Sagan Technology Metro • View topic - Built-in audio does not appear in any popup menus in 6.0.8.2
Postby Jazzdude » Fri Sep 05, 2003 5:48 am
In the 6.0.8.2 pre-release, "built-in audio" does not appear in any popup menus, such as Modify Outputs and Busses, Change Ports, etc.
Jazzdude
Postby Scoot » Fri Sep 05, 2003 6:50 am
Hello Jazzdude.
Using Metro 6.0.8.2
Under 9.2 I have it listed as 'Audio'.
Under 10.2.6 I have it listed as 'Built-in Audio Controller'.
I just added a few extra outputs on the port to make sure it was ok and it also appears in the graphic editor port pop up and the tracks pop up.
Do you have something else connected that may be confusing the mac?
Does it show up in AMSetup if you're in OSX?
Postby Jerm » Fri Sep 05, 2003 11:16 am
You need to specify built-in audio in the digital audio setup dialog (in OS X) so that it will appear in popups.
Built-in audio now appears popups
Postby Jazzdude » Fri Sep 05, 2003 9:24 pm
That's all it took. I had not checked Digital Audio Setup.
:P
Jazzdude
