> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x9b7bb000 - 0x9b816ffb libTIFF.dylib (1232) <E5A82202-E766-32DE-9706-86B3B2B73731> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x9b817000 - 0x9b819ffb libRadiance.dylib (1232) <F16794FD-4326-32CD-A578-3B2ADB27587D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x9b81a000 - 0x9b81cfff com.apple.securityhi (9.0 - 55006) <5AF7E054-F6A1-38B4-B403-BAF8BE4DBA35> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x9b81d000 - 0x9b831fff com.apple.ImageCapture (9.0 - 9.0) <4B84B5D5-A5F3-3B35-93CE-568A73486B92> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x9b832000 - 0x9b83bfff libGFXShared.dylib (11.1.1) <9A7C1796-07E7-3856-8703-75559016EF98> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x9b83c000 - 0x9b8b6fff com.apple.ApplicationServices.ATS (360 - 375) <4052B5D1-5F16-315A-A03B-14F0A112FC18> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x9b8b7000 - 0x9b8e8fff libtidy.A.dylib (15.15) <D893B41F-FBE9-3EDE-8DC6-2B80A4E0804B> /usr/lib/libtidy.A.dylib
0x9b8e9000 - 0x9b95dfff com.apple.Heimdal (4.0 - 2.0) <5BB21A72-99E6-3079-824E-935AA93D3981> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x9b95e000 - 0x9b964ff3 libsystem_platform.dylib (63) <509993B7-3F26-3360-B899-0BBB15152516> /usr/lib/system/libsystem_platform.dylib
0x9b965000 - 0x9bb15ff7 libGLProgrammability.dylib (11.1.1) <E8B8A0B3-1000-3ACB-B01A-09CD64797652> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x9bb16000 - 0x9bb3cffb libPng.dylib (1232) <576BCAB6-DBE2-36DB-A390-E945FC844118> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x9bb3d000 - 0x9bb40fff libdyld.dylib (353.2.1) <3E28E996-50B8-388B-8885-7299FBC978B1> /usr/lib/system/libdyld.dylib
0x9bb41000 - 0x9bb70fff com.apple.CoreVideo (1.8 - 145.1) <A59466FC-6B5A-3B36-BDD4-AC9CD581B7A1> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x9bb71000 - 0x9bba3ffb com.apple.GSS (4.0 - 2.0) <680D3014-D2C6-30D4-9892-93B9E4172100> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x9bba4000 - 0x9bc1afff com.apple.securityfoundation (6.0 - 55126) <E7CBF2F4-2A0E-3C82-BE84-E09D21772AFB> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x9bc1b000 - 0x9bc2bff7 com.apple.LangAnalysis (1.7.0 - 1.7.0) <DBECFAD5-DB53-390C-AE92-09549733C861> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x9bc2c000 - 0x9bc90ff7 com.apple.AE (681 - 681) <EEE62980-421B-33BD-BB88-6BDE269A3060> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x9bc91000 - 0x9bca8ff3 libLinearAlgebra.dylib (1128) <B20FAAAA-1C76-3B20-B100-5FC90F7FE023> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x9bca9000 - 0x9bd35ff3 com.apple.PerformanceAnalysis (1.0 - 1) <7A9DD1C9-465D-37FA-957E-2B0F190CFC7C> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x9bd36000 - 0x9bd3afff libheimdal-asn1.dylib (398.10.1) <6F113AF8-F5AD-330B-B029-F7AF28A93F28> /usr/lib/libheimdal-asn1.dylib
0x9bd3b000 - 0x9bd3dff7 libsystem_sandbox.dylib (358.1.1) <6031346B-57B0-36FB-911B-D355E1F98A9A> /usr/lib/system/libsystem_sandbox.dylib
0x9bd3e000 - 0x9bde4fff com.apple.Metadata (10.7.0 - 917.1) <0B19C2DD-A71C-3D2B-AB00-68FFC6CC606A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x9bde5000 - 0x9c1dbff3 com.apple.CoreGraphics (1.600.0 - 775.16) <5F7BDB0B-5324-3B7A-BC6B-E7A01A880D94> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x9c1dc000 - 0x9c20bff7 com.apple.DictionaryServices (1.2 - 229) <1F5C35C7-67AA-30A0-A366-EB4B361152A3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x9c20c000 - 0x9c214fff libsystem_pthread.dylib (105.10.1) <4A229519-29A1-3ABF-8CEF-43BCE4ACDA06> /usr/lib/system/libsystem_pthread.dylib
0x9c215000 - 0x9c219fff libCoreVMClient.dylib (79) <85CBF1F3-3CE1-304F-88DF-15608C9A2367> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x9c21a000 - 0x9c31eff7 libJP2.dylib (1232) <CD0012B6-D649-327B-B7FA-E52B0FC0067C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x9c31f000 - 0x9c39cff3 com.apple.framework.IOKit (2.0.2 - 1050.10.8) <60574F96-1CD6-34B8-A862-EA977FD058BF> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x9c39d000 - 0x9c3a4fff com.apple.speech.recognition.framework (5.0.9 - 5.0.9) <5D268178-3812-3777-92A6-D7D3395405B8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0xba300000 - 0xba301fff libCyrillicConverter.dylib (64) <DC85D688-7944-3C5B-812C-5157403D4237> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
0xba900000 - 0xba91dfff libJapaneseConverter.dylib (64) <6A2CDFEE-AC63-3F71-AADF-D9B0072EF5D9> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0xbab00000 - 0xbab22fff libKoreanConverter.dylib (64) <4638960C-099E-3E8B-8BB3-1209364A6E07> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
0xbad00000 - 0xbad01fff libLatin2Converter.dylib (64) <AF9C3D98-CE40-3B33-8706-88D8FCEEE853> /System/Library/CoreServices/Encodings/libLatin2Converter.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 2
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 258808
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=278.9M resident=89.9M(32%) swapped_out_or_unallocated=189.0M(68%)
Writable regions: Total=177.2M written=20.5M(12%) resident=53.8M(30%) swapped_out=5356K(3%) unallocated=123.4M(70%)
REGION TYPE VIRTUAL
ATS (font support) 33.7M
Activity Tracing 2048K
CG backing stores 14.1M
CG image 44K
CG shared images 1200K
CoreAnimation 2516K
CoreAnimation (reserved) 16K reserved VM address space (unallocated)
CoreGraphics 8K
CoreUI image data 264K
Foundation 4K
IOKit 12.6M
IOKit (reserved) 4K reserved VM address space (unallocated)
Kernel Alloc Once 4K
MALLOC 75.4M
MALLOC (admin) 48K
Memory Tag 242 12K
Memory Tag 249 192K
OpenCL 40K
Stack 69.1M
VM_ALLOCATE 17.6M
__DATA 28.7M
__GLSLBUILTINS 2588K
__IMAGE 528K
__IMPORT 44K
__LINKEDIT 52.4M
__OBJC 4396K
__TEXT 226.5M
__UNICODE 544K
mapped file 147.6M
shared memory 4K
TOTAL 692.0M
TOTAL, minus reserved VM space 691.9M
Model: MacBookPro6,1, BootROM MBP61.0057.B0F, 2 processors, Intel Core i7, 2.66 GHz, 8 GB, SMC 1.57f18
Graphics: Intel HD Graphics, Intel HD Graphics, Built-In, 288 MB
Graphics: NVIDIA GeForce GT 330M, NVIDIA GeForce GT 330M, PCIe, 512 MB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1067 MHz, 0x80AD, 0x484D54333531533641465238432D47372020
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1067 MHz, 0x80AD, 0x484D54333531533641465238432D47372020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x93), Broadcom BCM43xx 1.0 (5.106.98.100.24)
Bluetooth: Version 4.3.2f6 15235, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: Samsung SSD 840 Series, 250.06 GB
Serial ATA Device: HL-DT-ST DVDRW GS23N
USB Device: Hub
USB Device: USB 2.0 Hub [MTT]
USB Device: Micro Keyboard
USB Device: Elements 10B8
USB Device: Hub
USB Device: Composite Device
USB Device: NetPlay Keyboard
USB Device: PTZ-430
USB Device: USB Mass Storage Device
USB Device: BRCM2070 Hub
USB Device: Bluetooth USB Host Controller
USB Device: Apple Internal Keyboard / Trackpad
USB Device: Hub
USB Device: My Passport 0748
USB Device: Expansion
USB Device: IR Receiver
USB Device: Built-in iSight
Thunderbolt Bus:
Thanks!
matro
Re: Metro Crashing on startup
Postby Jerm » Wed Apr 01, 2015 12:04 pm
The open file dialog is a known bug introduced by Apple in Yosemite. We have a temporary workaround. Contact me by email for specifics on the fix for this please.
