Sagan Technology Metro • View topic - Looping
Looping
Looping
Postby Frek » Fri Mar 28, 2003 3:16 pm
I'm trying to make a loop using this technique, ( http://www.sagantech.biz/metro/help/help531.shtml ).
But the loop doesn't repeat correctly, lets say I try loop bar 2 to 6, it doesn't play bar 2 to 6 the 2nd time, but bar 1 to 4. (ie it seems like it plays X bars (X = loop bar end - loop bar start) from the beginning.
Btw, it's midi and I'm using AppleDLSMusicDevice as the instrument.
Frek
Looping
Postby Fred » Fri Mar 28, 2003 6:02 pm
Here is a simple example confirming the bug:
- make a midi track with port DLSMusicDevice of two bars
bar 1: whole note C
bar 2: whole note D
- define bar 2 as loop and play back
The loop plays note D, but with a pause of 1 bar (apparently starting at the beginning without playing C)
This happens with DLSMusicDevice, but not with an external device!
Fred
Postby Jerm » Fri Mar 28, 2003 6:10 pm
Independent track loops are not supported with audio tracks or synthesizer plug-in MIDI tracks. :(
For now simply use 'paste and'
Users browsing this forum: No registered users and 18 guests
