Sagan Technology Metro • View topic - Rewire Effects Crash
Postby MP » Sat Aug 27, 2005 8:31 am
I am experiencing a crash following these steps:
Start Metro with a blank project
Enable Rewire
Drag Apple Matrix Reverb into the rewire channel
After the crash, Metro needs to be authorized again.
Mike
Ti-Book 1Ghz, 768 mb RAM, OSX 10.2.8, Metro 6.3.2
MP
Postby MP » Sat Aug 27, 2005 10:05 am
I wonder if this is connected to Matrix Reverb's four outputs. While I was successfully loading other effects in the rewire channel, I noticed that they all had only two outputs. Then I tried loading the only other known multi-output plugin I have, DS404 sampler, into the rewire channel . . . poof! Just to make sure the last crash wasn't caused by shoving a softsynth in the rewire channel, I tried loading other synths (2 outputs) into it and they did not cause a crash. Hope this helps.
Mike
MP
Postby Jerm » Sat Aug 27, 2005 12:34 pm
MP wrote:Hope this helps.
Yes, very much. Fixed in 6.3.2.2.
