Sagan Technology Metro • View topic - Bank/Program Problem & DLSMusicDevice
Postby sseaton » Tue Oct 21, 2003 9:35 am
I am using the latest version of Metro SE and I can no longer get the banks and programs to appear correctly in the Tracks window.
I used to be able to drag the DLSMusicDevice plugin on top of Aux 1 and then choose a track in the Mixer. I would then change the port on the track to DLSMusicDevice and rename it. When I would go into Tracks Window and change the Output to reflect my renamed track, I could change my bank to dls1 or dls2, etc. and my program name would be the name of the sound I wanted to use... usually General MIDI program name. (Because I usually use GM soundfonts.)
Now all I get in the bank and program sections of the Tracks window are numbers... no dls1 or dls2, etc. or the program name.
Any advice? I wrote a great walk-through a while back that helped at least on Metro user, so I know (or used to know) what I'm doing. Has something changed? I tested this in 6.0.8 SE and the new pre-release as well as the full demo. I experience the same problem in all versions.
sseaton
Postby Jerm » Tue Oct 21, 2003 9:39 am
Sean,
Yes. This is a problem that was introduced with QuickTime 6.4. It is fixed in Pre-release 6.1.0.3 of Metro, which I hope to get out this week.
Sorry for any inconvenience. The names will be back.
Postby sseaton » Tue Oct 21, 2003 10:09 am
Once again... thanks for the information and the quick fix! :)
sseaton
Postby Jerm » Tue Oct 21, 2003 1:28 pm
Postby Scoot » Tue Oct 21, 2003 11:10 pm
Jerm wrote:It is fixed in Pre-release 6.1.0.3 of Metro, which I hope to get out this week.
Jerm wrote:Version 6.1.0.3 pre-release now available!
Boy! That was the fastest week of my life! :lol:
About 2 days ago you said it was 10 days away! Image
scoot
